Old 03-17-2008, 08:00 PM   #196
Verndog's Avatar
Trader Rating: 16 (100%+)
Originally Posted by rezenclowd3 View Post
The PPD plate combined with the Diggity designs lipo holder is a great combo. Unfortunatly the lipo holder does not hold the Orion 3600 in, so I bought their 4800 instead, now it works like a champ, no need to tape anything in.
Actually I tested the Diggity brace with an Orion 3600 and you can get it to hold pretty well. I put a couple of my base inserts along the back edge of pack to take out the slop and it held real well. I'll give you 2 choices here. Buy another side weight for second battery and I'll throw in a pack of inserts for free to get it to fit...or sell me the 3600 cuz I need another to test on Xray 007.
Here is my test fit post...
http://www.rctech.net/forum/showpost...&postcount=167
Here are the base inserts.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 03-17-2008, 09:20 PM   #197
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
I have the base inserts, but dont quite follow you on your use with the 3600. A pic would be helpful. About the 3600, if you want it its yours. It has 1 race day, 4 charges on it. However an ejection from the car caused the case to have a gash in it, however not through the case. Ill provide a pic for you if you want.
BTW, guys at my track love the PPD stuff. Unfortunately most dont want to deal with removing the lead that has been secured by double sided foam tape. Ill keep working on them for you. And again, thanks for starting to fill the gap in a much needed market!
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 03-18-2008, 07:17 PM   #198
Verndog's Avatar
I dont have pics on the insert placement but basically bonded 3 lengthwise along the back edge to remove play. The Orion3600 has heavy raduised edge that combined with the useless humps gives some movement with the Diggity brace.
I ground the humps off the Orion I had and most of that play is now gone. I've seen some chowed packs from people trying to use those humps to keep the pack in...on hard impact = shifting pack in stock TC chassis. With the base plate I did a 360 flying roll 4ft high into wall and drove away...battery was unscathed.
Dont worry about converting your friends...they put alot of effort into taping on those lead weights...when they switch batteries, or get tired of looking at lead...they'll come around.
---Team Hoarders---
Old 03-27-2008, 08:49 PM   #199
Trader Rating: 32 (97%+)
verndog, ygpm
john "apple" mcintosh, Roar onroad national champion, Roar region 5 champion.
www.modxrc.com.com www.diggitydesigns.com www.rcproductdesigns.com
www.robinsonracing.com www.gsracing.com www.fioroni.com Apples paints
Apl Hed is offline   Reply With Quote
Old 03-28-2008, 10:13 AM   #200
verndog, ygapm.... you got another pm, lol.
Old 04-01-2008, 01:19 PM   #201
Default TC5 LIPO TRAY
sorry, pm'd you again.
thanx
Old 04-02-2008, 10:02 PM   #202
Verndog's Avatar
Here are a couple options for the T2 007 and 008. This is an Orion 3600 in a 007 US chassis...this fits with no top deck mods and minor relief in bulkhead. One pack has a carbon overlay on it, the other a stock 007 emblem over a blank, then the bright spot is the polished engraved Tru Balance..grab your shades.
---Team Hoarders---
Old 04-04-2008, 03:19 PM   #203
hey kev, just got my TC5 lipo tray, wow, beautiful workmanship, awsome peice. thanx agaijn, i hope to use it at the region 5 race this weekend. thanx again.
apple
Old 04-19-2008, 12:57 AM   #204
People at the track are starting to notice the ease of use these things have with lipo Thanks once again.
Old 04-19-2008, 12:20 PM   #205
I've got one of these 6000 lipos:
http://www.maxamps.com/Lipo-6000-74-Pack.htm
Do you think this would fit (tc5), perhaps with longer screws to bolt in? Thanks.
protocol_droid is offline   Reply With Quote
Old 04-19-2008, 04:41 PM   #206
Verndog's Avatar
That packs dimensions are 44mm X 137mm X 22mm , so yes the 3.0oz baseplate will work fine. Being as it is already 10.6 oz you would need no more then the 2.5oz side weight added to the baseplate, possibly a bit less. That will help protect the soft pack from impact as well.
---Team Hoarders---
Old 04-28-2008, 02:32 PM   #207
So I was finally able to weigh my TC5 using these weights. I only required 1 7g lead weight up front to get to weight using a new Checkpoint 5400 Lipo. I weighed in at 1526g, min weight was 1525. AWESOME!!
Old 04-29-2008, 04:00 AM   #208
Mini Toink's Avatar
Trader Rating: 30 (97%+)
Send a message via MSN to Mini Toink Send a message via Yahoo to Mini Toink Send a message via Skype™ to Mini Toink
Great product Kevin!
Here are some pictures of your product (Side plates and Base plates(Singles)) fitted on Orion 3600 in my T2'008 EU - 6 Cell
Enjoy the pics!
Toink
Xray T2'008 EU 6Cell
Hudy Pro Tools
AE 12R5
LRP : Orion : Sanwa (Airtronics) : Ko Propo : Spektrum
Mini Toink is offline   Reply With Quote
Old 04-29-2008, 12:53 PM   #209
Verndog's Avatar
Enjoy the pics!
Toink
Sweet! Nice job.
I just picked up a 007 EU chassis that I'll convert my US chassis to. IIRC the US took 3 of the 7 optional weights (+21g) inside the weight channel to balance. How much weight did the EU chassis require with the 3600??
---Team Hoarders---
Old 05-02-2008, 09:32 AM   #210
SpidarX's Avatar
Are the base inserts sold separately, and could you attach them directly to the bottom of the lipo? I'm wanting to go to a lipo saddle pack, but I'm afraid the battery will slide around since it won't fit into the grooves made for the ni-mh cell. So I was thinking if i could attach those inserts, then that would secure the battery into the battery slots on the chasis.
SpidarX is offline   Reply With Quote
Novak: 21.5 2s with 2s lipo: the lipo solution for the pan class? tomkelley Electric On-Road 16 08-18-2008 01:06 PM
CF TC5 LIPO Mounting Brace - Diggity Designs Diggity Electric On-Road 85 03-04-2008 11:54 PM
LIPO CHARGER LIKE HYPERION AND LIPO BATTS AND MAYBE CHEAP 12TH SCALE jslider R/C Items: Wanted to Buy 1 02-16-2008 07:55 AM
Pg 2 on Complete Sellout Motor rebuild Orion Lipo, peak Lipo 4800 and more gunlocators R/C Items: For Sale/Trade 18 10-08-2007 02:11 PM
Lipo regulator mounting? dsl Nitro Off-Road 4 09-22-2007 06:47 AM
