Old 02-10-2008, 07:13 PM   #481
speedxl's Avatar
R/C Tech Charter Subscriber
Originally Posted by protc3 View Post
not exactly bro. It has more of the slaphammer effect than anything. The added weight also makes it harder for the front to set at the end of the straight.
Jason why would you have a slaphammer effect ? We didnt have it before. Car would set fine, you just may encounter a twitchy feeling ( quicker reacting, agressive) but that can fine tuned out. On my Quad 12 I run the batteries in the rear most position, as I used to when we ran 10th scale.
Pemberton / R1 / All out motorsports / Team Power Push
speedxl is offline   Reply With Quote
Old 02-10-2008, 07:14 PM   #482
protc3's Avatar
I will be going into production this week with a target release sometime early march. I have decided to keep the price at 300 or less. I have not figured the price yet but i will keep it at or under 300. It is a 200mm car and will not include tires in the kit. Tire compound will depend on the racing surface and it is very hard to decide what to include being that it will always be different.
Thanks for the compliments buddy
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 02-10-2008, 07:21 PM   #483
protc3's Avatar
The days of 6 cell racing in 1/10th pancars were when the motors were much slower and cells didnt weigh as much. In 4 cell 1/12th you are working with much less weight and a shorter wheelbase so this is not a problem in 1/12th. With todays motors and cells, they just weigh too much and once the car gets into a corner,the momentum wants to cary the rear around. TC does OK with it because of the 4wd but if you snip the front belt and run it RWD only you will see what i mean. With the amount of rubber,power in the motors and wieght of the electronics(especially with brushless), 4 cell has been clearly the better handling setup when we tested. 6 cell wasnt bad but 4 cell mod as opposed to 6 cell stock,4 cell proved to transition faster,drive deeper into the corners,and carry more corner speed than 6 cell in every test. I see no need for it when lipo 7.4 can give us the same voltage as 6 cell at the weight of the better handling 4 cell.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 02-10-2008, 07:47 PM   #484
AdrianM's Avatar
The 10R has gone through 3 different lower chassis. We started with the batts as far back as possible. Every time we tested a chassis we would move them forward and the car got faster.
Today we ran the car in the pic (prototype #3) vs. my prototype #2 with the electronics up front and the batts back 30mm and the car in the pics was clearly better.
Keep in mind that the 1/10 chassis is a lot longer than a 1/12 chassis and to maintain the proper weight distribution the batts would have to move forward.
Also by moving the electronics behind the battery its almost the same as the batts being further back but you get much better motor and battery wiring.
Adrian Martinez
Old 02-10-2008, 10:22 PM   #485
Cunningham1972's Avatar
I have ordered The CRC and Now Just waiting on the BMI !
Here are pictures of the Chassis I have been testing for a few months now.
We have made a total of 6 lower Chassis and others parts as well.
This Chassis or Car has been in the works for almost 2 years from what I am told it is a 200mm Pan Car as well and not from any of companies that have been talked about here.
I have run the HPI Corvette body 200mm and the Mustang Cobra 200mm and others it works good with most 200mm bodies.
I for one can't wait to test them all, and as well as race them when the class starts.
C.C.
Pro10 Class-x10-1.jpg   Pro10 Class-x10-2.jpg   Pro10 Class-x10-3.jpg   Pro10 Class-x10-4.jpg
Cunningham1972 is offline   Reply With Quote
Old 02-10-2008, 11:14 PM   #486
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
jason ygpm
Old 02-11-2008, 10:05 AM   #487
trackdesigner71's Avatar
Send a message via AIM to trackdesigner71 Send a message via Yahoo to trackdesigner71
Well now that we have our first cars hitting the market when are we going to start hearing reports from some of you guys (well other than Jason, Adrian and Marcos) running these cars. I like Grenade's idea for 4 cell 17.5 for GT. I think that LiPo and 17.5 would be workable as well. As I said before, we can't totally forget about the 235mm GTP cars because those cars really were the backbone of 10th scale pan car racing. I think having the option of 200mm or 235mm for tracks would help not only keep the guys that ran GTP in it, but itd also give an option for guys just coming into 10th pan racing with the 200mm GT
trackdesigner71 is offline   Reply With Quote
Old 02-11-2008, 11:38 AM   #488
Bill and Rocky have run them- 4 cell and 13.5. And we will for the rest of the year. His car is a 200mm Associated and mine is a 200mm RJSpeed.
