LIPO Product Idea - Who wants to partner with me?
So Ling is saying heating a lipo pack produces better #'s. ROAR has said a lipo sack is necessary for safety. The next logical step is a heated 'lipo sack'. If someone wants to produce it, I will take just 20% of the profits for the idea
patent pending...
patent pending...
I should say, I was using it, but it was a hassle to fit it in the liposack and keep an eye on temp while it was covered up. I've been leaving it at home lately. A combined bunker/warmer would be nice. Maybe a really tough easy bake oven is the answer. Or a reptile heating pad in a liposack.
http://www.redrc.net/2006/12/velocit...tery-warmer-2/
Now, all you need to do is combine that with a Liposack and you're set.
Yeah I was thinking 2 leads to the sack. One for the power for heat and one for charging (but also have internal connectors to the sack for the battery charging. Then put a display on the outside to help monitor things. Maybe add a couple of blue LEDs and some ringtones. Those are always worth a few extra $$$'s.
I have been away for a sec...sup fellas. I thought heat was the enemy of Lipo...now I am hearing they produce better numbers when warm. Thats fitting. It was BRICK here in NYC and thinking I could get some good pratice outside, which would be a cinch to keep the motor cool, I noticed fade after about 10 minutes. Fellas, get the pitbull up to speed.
