Old 06-22-2003, 02:26 PM   #1
Registered User
Calvin Ng's Avatar
Send a message via ICQ to Calvin Ng
Default Protecting Bottom Of Chassis
you know that plastic stuff to protect the bottom of the chassis.
i have a couple of questions
how do you guyz make the holes so you can still put your screws into it? using a exacto-knife is kinda weird.
Calvin Ng is offline   Reply With Quote
Old 06-22-2003, 04:54 PM   #2
Steevo's Avatar
I make a template out of tracing paper by placing it on the chassis and marking where you want the holes to be. Then I place it over the adhesive protection stuff and mark the centre of the holes with something sharp and then I either drill or use a hole punch to punch out the holes.
Steevo
Steevo is offline   Reply With Quote
Old 06-22-2003, 05:01 PM   #3
Registered User
Calvin Ng's Avatar
hole puncher never thought of that
thanx again. probably dont remember me butt you helped me out alot thanx
Old 06-23-2003, 11:04 PM   #4
FUK_WRX's Avatar
Send a message via ICQ to FUK_WRX Send a message via AIM to FUK_WRX Send a message via MSN to FUK_WRX Send a message via Yahoo to FUK_WRX
Default contact
Steevo
Hello Steve,
What do you exactly use to cover it ?? Because over the time i just use two layers of CONTACT( used to cover and protect books) . How do you do it ?? Just really curious want to preserve the chassis so in times of selling it will always be in good condition
FUK_WRX is offline   Reply With Quote
Old 06-24-2003, 12:23 AM   #5
Steevo's Avatar
I went to a Skate shop and bought some clear adhesive plastic that they use to protect the bottoms of skate boards. Some of the stuff you can get is a little thick so use as little as possible if this is what you get. You can also get some similar product that you put on the top of your tennis racquet which is excellent as well.
I only use it on the front and back of the chassis and a strip down each side.
Hope this helps
Steevo
Old 06-24-2003, 12:58 AM   #6
FUK_WRX's Avatar
Default thanks
gee, never thought of that. Thanks steve.
Old 06-24-2003, 01:13 AM   #7
Go to a local motorcycle shop, they use protective sheeting for tanks of dirt bikes, it is very cheap, quite thin and very hard, comes in about an A3 sheet, can get about 4-5 chassis out of one piece.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 06-24-2003, 01:53 AM   #8
Projector transparency film works as well and is easier to remove since you tape it to the bottom of the chassis.
Awesomatix A700L (building) | VBC Wildfire D07 (building) |416WE/X Smokem | Hobbywing 120A v2.1 | Sanwa M11x
itchynads is offline   Reply With Quote
Old 06-24-2003, 05:03 AM   #9
poolman51's Avatar
good idea i will try which is better.....
poolman51 is offline   Reply With Quote
Old 06-24-2003, 09:48 AM   #10
Regional Moderator
Addict sa RC's Avatar
Try this site and take a look at the "Skuff Saver".
Addict sa RC is offline   Reply With Quote
Old 06-24-2003, 05:14 PM   #11
JohnA's Avatar
I gave up on the OHP, too much dirt gets caught underneath and I've had a few runs where it came off.
I now use Associated or Yokomo (both the same) chassis protector sheet, sounds the same as the stuff mentioned above for dirt bikes think I'll give that a try.
JohnA is offline   Reply With Quote
Old 06-24-2003, 09:36 PM   #12
Steevo's Avatar
The stuff used for dirt bikes is excellent. The stuff for skateboards and the top of tennis racquets is also good and slightly cheaper.
I use the latter because it is enough to do the job unless you want to cover the whole chassis of course. Due to the weight factor I only cover the front and back ends as well as a strip down both sides.
If you choose to use the protector film used on motorbikes they also make it in a carbon fibre pattern which is way cool....and at first glance looks just like the chassis itself.
Steevo
Protecting your chassis pracy Nitro Off-Road 6 06-23-2008 11:39 PM
TC5 bottom chassis loopedout R/C Items: Wanted to Buy 0 12-11-2007 06:56 PM
Protecting your lower chassis? TGA78 Nitro Off-Road 6 07-04-2007 11:40 PM
Protecting the bottom of the chassis Wing Chun Australian Racing 8 03-26-2007 04:35 AM
Protecting the bottom of chassic. N15M0 Singapore R/C Racers 5 09-27-2005 10:31 AM
