Old 05-02-2008, 10:09 AM   #211
Verndog's Avatar
Trader Rating: 16 (100%+)
Originally Posted by SpidarX View Post
Are the base inserts sold separately, and could you attach them directly to the bottom of the lipo? I'm wanting to go to a lipo saddle pack, but I'm afraid the battery will slide around since it won't fit into the grooves made for the ni-mh cell. So I was thinking if i could attach those inserts, then that would secure the battery into the battery slots on the chasis.
Yes, inserts come in package of 6 and are attached seperately.
Here is the link, last item on page.
http://www.ppdbillet.com/RC_accessories.html
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 05-02-2008, 12:26 PM   #212
JCarr's Avatar
I have two TA05s one with the tub chassis and the other with the Penguin chassis. For the tub car the only thing that would work is the inserts? Also for the Penguin car will the 3.0 base weight work or would I use the 2.5 side weight stuck to the chassis?
JCarr is offline   Reply With Quote
Old 05-02-2008, 12:41 PM   #213
Verndog's Avatar
On the TA05 people were adding the 2.5oz weight into the chassis, then putting battery on top with the heavier 5000 mah packs, and 3.0 oz weight for the lighter 3600 packs and getting very close to balanced cars with just that. I dont know the difference between the Penguin and tub, I thought that this worked on all TA05's, so I'll need to check on the second part of your question.
---Team Hoarders---
Old 05-02-2008, 01:35 PM   #214
JCarr's Avatar
Thanks Vdog. The penguin chassis is a graphite chassis simular in layout to the TC5. I think I saw a few posts back that or8ital put one in his car and it worked, but I wasn't sure if it was the base or the side plate that he tried.
Old 05-02-2008, 02:34 PM   #215
Trader Rating: 38 (100%+)
I think it will fit if you remove a bit from the battery slots. It just barely doesnt fit or is a really tight fit if I remember correctly. I will try to fit it again tonight to see.
or8ital is offline   Reply With Quote
Old 05-02-2008, 03:00 PM   #216
JCarr's Avatar
Thank you.
Old 05-02-2008, 04:11 PM   #217
Maybell's Avatar
Kevin,
your going to have to pic up some issues of the new xtreme....theres a little piece with a pic of your lipo mount! congrats vernnndoggy!
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 05-02-2008, 04:25 PM   #218
JayBee's Avatar
Trader Rating: 31 (100%+)
Hey Kev,
Do we still have that 'potential project' on the table. The IIC (Vegas) is in August buddy
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 05-02-2008, 04:42 PM   #219
jdearhart's Avatar
Trader Rating: 15 (100%+)
Kevin,
Is the total weight for all six inserts 1.2 oz's, or does each one way 1.2 oz?
jdearhart is offline   Reply With Quote
Old 05-02-2008, 04:58 PM   #220
Verndog's Avatar
Originally Posted by Maybell View Post
Kevin,
Thanks captain...I'll check that out. Also recently made Ireland RC, they mounted channel out for some reason, but to each his own.
http://rcracingni.co.uk/wordpress/?p=393#more-393.
Jaybee...haven't forgot about my Shoey pals...just keepin busier then I like. I found some test material that will make prototype a bit cheaper...I need to get a chassis from you and label the required access holes.
---Team Hoarders---
Old 05-02-2008, 05:01 PM   #221
Verndog's Avatar
Originally Posted by jdearhart View Post
Kevin,
Total weight is 1.2oz, or .2oz per insert.
---Team Hoarders---
Old 05-02-2008, 05:05 PM   #222
JayBee's Avatar
I have it ALL ready for ya
Old 05-02-2008, 06:20 PM   #223
JCarr, it fits just fine. Not even close to being a tight fit. My memory must be slipping. The only problem I see is that, although its a nice upgrade, you will still be much slower then my TC5!
Verndog,
Any change of getting a lighter side plate? Im using the TC5 plate and my car is heavy to the battery side. Once I balance it on the electronics side Im overweight by about 20g.
Old 05-02-2008, 08:11 PM   #224
JCarr's Avatar
[QUOTE=or8ital;4409383]JCarr, it fits just fine. Not even close to being a tight fit. My memory must be slipping. The only problem I see is that, although its a nice upgrade, you will still be much slower then my TC5!
QUOTE] Thanx man Yeah your mind must be going if you think you're going to out run me. I think I will have to order a couple of these here in the next week or two.
Old 05-02-2008, 08:22 PM   #225
JCarr's Avatar
double post
Novak: 21.5 2s with 2s lipo: the lipo solution for the pan class? tomkelley Electric On-Road 16 08-18-2008 01:06 PM
CF TC5 LIPO Mounting Brace - Diggity Designs Diggity Electric On-Road 85 03-04-2008 11:54 PM
LIPO CHARGER LIKE HYPERION AND LIPO BATTS AND MAYBE CHEAP 12TH SCALE jslider R/C Items: Wanted to Buy 1 02-16-2008 07:55 AM
Pg 2 on Complete Sellout Motor rebuild Orion Lipo, peak Lipo 4800 and more gunlocators R/C Items: For Sale/Trade 18 10-08-2007 02:11 PM
Lipo regulator mounting? dsl Nitro Off-Road 4 09-22-2007 06:47 AM
