RDX question...
Old 01-23-2008, 06:06 PM
TL_XXX-S_racer's Avatar
Default RDX question...
Hey guys, Well I just finished re-building my RDX and seems like I have a little problem. With running the 1,1 roll centers in the front, I cant seem to get the ride height down to 5mm. Running rubber tires 22lb springs. Plus, before the chassis bottems out on the board, the shocks get fully compressed. What seems to be the problem so I can fix the problem?
Thanks,
Chris
TL_XXX-S_racer is offline
Old 01-23-2008, 08:04 PM
Brian McGreevy's Avatar
Cut approximately 3 mm off the shock end where the shaft threads in. This will allow the spring cup (and spring) to sit lower.
Brian McGreevy is offline
Old 01-23-2008, 08:25 PM
RCFREAK's Avatar
Trader Rating: 19 (100%+)
i use hpi spring perches... lower than the rdx ones.
RCFREAK is offline
Old 01-23-2008, 09:00 PM
Nuclear Dave's Avatar
http://www.corallyusa.com/2005/shocks.htm
Nuclear Dave is offline
Old 01-23-2008, 09:04 PM
Still Bill's Avatar
Trader Rating: 16 (100%+)
Agreed that this is the answer for your rubber tire setup.
Still Bill is offline
Old 01-24-2008, 07:12 AM
Trader Rating: 50 (100%+)
Thanks,
Chris
Chris,
I run an RDX and was wondering how much traction you have. I have never ran a spring that stiff unless traction was through the roof. Usually 17's in front and 14's in rear. I use the 3mm chassis. and standard Corally spring cups. Associated cups are lower also. I use them for when I race Foam though.
I use full length shock shafts and std towers.
Jaz406 is offline
Old 01-24-2008, 12:17 PM
Ok thanks guys for the help. What would the easiest way to go? Get different shock spring perches? If so, just get the HPI ones, for the Pro4 or what? Im also using the Phi shock towers, with standard shock length. The towers so ride height doesnt change when you move shock position
Jaz: Well the thing is, Im running 35 weight oil, with one-way. And the rest of the setup you would have to know, why Im running that stiff of a spring
Old 01-24-2008, 07:47 PM
Still Bill's Avatar
Yes, the Pro4 spring perches are the ones.
Why are you running Phi shock towers on your RDX? Are you sure that they aren't the low version ones?
Old 01-25-2008, 12:07 AM
Cool
Send me your setup via p.m. I'd like to see it.
Jaz406 is offline
