this is normal right.....?
ok since i blew my reciever and esc from plugging in the connectors wrong i had to get new ones....
so i did.. and i believe my TT01 works flawles...
so its normal for the car to be like impossible to reverse, in other words... 0.1 metre an hour? so really slow reversing?
also whne i accelerate its normal for the car to make like a squeaky noise?
thanks, youngage
thanks, youngage
Connectors
It doesn't sound like you are using dean plugs. If not do yourself a favour and get some. You cant connect them wrong and they last very well and are very low resistence.
The other stuff could be many different things so I will leave it to someone with more experience to help you.
Terry
Terry
no but thing is the car runs well but cant reverse
it can but extremely slow.
every thing you mentioned wasn't normal,
what esc, motor and controller you have?
and what pinion and gear you put to your car?
i have the stock motor
and the taser dynamite 12 turn esc...
everything is stock...
controller meaning?....dx2...?
pinion everything is stock
make sure you set the endpoints right on the speed controll, otherwise it could be doing what you describe. go back and set them again to be sure
ok setting endpoints you mean by setting the esc up all over again?
so like reseting it all?
i will have to set the radio and reciever and esc right?
Just reset the radio to the esc, that'd be the first place i start
radio to esc...?
the reciever?
i might as well reset it all no?
the reciever?
