Old 02-05-2008, 12:21 AM   #331
Originally Posted by Scottrik View Post
Um...if they're both 4200's and both charged at the same rate (say, 6 amps) they charge in pretty much exactly the same amount of time. Number of cells only affects voltage. SIZE of cells affects mah and, thus, charging time.
........... guess what my point was ..... it takes exactly the same amount of time for a 4 cell pack and a 6 cell pack to get a full charge.
With the 6 cell pack however you get the extra runtime.
Make it idiot-proof, and someone will make a better idiot.
Quante is offline   Reply With Quote
Old 02-05-2008, 12:44 AM   #332
Thumbs up
Gen X10 HHHMMMM.!!!!!
THEBIGBULL is offline   Reply With Quote
Old 02-05-2008, 04:19 AM   #333
protc3's Avatar
Originally Posted by speedxl View Post
What up Jason, see things are doing good for you guys. Great to see you involved with helping the proten class comeback. Look forward to rubbing fenders on the track.
Hey dude. Good to see you coming back to racing. I think this is going to be a great class. I decided to go super crazy exotic looking instead of the way i had my prototype. Price shouldnt jump more than 5 or 10 bucks but it will look like it did. I really feel this class will catch on for alot of clubs once they try them. We ran them at minnreg and they were really awesome.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 02-05-2008, 04:30 AM   #334
Since it was brought up- I've said it several times before . The Fla. series ran there first state race and in the vintage class there were two 200mm pan cars and one 235 (gtp body) running. The Purple Cuda (13.5 with 4 cell- 4600)and the Green and white Mustang(13.5 with 4 cell- 4200).Gosh and I've got no experience running pan cars?I can remember them being introduced to the world(1985) at the Winter-Nationals in Orlando by Bolink.Parma also introduced the 1/18th car that was a clear lexan chassis.Also going to the 1st 1/10th nationals in Tulsa, Okla( the same hotel as the Oral Roberts convention)!
Hector between you and Michael Bruce you've lost two people. I probably won't reconize you next time I see you.
Team Epic/Trinity -Michael Bruce Hobbies-Team CRC ,Kimbrough Products and GForce.
WGT-R, GT-12 Racing USA (21.5 ), Formula 1 and Home Track is 386 RaceWay,ROAR #7540.
BullFrog is offline   Reply With Quote
Old 02-05-2008, 07:08 AM   #335
AdrianM's Avatar
4 cell and 6 cell packs are wired in series so the run time for both are the same. You just get more voltage with 6 cells.
Adrian Martinez
Old 02-05-2008, 07:29 AM   #336
Scottrik's Avatar
Trader Rating: 245 (100%+)
Hey Adrian. I THINK his point is that to go the same "speed" you're calling on less from the 6-cell pack (less throttle) than the 4-cell. You and I know this ain't how it would work "at the track" though. Firstly, you wouldn't go the same speed, you'd go faster, thus using energy at the same (or close to the same if traction-limited") rate. The additional weight being carried around (two 4200 cells is right at 5 ounces...a significant percent of a pan car's weight) will require more energy be expended each time the car is positively accelerated. The additional heat generated by the higher voltage also affects efficiencies within the system. Etc.
The argument, though well-intentioned (I think), appears fundamentally flawed to me though I stand ready for correction as appropriate.
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline   Reply With Quote
Old 02-05-2008, 08:33 AM   #337
Send a message via AIM to WhoMe
This definatly looks like a cool class. I just recently came back into the hobby after being out for about a year and a half. Im currently racing 4 cell 12th scale and its a blast. So naturally a tenth scale pan looks like a very attractive alternative to running 10th scale sedan onces it gets warm out.
But this battery thing is definatly a sticking point for me. I personally would like to get away from running Nimhs. I dont want to run Lipos to go stupid fast, I just want to get out of the battery maintainece dance. So what BL motors would make this managable (slow enough) at 7.4 volts?
So aside from the speed what are the negatives of running a 7.4 lipo in this class?
