Old 02-11-2008, 10:39 PM   #151
JimmyMac's Avatar
double post.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 02-11-2008, 10:39 PM   #152
JimmyMac's Avatar
That sucks. The only lipo pack(s) what will fit the car no issues are the Orion 3200 and "maybe" the SMC 4000. I ran the 3200carbon packs in my MRE. The deep groove in the 3200 packs just slide under the rear bulkhead "humps". But you can not use the EZ-lipo plate on this car with that pack. The EZ-lipo plate "may" work with the SMC 4000 pack. What you could do is order the stick pack conversion kit for $100. It will give extra clearance. I can not guarantee it will solve your issues. You would need to ask this in the TRF415 thread. But it's worth a shot if you are "stuck" with this car and those packs. How much you buy the car for? I'm selling my MRE $220 shipped. Here is the kit.
http://shopping.rcmodel.hk/product_i...ducts_id=11080
TamiyaUSA web link
http://www.tamiyausa.com/product/ite...oduct-id=49436
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 02-13-2008, 07:16 PM   #153
Jamie007's Avatar
Default Oh Yeah!
First of all, Verndog is the man! Thanks for getting it to me so quickly!
I just got my lipo plate today and mounted up my new Maxamps 6000HV 2S2P. I am using their optional "skins" so I can mount the plates to the skin instead of the pack. I can now easily throw the pack into another vehicle without removing the servo tape from the plates. I had to trim the battery holder a tad so I could route the wires but no biggie. I also used a little electrical tape to hold the side plate secure, because the skins are a kinda of flimsy. I just drove my car for the first time with the lipo, and holy smokes what a difference! I highly recommend this setup to anyone!
PPD EZ-LiPo --TC5 and beyond LiPo mounting Solution.-lipo2.jpg   PPD EZ-LiPo --TC5 and beyond LiPo mounting Solution.-lipo3.jpg   PPD EZ-LiPo --TC5 and beyond LiPo mounting Solution.-lipo4.jpg
Jamie
Sparrowhawk XT, TC5, T4, SC10, Tek18X, Exotek R18, MGT Truggy
RC8E CC2200KV AE/RCM Conversion
RC8T CC2200KV AE Conversion
Jamie007 is offline   Reply With Quote
Old 02-13-2008, 08:39 PM   #154
Verndog's Avatar
Trader Rating: 16 (100%+)
Now there is a new idea! How much does that 6000 pack weigh? People that are converting are finding out what I did after alot of testing and playing with scales....proper weight placemant can make a difference.
Glad we could help with your solution...now....go have some awesome 1/2 hr. runs with that...and BTW, you'll now need a LiPo for your transmitter.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 02-13-2008, 09:30 PM   #155
Jamie007's Avatar
According to maxamps, its supposed to weigh 297g (10.6oz), I don't have the proper scales to test the balance of the car yet, but working on it.
Jamie
Old 02-13-2008, 10:27 PM   #156
Got mine today, thanks. I am little concerned about loosing the side piece though. It is not real solid with the servo tape i used. Especially since the 3600 can move a lot using the graphite hold down. Should i switch to taping them in? I also think i am going to epoxy the 2 pieces together just to be safe. Very good work though, i matches the cell cut outs perfect.
FT B44 - FT J82
LRP TC SPHERE - Futaba Fasst
Orion Lipo & Vortex motors
" Go that way really fast, if something gets in your way, turn"
tcmerf is offline   Reply With Quote
Old 02-13-2008, 10:32 PM   #157
JayBee's Avatar
Trader Rating: 31 (100%+)
Just put Shoe-goo on the side piece...clean both surfaces well and put dabs of goo on both parts to be safe.
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 02-13-2008, 10:38 PM   #158
There you go. Dont know why i did not think of that!
FT B44 - FT J82
Old 02-13-2008, 11:13 PM   #159
Verndog's Avatar
I'm not sure which plate you got, was it the flat 2.5 or the universal 3.0 -4.75 ? In either case, with the Orion type that is curved, put a thin strip on top and bottom edge leaving the center more open. Do that at each end and the center. Good servo tape will not come of if both surfaces are clean prior to bonding. In fact you should have a bit of a tough time removing it.
AS JB pointed out a bit of Shoe Goo could add security, but I've seen an Orion pack taped that was quite secure.
Also, the base plate should be secured to the bottom of the battery, and you'll have zero movement.
Use double thick servo tape between the humps, per directions...should be very secure when done this way.
---Team Hoarders---
Old 02-13-2008, 11:24 PM   #160
Verndog's Avatar
Not sure about your electronics, but money says your well within 1oz.
---Team Hoarders---
Old 02-13-2008, 11:59 PM   #161
Actually i am trying not to mount them to the battery. I misunderstood the instruction i think and mounted the side place to the bottom plate. In any case that way i dont have to do anything when i switch packs out. I like the shoe goo idea and dont really think the plate even needs to be mounted to the chassis, its fits the slots that well.
FT B44 - FT J82
Old 02-14-2008, 02:11 AM   #162
Insane's Avatar
Got my side plates yesterday, WOW they look good. Plus extra protection for my lipo's. More people in my area will be buying them for sure. Verndog you do grate work.
Insane is offline   Reply With Quote
Old 02-14-2008, 06:41 PM   #163
Rommel's Avatar
Got mine today, thx Verndog! Well done man
Rommel is offline   Reply With Quote
Old 02-15-2008, 12:12 AM   #164
JimmyMac's Avatar
Holy cow! You rally racing that thing! That car is Dirty!!
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 02-15-2008, 06:44 AM   #165
Gain Time's Avatar
Verndog is the man. You gotta get one of these. I will take pics of mine once I get them installed tonight. I have the need to swap LiPo packs between heats. Our racetrack runs a tight ship and on the nights we run our club races there is not enough time between heats to recharge the battery.
So what i am going to try is some brass strap bent into an L shape. Servo tape 3 of those onto the bottom and side plate. To hold the battery from slipping I am going to use some self sticking hook and loop (velcro). Not sure if the graphite bar will fit over all of this so I may have to use battery strap to hold it all in.
I really love the pieces. This stuff is nicely done and is well worth the investment.
DON'T TAZE' ME BRO!!!!!!
Gain Time is offline   Reply With Quote
Novak: 21.5 2s with 2s lipo: the lipo solution for the pan class? tomkelley Electric On-Road 16 08-18-2008 01:06 PM
CF TC5 LIPO Mounting Brace - Diggity Designs Diggity Electric On-Road 85 03-04-2008 11:54 PM
LIPO CHARGER LIKE HYPERION AND LIPO BATTS AND MAYBE CHEAP 12TH SCALE jslider R/C Items: Wanted to Buy 1 02-16-2008 07:55 AM
Pg 2 on Complete Sellout Motor rebuild Orion Lipo, peak Lipo 4800 and more gunlocators R/C Items: For Sale/Trade 18 10-08-2007 02:11 PM
Lipo regulator mounting? dsl Nitro Off-Road 4 09-22-2007 06:47 AM
