Any info on this tool? >
Old 06-25-2003, 12:10 PM
  #16
Steevo's Avatar
Originally posted by CypressMidWest
Steevo: Actually Robinson pinions use a 5/40 set screw which requires a 1/16th wrench, most other American pinions use a 4/40 set screw which takes a .050 wrench. The 4/40screw and .050 wrench combo is the accepted Standard in this country.
Hmmmmm......... I don't know what the deal is but I can say one thing for sure I use a 1.5mm Hex Driver for my Tamiya Pinions and a .063thou (which is 1/16 or there abouts) Hex Driver for everything else. I have never had the need for a .050 Thou Hex driver which according to my digital calipers is only 1.25mm (smaller than the Tamiya one)
Perhaps things are a little different down under
Steevo
Steevo is offline
Old 06-25-2003, 01:04 PM
  #17
Don't know about the Tamiya pinions, but I know for a fact that HPI pinions use 3mm set screws which require the 1.5mm wrench as stated in the manuals and provided in the kits. The X-Ray uses a 1/16 wrench. The set screws used with the MIP CVDs for instance use the .050 wrench. This is a very small set screw and I seriously doubt it is used in pinions.
calvin is offline
Old 06-25-2003, 06:12 PM
  #18
FUK_WRX's Avatar
Default losi tool
you should get your hands on that new losi shock tool for ultra fine shock tuning
FUK_WRX is offline
Old 06-25-2003, 06:44 PM
  #19
rc_bam226's Avatar
Hey doesn't Tamiya make a similar air-remover tool? As for the Losi shock tool, "SWEEET"
rc_bam226 is offline
Old 06-25-2003, 07:01 PM
  #20
pkranger63's Avatar
I have not seen a similar air removal tool from Tamiya. The Losi shock tool does look sweet but I will stick to my digital calipers for now
Matt
pkranger63 is offline
Old 06-25-2003, 10:22 PM
  #21
newracer's Avatar
yes they do
newracer is offline
Old 06-26-2003, 11:58 AM
  #22
pkranger63's Avatar
I still cant seem to find the Tamiya one. Any links folks?
Matt
Old 06-26-2003, 01:39 PM
  #23
Steevo's Avatar
Me neither......
To be honest I have never heard of one from Tamiya...
Steevo is offline
Old 06-27-2003, 07:24 AM
  #24
VenomWorldOrder's Avatar
Originally posted by Steevo
Me neither......
i have heard that they do but can't get a hold of one.
if anyone wants to sell their ride air shock remover pm me. i want to buy one.
VenomWorldOrder is offline
Old 06-27-2003, 08:46 AM
  #25
dtm
dtm's Avatar
The Tamiya version is exactly the same as the Ride...it just has a Tamiya sticker! A bit like the Tamiya camber gauge being the same as the Serpent gauge (it even still has the Serpent molding!)
I've been using the Ride version for a few years. You have to do it a few times before all the air is expelled. It is not bad!
dtm is offline
