Old 01-26-2008, 07:50 PM   #1
SammyZ's Avatar
Trader Rating: 138 (100%+)
Default Battery Strapping Tape vs Electric Tape
I've used both tapes, sure the strapping tape is stronger, but i've never had the electric tape break on me. I see no difference in performance but the cost is $14.99 vs .99 cents, whats the point?
SammyZ is offline   Reply With Quote
Old 01-26-2008, 07:53 PM   #2
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
$14.99 for strapping tape is alot cheaper than buying another battery pack
i use the 3m strapping tape like this one and is $2.50 per roll
Old 01-26-2008, 07:57 PM   #3
Maybell's Avatar
stapping tape is for sure the way to go....especially "Sliontech" tape...with that stuff one can fold the ends over and reuse the same piece 4-8 runs before needing another piece...
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 01-26-2008, 08:16 PM   #4
stiltskin's Avatar
Trader Rating: 102 (100%+)
Electrical tape will stretch. You don't need that to happen.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 01-26-2008, 08:46 PM   #5
gubbs3's Avatar
Stretching is bad. That will allow the cells to jiggle around and give them extra momentum that can eject them in a crash.
gubbs3 is offline   Reply With Quote
Old 01-26-2008, 09:09 PM   #6
trailranger's Avatar
Go with the FIBER...
Good for your car,
Good for your diet.
FIBER makes you go faster!!!!
Well in this case, fiberglass reinforced tape
trailranger is offline   Reply With Quote
Old 01-26-2008, 09:14 PM   #7
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
I use a strapping tape I get from my track (forget the brand name) But its sooo sticky and strong, and to be sure, I double up the tape, tape the pack in with 1 piece, and then another, and I use that for about 20 runs
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 01-26-2008, 09:36 PM   #8
adamge's Avatar
Marcos, what's the part number on that 3M tape?
When someone is intent on excelling in an otherwise laudable manner, does he not desire to inflict pain on others by means of his exalted status and enjoy the envy he arouses? Is there not an anticipated delight in an artist's ability to defeat his artistic rivals, which heightens his euphoria in creation?
-Nietzsche
adamge is offline   Reply With Quote
Old 01-26-2008, 11:47 PM   #9
SammyZ's Avatar
nice, i foudn the 3m tape, its a filament tape EXACTLY the same as the expensive r/c stuff for $2.50 a roll. Unreal deal!
Old 01-27-2008, 01:56 AM   #10
flashgordon's Avatar
Trader Rating: 27 (100%+)
Talking Fibre Tape
Hi Guys,well fiberglass reinforced tape is the way to go if there is a problem with people think they may split tape where it wraps the chassis just run two strips extra on bottom of chassis at cell ends this makes sure it wont wear as it will have to get other 2 layers down before that could even happen as for cost well i have unlimited supply from work and get it cut to 22mm wide
RDX/PHI 09 Corally-Emtron 30amp Power Supply-KO Helios-Spektrum-Speed Passion
Graphics Alive
M.R.C.C.A...R.I.P
flashgordon is offline   Reply With Quote
HOW TO TAPE BATTERY TO CAR Rolex Rookie Zone 10 04-17-2008 07:08 PM
How can i do away with battery tape on 1/12? crusty Electric On-Road 31 02-08-2007 08:14 PM
Strapping tape for off-road BobWoodhouse Electric Off-Road 2 01-01-2007 07:34 PM
Battery Strapping Tape? Goonish Electric On-Road 18 06-05-2005 05:27 AM
Blue Strapping Tape - Where is it cheapest? RichO Electric On-Road 9 12-29-2004 08:00 AM
