Old 04-29-2008, 06:33 PM   #1036
Taz_S's Avatar
Originally Posted by rcdougie View Post
I dont see the max 10 conversion on Doug's website. Is there a part number or a link? I've had a Quad 12 in the past and would like to see about the Max 10. Thanks!
email him. He dose need to update his site.
Taz_S is offline   Reply With Quote
Old 04-29-2008, 09:27 PM   #1037
Taz_S's Avatar
Stormer is out of stock Protoform Peugeot 905B
So if you need a Body
T-bang as them in stock.
http://www.t-bang.ca/catalog/product...roducts_id=619
Old 04-29-2008, 10:44 PM   #1038
tallyrc's Avatar
i wish bob would get a run of HD protoforms done.. i have everything but one of them...
WWW.STORMERHOBBIES.COM helping keep pan cars alive!
Turns out not where, but who your with that really matters... DMB
tallyrc is offline   Reply With Quote
Old 05-03-2008, 09:17 AM   #1039
Send a message via MSN to ammo
I have a problem with my pancar front end chattering very badly when i'm turning at any kind of speed. This results in massive understeer
Does anyone happen to a clue on the likely cause of this?
ammo is offline   Reply With Quote
Old 05-03-2008, 09:37 AM   #1040
Mason's Avatar
we need set up info as this could be anything...
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 05-03-2008, 08:48 PM   #1041
trailranger's Avatar
I sometimes associate wheel chatter as improper ackerman.
Is your ackerman correct. Maybe you have your links wierd on the saver or the steering knuckle.
trailranger is offline   Reply With Quote
Old 05-04-2008, 05:42 AM   #1042
Joost K.'s Avatar
Recently I started a home made Pro10 project and it is near finished now... I have tested it already and it runs good on the track. I didn't try to invent a new concept, instead I went fot an excisting concept that has proven itself already by Associated. A lot of parts came from my RC12L4 and some parts of an old school RC10L. It has a fiberglass chassis plate of 3mm. that will be replaced by a 2,5mm Carbon Fiber chassis in the near future. Also the rear axle will be replaced for an IRS rear axle.
The things that we made ourself are the main chassis, lower & upper pod plate, cross brace and T-bar. Al of the other parts and hardware are from the two Associated cars. Except for the tube dampers, they are from CRC. The body is a Corally Nissan that I had already and will also be replaced with a Protoform Peugeut 905B...
JKMR P235-SE Stealth Edition Pro10 | Futaba | Orion | Trinity | Orion | BSR tires
*** JK Model Racing ***
*** MIX-RC.DE TEAM ***
Joost K. is offline   Reply With Quote
Old 05-04-2008, 09:01 AM   #1043
Taz_S's Avatar
Look great where are you running it nextg?
Old 05-04-2008, 09:02 AM   #1044
Taz_S's Avatar
sorry dbl post.
Old 05-04-2008, 09:21 AM   #1045
losi nut's Avatar
So, I'm thinking the PRC Max 10 conversion is for 235mm ? What all comes with the kit? thanks
Bob
losi nut is offline   Reply With Quote
Old 05-04-2008, 10:11 AM   #1046
DPowell's Avatar
Bob
Bob,
Thanks for asking. The MAX10 was originally intended to be an upgrade/replacement for the AE 10L2 and is 235mm. The parts that we offer are the chassis, bottom pod plate, top pod plate and chassis brace. You can use our parts to update an existing car or build a new car from the ground up.
www.powellracingcomponents.com
**Record setting carbon fiber**
Speedmerchant and TOP USA dealer.
DPowell is offline   Reply With Quote
Old 05-04-2008, 10:31 AM   #1047
Joost K.'s Avatar
Originally Posted by Taz_S View Post
Look great where are you running it next?
Hey Taz, I am from the Netherlands (Europe) and I almost only drive it at the MACH circuit in Heemstede... It is not likely that I will drive it in the US...
Joost.
Old 05-04-2008, 11:14 AM   #1048
Taz_S's Avatar
Joost.
cool i just want to find out when you running next and how the car is doing.
Old 05-04-2008, 12:20 PM   #1049
Joost K.'s Avatar
Taz, here are some links to some movieclips we made on the MACH track. It was at night with the track lights on...
http://www.youtube.com/watch?v=OkeHcVQWwak
http://www.youtube.com/watch?v=_oSQy98gUa0
This was with a 19t Corally stock motor and GP3300 cells...
Joost.
Old 05-04-2008, 12:25 PM   #1050
Joost K.'s Avatar
Joost.
2WD pan cars 1/12, 1/10, Pro10 ammo Singapore R/C Racers 123 03-15-2013 12:40 AM
Rebirth of Pro10 bigmac567 Electric On-Road 5 02-22-2008 12:44 PM
WTB - Pro10 timmay70 R/C Items: Wanted to Buy 0 07-05-2007 08:02 AM
Corally Pro10 FS/FT trackdesigner71 R/C Items: For Sale/Trade 9 07-15-2003 09:42 AM
STS Pro10 Tips OZDC Nitro On-Road 4 04-07-2003 10:57 PM
