PPD EZ-LiPo --TC5 and beyond LiPo mounting Solution. >
Old 07-24-2008, 03:19 AM
  #241
Hoggy's Avatar
Trader Rating: 26 (100%+)
received the stuff today, thanks for the speedy delivery. really high quality work!
Hoggy is offline
Old 07-25-2008, 02:42 PM
  #242
Khador12's Avatar
I received my bottom plate and adjustable side plate today. It fits nicely in the Cyclone TC. I do have one question, with the new chassis on the TC their is more space to add in weight in the battery slots. would it be possible to get one like that? Also would it be possible to add notches for the Orion 3600 to set in?
Khador12 is offline
Old 07-26-2008, 08:27 AM
  #243
Verndog's Avatar
Trader Rating: 16 (100%+)
Although it would be convenient to have a notched plate for Orion, it's not cost effective to make too many different designs for the multitudes of different packs. Those Orion humps are a consensus waste of precious space and with them you miss the oportunity to drop your COG because there is little weight from the carbon. Alot of people just sand them off since they cant REALLY hold the battery safely under impact. Many prefer to jump up to the 5000 series packs that carry more weight if you have the room, they in theory should carry more punch later in the race as well.
I'll look into the additional space your talking about, because that can drop COG for sure, and Cyclone populatity is growing from what I'm hearing.
Verndog is offline
Old 05-31-2009, 05:03 AM
  #244
k_bojar's Avatar
Trader Rating: 30 (100%+)
WHat do you recommend for guys running the packs with the little humps on the bottom side?
k_bojar is offline
Old 05-31-2009, 05:23 PM
  #245
Verndog's Avatar
Most people are grinding those humps off when using a base plate. They will not hold the battery well enough under hard collision, and waste the oportunity to lower the COG by getting weight inside the chassis slots. I have seen a base plate out there that has cuttouts for the humps, but then you need to thicken the plate, or add more weight somewhere else to make up for that loss, and again raise the COG.
That said, if its a TC5 and something like an Orion / Trinity 3800, that can fit onto a PPD plate and under the top deck without removing humps if it bothers you.
Verndog is offline
Old 05-31-2009, 07:42 PM
  #246
k_bojar's Avatar
I was kind of afraid you'd say something like that...unfortunately griding off the humps is out of the question, since it 'alters' the case and illegal for most forms of racing
its for a 'standard' cyclone (non WCE and TC)
k_bojar is offline
Old 05-31-2009, 08:06 PM
  #247
Verndog's Avatar
I understand your position but take a look around. Many top level racers have removed the humps, and I've not heard of any disqualification. The end result is a case that is the same as those without humps, only now 20x stronger now that its fully protected with stainless steel. The newer 40c packs are flat bottom so this is becoming less of an issue so there is no plan to make cutout plates.
That said, here is a plate with cutouts from a competitor you may want to look at. Good Luck.
http://www.manutech.info/181101specs.html
Verndog is offline
Old 06-01-2009, 03:34 AM
  #248
k_bojar's Avatar
Thanks, Kevin - but knowing my luck, I'll be the one that gets caught
I've seen that plate before - but looking around to see what else is available
k_bojar is offline
Old 06-09-2009, 04:02 AM
  #249
Hoggy's Avatar
hey verndog just wondering when the 3.0 oz base weight will be available again.
let me know cheers
Hoggy is offline
Old 06-09-2009, 06:58 AM
  #250
trdsupra88's Avatar
Trader Rating: 25 (100%+)
Are these/were these made simply to get bigger packs in the car or is there a want/need to get more weight onto the tires too?
trdsupra88 is offline
Old 06-09-2009, 07:18 AM
  #251
Verndog's Avatar
let me know cheers
My apologies for the delay. I'm having trouble getting time sceduled into the shop right now, but hope to get them back in stock early next week. If you need them sooner then Nexus racing has them in stock as well.
http://www.nexusracing.com/index.php?cPath=137_154_293
To balance the car and to safely and securely mount lipo batteries is their main purpose.
Verndog is offline
Old 07-29-2009, 02:11 AM
  #252
espresso1967's Avatar
Trader Rating: 18 (100%+)
Anyone using the Diggity Wide lipo mounting brace (not the offset one) with ppd 3oz base and 2oz side weight? I am using the smc 5200 40c lipo and wanting to get my car balanced properly once my tekin rs pro arrives this week.
Will be using four scales to balance car out once esc arrives.
espresso1967 is offline
