Difference between 766 and 767 brush. >
Old 06-24-2003, 05:43 AM
Default Difference between 766 and 767 brush.
Same as topic, what is the difference between those 2 reedy brushes?
Thanks.
rcpilot is offline
Old 06-24-2003, 07:04 AM
gazza's Avatar
The 767's are a high silver content brush, though not as high as a putnam green shunt or trinity's 'e' brush. The 766 is a very soft brush with little if any silver in it. This brush is more of a torque compound, whereas the 767, putnam, e brush are more rpm-ish.
Hope this helps.
gazza is offline
Old 06-24-2003, 07:20 AM
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Is the 767 Reedy's highest silver content brush?
Randy Caster is offline
Old 06-24-2003, 07:37 AM
gazza's Avatar
Reedy has a new brush called the 728 that has a very high silver content, but I think it was meant for the Kr series of mod motors with the larger comm. Don't know how it would work on a stock motor though.
gazza is offline
Old 06-24-2003, 08:05 AM
StephenSobottka's Avatar
time to try it out today then, ill let u know
StephenSobottka is offline
Old 06-24-2003, 08:08 AM
Good thing, I am running the Kr series motors. I change the brushes after every run, so it doesnt really matter to me how fast they depleat, just trying to get the most power.
Old 06-24-2003, 08:13 AM
Yeah I'm running the Kryptons aswell and noticed on most of Ae set-up sheets they runn 766's with the kr.
rcpilot is offline
Old 06-24-2003, 08:37 AM
u got it randman
Old 06-24-2003, 11:12 AM
The 728 is a standup brush, it was designed for use in 4 cell mod applications, where wear is less, so you can get away with a high silver brush.
RC Paperboy is offline
Old 06-24-2003, 01:57 PM
gazza's Avatar
Yeah thats right, but you could toss them on a brush contouring tool to convert them to a laydown configuration.
gazza is offline
Old 06-25-2003, 12:35 AM
Mr. MR4's Avatar
Hi All,
The Krypton Motors do not like silver brushes. If you dont want to change brushes every run use the 766 brush.
I also tried out the Orion Silver Laydown brush which gave much better performance, but had to change brushes every run.
Mr. MR4 is offline
Old 06-25-2003, 12:45 AM
sorry guys if this sounds stupid, the krypton uses stock style brushes??
Johnnytc3 is offline
Old 06-25-2003, 01:20 AM
Mr. MR4's Avatar
JohnnyTC3,
Yes the Kr uses laydown brushes (Stock Style)
Mr. MR4 is offline
Old 06-27-2003, 11:20 PM
So talking about brushes, which ones do you recomend to replace the stock brushes that comes with the Orion ORbital Motors cuz i change them this week after a week of use and now the motor runs like crap, and overheats a lot.
SubaruWRC is offline
