charging lipos
Old 01-30-2008, 12:00 PM
stuey's Avatar
Default charging lipos
hey fellas what amps are best to charge lipos and what chargers are people using
stuey is offline
Old 01-30-2008, 12:11 PM
Trader Rating: 38 (100%+)
Orion Carbon 3200
6.4 Amps (2C)
Duratrax ICE
For safety most recommend 1C charging. Plus the ICE has to be tricked into doing it.
or8ital is offline
Old 01-30-2008, 12:25 PM
stuey's Avatar
can you djust the amps on a muchmore cell master v1 in lipo mode
stuey is offline
Old 01-30-2008, 12:46 PM
I dont believe so. I think its stuck at something like 1 amp.
or8ital is offline
Old 01-30-2008, 01:35 PM
Skruger's Avatar
Trader Rating: 16 (100%+)
The Much More cell master will charge Li-Ion at .1 to 1.0 amps
The Much More Silent charger will do Li-Po up to 4 amps (last I remember)
I personaly got a Triton Jr and for Li-Po it is the easy-est to use and will charge up to 5 amps best of all it is just $80.00.
Skruger is offline
Old 01-30-2008, 02:35 PM
Regional Moderator
Darkseid's Avatar
What amps are best: what ever the charger tells you to charge them at(most chargers lock in a amp level when you enter the lipo capacity)
what chargers: which ever one you have that goes at least up to 5amp. And if you don't have one already, Multiplex, Duratrax, Orion, Triton Jr. are all good options. Charging Lipo isn't the art form than charging NiMh was. All the lipo chargers charge the same way, CC-CV. No tricks, no bells, no whistles.
Darkseid is offline
Old 01-30-2008, 03:14 PM
what about this?
http://www.losi.com/Products/Feature...rodId=LOSB9607
it seems you don't need a lipo designed charger
il-gufo is offline
Old 01-30-2008, 03:23 PM
TryHard's Avatar
Stu,
Carbon 3600,
LRP Pulsar 3 @ 3.6amps (which is 1c).
It does allow you to charge upto 10amp... which is 2C for a 5000mah pack.
HiH
Ed
TryHard is offline
Old 01-30-2008, 04:48 PM
Originally Posted by il-gufo View Post
what about this?
Go to the electronics forum and read the reviews. Most people say its a waste of money. It only charges to 90%, works with a limited # of chargers and batteries (mostly receiver packs).
or8ital is offline