WhoMe is offline   Reply With Quote
Old 02-05-2008, 10:00 AM   #338
yyhayyim's Avatar
Trader Rating: 26 (100%+)
if you want to go slow...use 17.5BL motor...slower, use 21.5BL
yyhayyim is offline   Reply With Quote
Old 02-05-2008, 10:13 AM   #339
AdrianM's Avatar
Uh...I just though he didn't understand that the capacity was the same.
Adrian Martinez
Old 02-05-2008, 10:22 AM   #340
CanyonCarverR1's Avatar
Cool
6 cells will actually give less run time
More Voltage = more current = less run time
CanyonCarverR1 is offline   Reply With Quote
Old 02-05-2008, 11:11 AM   #341
Had a little discussion awhile ago with a good friend. He was telling me want I already suspected. Yes what goes around comes around and the big push is 1/10th pan cars- With what I was told. It really makes alot of common sense I've seen the same thing happening when I first started racing many years ago.Cost of a kit goes up less racers.With the coming of the 1/10th pan cars it's cheaper for the general everyday racer.Then we get our racers out of this new group of racers.Then in about 10 years the cycle will change again. To all the pan cars manufacturers present and in the near future thank you helping our Hobby grow again and keeping the overall maintance reasonable.Now I don't have to be a mechanical genius to set up my car - I just have to remember what I forgot.Luckly I've have notes from the old days.
Fun days are here a again.........................................
Old 02-05-2008, 11:20 AM   #342
Ever think about that you can actually gear a car down?????
Make the cars run the same Top end speed and lets see which car drives the longest....
But hey, what do I know.... I'm a guy with just a hundred posts or something. That must mean my knowledge of RC is pretty low...
Old 02-05-2008, 11:29 AM   #343
Cosmo's Avatar
I like the idea, but how do you propose making all the cars run the same top speed? Even with identical motors, batteries, gearing, tires, etc. some will be faster than others. If you specify a certain gearing, then you have to take into account running foam tires and not all of them are going to be the same diameter. And, people running different motors that reach different RPM's.
I'm all for making the cars as equal as possible, but how can you make them run the same top end speed?
Cosmo is offline   Reply With Quote
Old 02-05-2008, 11:45 AM   #344
ZipZap's Avatar
Not really, it's an energy thing. With a fixed resistance, the 6-cell pack would discharge faster. With a fixed load, the 6-cell would last longer.
The thought is that the 6-cell would be run on a higher resistance motor (more winds) so that the power output would be equivalent. The 6-cell would nominally have 30.24 Watt-hr where the 4-cell would have 20.16 Watt-hr.
For an equivalent load of 100 watts, the 6-cell would run 18 minutes and the 4-cell would run 12 minutes.
ZipZap is offline   Reply With Quote
Old 02-05-2008, 12:00 PM   #345
trackdesigner71's Avatar
Send a message via AIM to trackdesigner71 Send a message via Yahoo to trackdesigner71
I think there needs to be some spec aspects to any 10th pan class either way. I suggested the 4 cell and 10.5/19T but whatever the accepted combination is, I think some sort of a spec aspect ought to be integrated. Im not saying that every single thing (right down to the top end speed) needs to be spec but something to at least start everyone at the same ground floor. Whether its 7.4 LiPo and 21.5 or 4 cell NiMH and 17.5/27T or whatever, some sort of a spec aspect ought to at least be considered to level things from the start.
trackdesigner71 is offline   Reply With Quote
2WD pan cars 1/12, 1/10, Pro10 ammo Singapore R/C Racers 123 03-15-2013 12:40 AM
Rebirth of Pro10 bigmac567 Electric On-Road 5 02-22-2008 12:44 PM
WTB - Pro10 timmay70 R/C Items: Wanted to Buy 0 07-05-2007 08:02 AM
Corally Pro10 FS/FT trackdesigner71 R/C Items: For Sale/Trade 9 07-15-2003 09:42 AM
STS Pro10 Tips OZDC Nitro On-Road 4 04-07-2003 10:57 PM
