Old 01-29-2008, 11:06 AM   #16
Nexus Racing's Avatar
Originally Posted by AdrianM View Post
Your results are pretty much the opposite of what evryone else is reporting.
Yup...everyone here who has tried the Core 5000 does not want to put any other pack in their car! The first time I tried one, I had to lift the throttle in a sweeper where I didn't have to lift using another pack.
Oddly enough, however, our Core packs seem to run better on the second run of the day...
NEXUSRACING.com
Nexus Racing is offline   Reply With Quote
Old 01-29-2008, 02:02 PM   #17
turbodog's Avatar
I have only used the CORE 5000 and do not feel the need to try anything else! LRP Pulsar3 charging @4.00 -no overcharging! Great power results!
Troy Schafer
turbodog is offline   Reply With Quote
Old 01-29-2008, 02:28 PM   #18
mtveten's Avatar
Trader Rating: 27 (100%+)
Originally Posted by zake540 View Post
Did the cars you tested between both packs weighed the same?
I ran over several days, 2 different layouts and a few different chassis but each comparison test used the same car on back to back runs. For example I would show up and run an Orion 3200 and core 5000 one day noting the performance difference between the 2 and then run one of them against something different the next time to establish a pecking order.
I balanced the car on pins with each pack to get even weight but not necessarily the same total weight from pack to pack. I can tell you that with the Orion 3600 in a t2007 I needed just over 6.25oz compared to a approximately 3oz for the core. My thinking was that the car needed a set amount of ballast on the battery side to balance the chassis and however much battery weight I removed I would need to add an equal amount lead to retain that balance.
Mark
mtveten is offline   Reply With Quote
Old 01-29-2008, 02:43 PM   #19
sinisterRC's Avatar
the core pack includes a balancing connector, what exactly is that??
MUGEN Tekno - MBX6TE TEKIN
Custom Nitro Pro Mod
MRX6 under construction..
sinisterRC - High Performance R/C
sinisterRC is offline   Reply With Quote
Old 01-29-2008, 02:53 PM   #20
Skiddins's Avatar
Was that second run of the day after having topped the pack up, or just a straight second run without touching the pack?
Also, which class?
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 01-29-2008, 04:17 PM   #21
wallyedmonds's Avatar
orion
imo
wallyedmonds is offline   Reply With Quote
Old 01-29-2008, 04:41 PM   #22
Hebiki's Avatar
Trader Rating: 26 (100%+)
Default Lipo weights
would someone be kind enough to post weights for each lipo?
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 01-29-2008, 06:42 PM   #23
skypilot's Avatar
Trader Rating: 14 (100%+)
well as one of the 'LOCAL' drivers that actually race the carpet where mark did his testing, let me say, i have two core 5000 packs, both of them rock. jaybee who many of you know also has two core 5000 and is of the same opinion. two weekends ago i went to a point series race across the state, i TQ'd four heats in a row, and ran away with the first A main, team corrally driver dave elrich (sp) thought my car had major rip, as did brain bodine of "Slapmaster" fame.
questions for mark, is the core you tested, the same one that brett and randy ran or did you buy your own.
mark you are more then welcome to run either one of my cores in on road, or come to trcr sunday and drive my b-4 powered by the core.
and yes i am a schmacher driver, and however bias i might want to be, my lap times and race performance back up the core.
skypilot is offline   Reply With Quote
Old 01-29-2008, 06:48 PM   #24
JayBee's Avatar
Trader Rating: 31 (100%+)
Originally Posted by mtveten View Post
All my testing has been in 10.5 sedan on a carpet track running simple a/b comparisons. Lap times for the middle tier packs I have tried were all the same but did produce different power bands and needed slightly different gearing to get the most out of them.
The 3600 was a full .1s faster than the middle tier packs from the start and fell off less over a 6min run, the power difference was great enough to be seen.
The core packs have all been extremely flat with no bottom or top end and ran nearly .2s off the 3600. With all the hype surrounding these batts I had expected them to be nothing short of exceptional and was certainly disappointed with performance I got.
Locally several other experienced racers that bought the core packs have had similar results and switched to others.
Mark
I run at the same track as Mark does (although more often) and myself and skypilot (Ritchie) were the first to run the CORE5000's. We still have our first packs and they run just as strong as when brand new. So my experience has been the complete opposite. Although I do sympathize with Mark, I'm very happy with my CORE's.
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 01-29-2008, 09:03 PM   #25
MagicMarker's Avatar
As far as I know most if not all Lipos have balancing connectors or ports. I know someone will be able to explain it better but balancing a lipo is like rematch a pack or putting it on a discharge tray and allowing each cell to be at the same voltage. Lipos, I believe, use the balance port as they charge (so the opposite of discharging them to equal volts) to equalize the cells. The CORE is external (can get in the way) and the Orion is internal (have to buy extra connectors to balancing). Hope you understand and that I didn't totally explain it incorrectly.
L8R Marker
Team Schumacher USA - Team Trinity - Team McGoo Racing - Ken Graf/x - Mini Mafia [Dallas Chapter]
MagicMarker is offline   Reply With Quote
Old 01-30-2008, 05:59 AM   #26
skypilot's Avatar
heres a link to a local for sale site... if you put two and two together you get......
http://www.rctech.net/forum/showthre...10942&page=118
Old 01-30-2008, 06:17 AM   #27
5000mah 20C Yuntong
and i think it was the most performing pack with hard case in the world for the moment
and yuntong have newer cell with 5400mah 20C and 3600mah 25C
and soon in april Roar certification
ironxxx4 is offline   Reply With Quote
Old 01-30-2008, 08:57 AM   #28
Tech Legend
Wild Cherry's Avatar
Seen the Core run , nothing that a Carbon 3200 can`t handle , Carbon 3600 is the fastest Li-Po pack I`v seen @Trcr so far ....
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 01-30-2008, 09:44 AM   #29
sinisterRC's Avatar
L8R Marker
After reading the whole Core 5000 thread and your response I completely understand, thanks. I have an ICE charger so if I would want to balance the batt I would have to purchase an inline device to effectively do so. Im assuming I will be able to use the Team Orion stability balancing system.
Old 01-30-2008, 10:42 AM   #30
mtveten's Avatar
I'm glad the schue guys are happy with the core battery but the 3 I tried (Randy & Brett's packs) as well as the RCE branded version (Franko's) simply did not perform. For me the Orion 3600 has proved itself best out of all I have run. It is possible that the 4 I tried are not as good as the 2 Skypilot got but even if his AND Jaybee's are exceptional I would be reluctant to buy a $125 pack where only 50% perform well.
Ritchie I appreciate your offer to try one of your core packs but I have switched from the TC5 to an x-ray and the core's hard shell would have to be modified to fit my new car. For now I am going to focus on trying thinner packs that fit the sedan without modification only, All my thick packs (tp4900 & trinity 4500) have been sold.
For those curios about my test sample sizes I have run 4ea of the Orion 3200, core/rce 5K, 2 Orion 3600 and 1ea of the tp4900 & trinity 4500.
Mark
Ni-MH LiPo Poll/Opinion YmeBP Micro and Mini Scales 21 07-18-2008 12:32 PM
What is YOUR opinion on SGT Pernia Electric Off-Road 0 03-08-2008 01:32 PM
Opinion??? scubajt41 Nitro Off-Road 3 12-18-2007 08:10 AM
your opinion please! biggy_j Nitro On-Road 11 01-14-2004 03:23 AM
