Old 02-11-2008, 08:31 PM   #136
JayBee's Avatar
Trader Rating: 31 (100%+)
Originally Posted by Verndog View Post
Sorry...I dont "do purple".
Really though. I have some blanks coming that you can add your own emblem / decals on, should be done by Thursday...posssibly sooner. I cant possibly engrave all the different manufacturers as you know. There has to be some good sticker sheets out there that can do the custom job aren't there?
JB have you tried the inserts or base plate to see if either will clear without moding the bulkheads like Ritchie did??
I did but didn't want to mod my bulkheads. What worked for me though is just using (2) of your 'insert-less' side pieces on both sides of the case, and that happened to match my electronics side perfectly
I will take 4 of the blank 'insert-less' sidebars
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 02-11-2008, 08:32 PM   #137
JayBee's Avatar
Originally Posted by skypilot View Post
jaybee, your such a gober,, why engrave the plate that goes on the inside of the battery, no one will see it.
True......on both points
Old 02-11-2008, 08:34 PM   #138
Con
Will you ship to Canada??
Con is offline   Reply With Quote
Old 02-11-2008, 08:38 PM   #139
Rommel's Avatar
Never did ask Verndog, how does the side plate attach? Does it attach to base plate? May have been answered already but didn't bother to look
Rommel is offline   Reply With Quote
Old 02-11-2008, 08:44 PM   #140
Verndog's Avatar
Trader Rating: 16 (100%+)
That depends...are you on the French side of the war issue??
Really though...send me an email, and I'll have to get a shipping estimate. I'm trying to keep in US..but Canada should be no big.
[email protected]
Ritchie....it will take less weight to keep it outside...I recommend to try that, and the 1.2oz base inserts right on the Core. Am I gunna have to come over and do this myself!!??
Now...engrave with what again?? You talking about a vibro type engraver??
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 02-11-2008, 08:48 PM   #141
Verndog's Avatar
3 small strips servo tape at each end and center of battery, direct to the battery. Use much more and you'll have a hard time removing it someday.
---Team Hoarders---
Old 02-11-2008, 08:49 PM   #142
skypilot's Avatar
Trader Rating: 14 (100%+)
i was thinking about taking a blank side piece to a thropy shop and asking them to engrave it with thier engraver that they engrave the brass plates they put on thropys
skypilot is offline   Reply With Quote
Old 02-11-2008, 08:56 PM   #143
Verndog's Avatar
Not familiar with that type, I'm, actually doing a high speed rotary engrave on these with a CNC mill. But, they prob. have something like a "dot peen" type engraver that "pounds a series" of dots so small you cant hardly tell. If so yes, that will work fine. The series stainless I'm using is pretty machinable, but tolerant to corrosion.
---Team Hoarders---
Old 02-11-2008, 09:00 PM   #144
skypilot's Avatar
i'll have them give it a go, if it turns out like crap it goes to the inside or gets a nice brass plate put over it
Old 02-11-2008, 09:04 PM   #145
Verndog's Avatar
Or we can skim .005 from it to clean up again then add 1/4oz to the channel to make the weight back.
---Team Hoarders---
Old 02-11-2008, 09:32 PM   #146
arn671's Avatar
Trader Rating: 15 (100%+)
Default Lipo mounts in stock at SIR?
Hi Verndog, Considering going to Lipo, are the TC5 mounts available at SIR or should I order through your site? Thanks-Alvin
arn671 is offline   Reply With Quote
Old 02-11-2008, 09:44 PM   #147
JimmyMac's Avatar
Originally Posted by Travis S View Post
Anyone try this in the 415MRE or TA05? I really like the looks of this but not sure about the top deck clearance for the TRF415 MRE. I have orion 4800's if that makes a dif or not.
SPECS: Length: 5.4" (137.5mm)
Width: 1.8" (45mm)
Height: .91" (23mm)
Weight: 10oz (285g)
I am not sure if I need to go with the stainless steel inserts or if I can use this or not. Any advice before I put in my order?
Hey Travis, you need to learn to READ!!! Read my comments just above the pics!!! If you have any questions about the MRE, just ask me.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 02-11-2008, 09:45 PM   #148
JimmyMac's Avatar
Oh, and the 4800 will not fit a 415MRE. With or without the plate.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 02-11-2008, 10:09 PM   #149
Verndog's Avatar
Yes, they have the complete line there at SIR. Price should be very close to the same, difference being tax vs shipping about a wash. Anthony has a spot right behind register for them hanging on the wall, both he and Dan are familiar with them.
These make the switch to LiPo that much easier. I recomend the Trackpower 4900...fit, look, and feel of power are excellent...and they have those also.
---Team Hoarders---
Old 02-11-2008, 10:11 PM   #150
Travis S's Avatar
Trader Rating: 46 (100%+)
Originally Posted by JimmyMac View Post
This piece would also slide into my 415MRE if you dremel out clearance for the motor brace. However, the rear bulkhead and top deck may cause clearance issues with lipo packs.
This is what I read from you and it said it may cause so I wasn't sure...
This is bad news to hear since I just bought a used MRE (still being shipped) and have 2 Orion 4800's... What lipos fit in that car if any? The 4800's don't seem any bigger then a normal battery pack... Now I don't know what I am going to do.
Travis S is offline   Reply With Quote
Novak: 21.5 2s with 2s lipo: the lipo solution for the pan class? tomkelley Electric On-Road 16 08-18-2008 01:06 PM
CF TC5 LIPO Mounting Brace - Diggity Designs Diggity Electric On-Road 85 03-04-2008 11:54 PM
LIPO CHARGER LIKE HYPERION AND LIPO BATTS AND MAYBE CHEAP 12TH SCALE jslider R/C Items: Wanted to Buy 1 02-16-2008 07:55 AM
Pg 2 on Complete Sellout Motor rebuild Orion Lipo, peak Lipo 4800 and more gunlocators R/C Items: For Sale/Trade 18 10-08-2007 02:11 PM
Lipo regulator mounting? dsl Nitro Off-Road 4 09-22-2007 06:47 AM
