Old 01-23-2008, 07:24 PM   #1
Nuclear Dave's Avatar
Default Question about on throttle response.
rdx phi-when starting at a slow speed. as i get on the throttle pretty heavy my car starts to track left. if i ease on the throttle from a slow pace it tracks straight. my guess would be the diff is slipping, would i be correct? or is this a suspension issue? this was running on a tennis court (pretty decent grip) with vintage rubber tires.
im new to the on road sport but a good racer helped me set up my car. so on that end i should be good.
Nuclear Dave is offline   Reply With Quote
Old 01-23-2008, 07:35 PM   #2
might be a diff slipping ... make sure there is no tweek in your car .. also chk your shocks . one might be a little soft causing what your describing .. also make sure you wheel nuts are not too tight . just some things to chk ...also try a diffrent set of tires ,,,,
Mark Barden .
mb racer is offline   Reply With Quote
Old 01-23-2008, 08:16 PM   #3
i run the car in a vintage series so the tires have to stay the wheel nuts are only snug. my shocks are diaphram type. they are free of air and with the spring removed, when compressed they have 0 rebound. i read some places i should have 1/8th inch rebound. but it seems there referring to emulsion type. and on RC411.com they dont really say. anyone know for sure?
Old 01-23-2008, 11:43 PM   #4
gubbs3's Avatar
If any type of vehicle is pulling to one side under heavy acceleration you really have to go through everything to correct it. Everything must be checked: left/right balance, same length shocks, equal rebound, equal preload, equal toe/camber... anything that is adjustable, needs to be gone through.
gubbs3 is offline   Reply With Quote
Old 01-24-2008, 02:46 AM   #5
Thats an easy one.. Your car is tweaked. Basically your cars weight ditribution is not balanced accross your four wheels. I suggest you get someone local to show you how to guage tweak and fix it as it can be hard to understand with just words.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 01-24-2008, 03:11 AM   #6
Drewdc90's Avatar
Check that the chassis isn't twisted on a flat surface, if it isn't check every thing in the suspesion and shocks is even side to side. If that doesn't fix the problem get hold of a tweak station. The tweak station will tell you what wheel has more weight on it, you can then use the shock collars to even out the weight distribution.
-Xray--Nosram--Orion--Trak Power--Duratrax--Spektrum--Futaba-
Sunshine Coast QLD AUSTRALIA
"If you stand still long enough you'll go backwards"
Drewdc90 is offline   Reply With Quote
Old 01-24-2008, 07:37 PM   #7
thank you for the response guys. ive checked all my settings with the exception of the weight distribution. can you tell im new? im glad i have an avenue of attack now. thanks again.
nitro rustler throttle response problem gsxrmcs Nitro Off-Road 6 08-24-2008 01:23 PM
Throttle control question 2t'sracing Electric Off-Road 2 05-07-2008 11:02 PM
BF Throttle reverse question. silvergt02 Electric Off-Road 4 01-23-2005 09:01 AM
Throttle question? 2Hard2Handle Nitro On-Road 10 08-15-2003 10:44 PM
