Old 04-09-2008, 08:32 AM   #961
Euge's Avatar
Originally Posted by Cunningham1972 View Post
I will post a release just before we go to market ok other than that keep an eye on the website ok.
Originally Posted by Marty Peterson View Post
I do not want to post pictures here email me and I will send you the info you ask for or email Chris ok.
I want Chris and MLP not to be pushed here this is for racing and not a sales tool Chris has said it time and time again he is a racer and not here to push a product ok.
you guys sure seem to write the same way ok
hmmmmmmmm ok
Euge is offline   Reply With Quote
Old 04-09-2008, 09:33 AM   #962
Cunningham1972's Avatar
short and to the point.
Oh I see that is to say we post similar, and that they look the same.
Well thatís it. I am busted. I am Marty. I just wanted back on r/c tech because itís like a drug and I could not live with out it, Right!!
Now that I think about it could it be that I took over MLP to help a guy out.
No thatís not it why would I do that? Oh I remember it was because I have owned every one of his cars and I liked them so much that I wanted to help when he became ill and I for one felt he could use a hand and not people looking to take him down.
So because I felt he needed help so that is what I set out to do.
One would think that the R/C public in his area would have said hey he is a new manufacturer in our home town or state and maybe he could use a hand and it would be cool to have a local guy making r/c cars and maybe we could help him and see if MLP comes up with something we would like to race, or even do some testing for him.
No I donít remember seeing any of that when he was taking a beating on here for setting out to try and make a touring car.
What ever. :
C.C.
Cunningham1972 is offline   Reply With Quote
Old 04-09-2008, 10:07 AM   #963
AdrianM's Avatar
Originally Posted by ammo View Post
Thanks Adrian!
Also, for traction additive we run Paragon on the inside 1/2 of the front tires and the full rear tire for 5 min. Then we apply a layer of cheap thin suntan lotion over the same areas and let it soak in for 15 min. We then wipe the tires off 5 min before a race.
The suntan lotion makes the traction last later into the run, very important for 8 min 1/12th racing, and makes the tires no pick up debris from the racing surface.
I don't know why it works so well but I have been doing this for 25 years and so far nothing else I have tried works as well.
Adrian Martinez
Old 04-09-2008, 10:07 AM   #964
Trader Rating: 37 (100%+)
Yes there is www.mlpmotorsports.net it is a handful right now but take your time I am working on the website as well and I took over MLP Jan 1st 2008 but it is not official till July 1st 2008 so I am doing all I can
C.C.
Hey Nexus I am going to try to get a car or 2 out to Marty he is in IL maybe you can hook up with him and do some testing
The website is all jacked up and I can't find contact info other then email.
I have some questions so what are the contact numbers for CLC?
Nexus is offline   Reply With Quote
Old 04-09-2008, 10:09 AM   #965
Nova F1 Racer's Avatar
R/C Tech Charter Subscriber
I assume you mean foam tires and not rubber tires...
This is DICK!!! And you're NOT!
RC Tech member #11
Aussie Rules Footy, Brisbane LIONS!!
[url]http://www.pitter-pat.com/[/url] for pet care needs in Northern Virginia
Nova F1 Racer is offline   Reply With Quote
Old 04-09-2008, 10:18 AM   #966
AdrianM's Avatar
Yes, this is for 1/12th and 1/10th pan cars running foam tires on asphalt.
Adrian Martinez
Old 04-09-2008, 10:25 AM   #967
I wonder about running rubber tires on the Pro 10 class... Too cut down the cost of racing....
RC Tech member #11
Old 04-09-2008, 10:32 AM   #968
EricF's Avatar
Can't be done. The manuf. or someone would need to make adaptors for the 12mm hex found on sedan wheels. There are capped tires but I beleive they cost more than foam and sedan wheels. Adrain (most of the time a good source of information) most likely knows more about this than I do.
E
EricF is offline   Reply With Quote
Old 04-09-2008, 10:35 AM   #969
GreaseMonkey's Avatar
Cut down the cost? Have you seen the price of capped tyres for pan cars?
I'm not a grown man playing with toys. I'm a hobbyist.
GreaseMonkey is offline   Reply With Quote
Old 04-09-2008, 10:59 AM   #970
E
hmmm... Maybe rubber tires are not the way to go now but if there is a market for it some one will offer it...
RC Tech member #11
Old 04-09-2008, 01:05 PM   #971
E
Already been done... By Tamiya.
It's not that hard to make the adaptors for the rear but you would need to relocate the front bearings into the steering knuckle like Tamiya did.
The tamiya cars can be a handfull with rubber tires and a little bit of motor.
Fred_B is offline   Reply With Quote
Old 04-09-2008, 01:08 PM   #972
AdrianM's Avatar
The Tamiya F103GT is a rubber tire pan car. The problem is even with the best tires it can't generate enough traction to use any more power than a silver can on 6 cells or Lipo. Even a 27T ROAR stock motor is too much power and will make the car spin out at the lightest touch of the trigger.
Foam tires on pan cars are a better choice. This is because they are so much wider than rubber tires. They can generate more traction so there is less slip and thus much less wear than even what nitro sedans on foam experience.
Adrian Martinez
Old 04-09-2008, 01:23 PM   #973
In my area the F103GT class is becoming very popular........since we started running foam tires. The cars are much more driveable and cost is less. A set of $20 foams seems to last about five or more full race days. In GT10 I have run four race days on a set of foams (pink front and rear) running 6cell/13.5. Our sedan racers are getting 2 or 3 runs on a set of $40 rubber tires.
jrrc is offline   Reply With Quote
Old 04-09-2008, 03:08 PM   #974
padailey's Avatar
I-Force shows up today!! Yipee!! Can't wait to get it on the track so we can get a class going!!
www.hobbyplexraceway.com
Tamiya TRF417X (Lion's Automotive GTR)
Tamiya TRF416X
Tamiya F104W MP6/4 converted to F104X1 (Renault R30)
padailey is offline   Reply With Quote
Old 04-09-2008, 03:11 PM   #975
JamesArluck's Avatar
Trader Rating: 52 (100%+)
Send a message via AIM to JamesArluck
That's cause all of us sedan racers don't have a clue how to set up a car..
JamesArluck is offline   Reply With Quote
2WD pan cars 1/12, 1/10, Pro10 ammo Singapore R/C Racers 123 03-15-2013 12:40 AM
Rebirth of Pro10 bigmac567 Electric On-Road 5 02-22-2008 12:44 PM
WTB - Pro10 timmay70 R/C Items: Wanted to Buy 0 07-05-2007 08:02 AM
Corally Pro10 FS/FT trackdesigner71 R/C Items: For Sale/Trade 9 07-15-2003 09:42 AM
STS Pro10 Tips OZDC Nitro On-Road 4 04-07-2003 10:57 PM