Team Epic/Trinity -Michael Bruce Hobbies-Team CRC ,Kimbrough Products and GForce.
WGT-R, GT-12 Racing USA (21.5 ), Formula 1 and Home Track is 386 RaceWay,ROAR #7540.
BullFrog is offline   Reply With Quote
Old 02-11-2008, 06:53 PM   #489
Mason's Avatar
Dale, Gary and other Body producers.. What are your thoughts on a separate rear wing (like the real cars) instead of a molded in thing like days gone by. Is one cheaper than the other, which one would benefit the long term need to help keep the cars driveable yet not crazy fast.. and I mean nothing as huge as a TC wing!
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 02-11-2008, 07:44 PM   #490
Grenade10's Avatar
Trader Rating: 37 (100%+)
I'm getting the 200mm Darkside ready to roll with 4 cell and 19 turn. Need to get a good GT body. I'd like a Porsche GT1, just need to go looking. I'll have it ready to run at our track on the 24th.
I'm running my Corally 235 this week, so it should be a good comparison.
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 02-11-2008, 07:58 PM   #491
tomkelley's Avatar
I just noticed that a Tamiya f103 is 200mm. Since they are a 200mm pan car, looks like it'll do! I'm going to start dusting them off!
Detroit Radio Control Car Club
www.drccc.org
tomkelley is offline   Reply With Quote
Old 02-12-2008, 01:18 AM   #492
I just ran an F103 with a canam body in Pro10 at the New Zealand Electric nationals that just happened this weekend, I put some of my spare corally sp12x ceramic balls in it, and ran a normal spur gear with the spur gear adapter, and the diff felt almost as good as my corally diff which is surprising, it was the first time i've run that chassis for about 4 years, and it was very fun with 6 cells and a mod motor in it . I should have some video of it on rcracer.co.nz soon as well as vids of modified, stock etc.
drivingpro is offline   Reply With Quote
Old 02-12-2008, 02:15 AM   #493
rosko's Avatar
Wink
cant wait to get one, i really hope they run gt type bodies ONLY and leave the 200mm dna's , and stratus's out of this class. i think this class would be a lot more fun if we leave the tc bodies on the tc's. go to a big race you could'nt run a gt body on a tc so i think you shouldnt be able to run tc bodies on the 1/10th scale. i think this class would be lots of if we dont intermingle the two classes...........................
rosko is offline   Reply With Quote
Old 02-12-2008, 07:22 AM   #494
RBLove's Avatar
Trader Rating: 72 (100%+)
Agreed...
RC America, Xray, Hudy, R1 Wurks, EA Motorsports, ProLevel RC, Ulti Tires America, PROTOform
RBLove is offline   Reply With Quote
Old 02-12-2008, 02:40 PM   #495
RB, didnt they try to get a 10th pan class going at the Gate at one point?
2WD pan cars 1/12, 1/10, Pro10 ammo Singapore R/C Racers 123 03-15-2013 12:40 AM
Rebirth of Pro10 bigmac567 Electric On-Road 5 02-22-2008 12:44 PM
WTB - Pro10 timmay70 R/C Items: Wanted to Buy 0 07-05-2007 08:02 AM
Corally Pro10 FS/FT trackdesigner71 R/C Items: For Sale/Trade 9 07-15-2003 09:42 AM
STS Pro10 Tips OZDC Nitro On-Road 4 04-07-2003 10:57 PM
