Old 06-22-2003, 05:37 PM   #1
Registered User
Calvin Ng's Avatar
Send a message via ICQ to Calvin Ng
Default Charger Terms
just purchased a millenium pro
can someone explain these things to me
whats the diffrence between "ni-cd linear" and "ni-cd rev pulse"?
if i wanted a performance charge out of my millenium pro would i use another setting instead of the nimh2?
What is Trickle Charge?
What is Threshold? mv?
im looking for the safest charge possible for my 2400's at 5.0amps
Calvin Ng is offline   Reply With Quote
Old 06-22-2003, 05:47 PM   #2
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
You want to use Nicd linear. Nicd reverse pulse can be good for charging old packs that need a wake up.
Trickle charging is very low amperage charge after the initial peak, NiCD batteries like this, NiMH do not.
Threshold is the amount a battery is allowed to charge after it reaches peak voltage. After peak voltage is reached, you will see the voltage of the pack drop down a certain amount. You are able to set how much it drops. NiCD batteries like about 10-15mv threshold per cell, so thats about where you should set it. NiMH like between 3-8mv.
My suggestion to you, charge at 5-6 amps, 12mv cutoff with tickle charge on. Make sure you discharge the pack completely after you are done using it.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 06-22-2003, 05:51 PM   #3
Registered User
Calvin Ng's Avatar
so is higher threshold good or bad
Old 06-22-2003, 06:39 PM   #4
neither. a higher threshold will charge the pack for longer (more mah, more runtime) but if you go too far you can overcharge the pack, damaging or ruining it. i might be wrong but i think a higher threshold also decreases punch. the purpose of adjustable threshold is basically because different packs require different thresholds, you want to find a compromise between runtime and the condition of your pack.
Trippin Freddy is offline   Reply With Quote
Old 06-22-2003, 06:42 PM   #5
Registered User
Calvin Ng's Avatar
ok thanx you guyz
that answers all my question
Old 06-22-2003, 06:47 PM   #6
I use Threshold to "set the temp". Your NIMH batteries should come off the charger at 100 to 125 F. If 4 Mv per cell (24 per pack) does not get them warm after charging, then go to 5Mv per cell (30 per pack). You will get to know your packs and charger after a wile. NO RATE or Mv setting will perform magic on your cells. Charge them at a reasonable rate (5 amps) without getting them too hot and that is all you get. It is good to have the charge end just before you start a race so they are good and warm. This is how they perform the best.
David Root
David Root is offline   Reply With Quote
Old 06-22-2003, 06:58 PM   #7
Registered User
Calvin Ng's Avatar
ok on my millenium pro it has a 3 settings nicd linear nicd reverse pulse and nimh2
lets just say i wanted to use threshold on my nimh. but then when i choose nimh the only settings are the amount of amps and the number of cells.
would i use nicd linear then?
Old 06-22-2003, 07:02 PM   #8
Geez, Idunno, I have never used a Milennium.
sorry I can't help on that one.
Old 06-22-2003, 07:05 PM   #9
Registered User
Calvin Ng's Avatar
do you have msn?
sounds like you do since your replying so fast
Old 06-22-2003, 07:13 PM   #10
You can use the NiCD linear setting, I have a millenium pro and that's what i use for my NiMH. Just set the threshold setting low enough and your packs will be great. What kind of NiMH cells do you have? I could give you an idea of what threshold to use with that info.
USVTA Member #211
Old 06-22-2003, 07:22 PM   #11
Registered User
Calvin Ng's Avatar
i have gp 3300's
and sanyo's 3300's
i want to charge em at 5 amps
Old 06-23-2003, 09:52 PM   #12
For your GPs use a 5 mv threshold
For your Sanyos, try 7 or 8.
USVTA Member #211
Old 06-23-2003, 09:54 PM   #13
Registered User
Calvin Ng's Avatar
so whats with threshold
can you tell me the advantages of having it high and low and the disadvantages of having htem high/low
Old 06-23-2003, 10:02 PM   #14
Threshold is the amount of voltage drop allowed (still charging) right after peak voltage is reached. This is the point at which your batteries start to get pretty warm. Some batteries take more threshold to reach a good peak, other's don't. Most sanyo cells like higher threshold than GP or panasonic.
USVTA Member #211
Old 06-23-2003, 10:05 PM   #15
Registered User
Calvin Ng's Avatar
how bout trickle charge
im looking for a performance charge and a good safe charge for my batteries
the one you gave me would that be considered performance or safe.
can you give me some settings i can use
amps (around 6-7)?
threshold?
trickle charge?
performance/safe
sanyo 3300's and gp 3300's and panasonic 3300's
Is this normal behaviour for a Mamba Max? + some BL terms Qs shurcooL Electric Off-Road 19 08-15-2008 03:56 AM
What is the best RTR on road touring car out there in terms of performance? rclab1 Electric On-Road 4 03-27-2007 07:15 AM
ESC Terms AZNracerx1989 Electric On-Road 2 07-21-2005 06:48 AM
Battery Discharge Terms and Definitions Entropy Electric On-Road 0 05-08-2005 10:53 PM
Help Understand Droop Terms rctoyguy Electric On-Road 9 06-29-2004 02:45 AM
