Old 06-21-2003, 07:34 AM   #1
Default Futaba 3pk HRS receiver and non digital servos
Is there asolution to use standard servos with the HRS reveiver?
I suppouse that you can use HRS with standard servos.
Thanx a lot!!!
martinm is offline   Reply With Quote
Old 06-21-2003, 10:25 AM   #2
dtm
dtm's Avatar
Send a message via ICQ to dtm
The manual specifically says not to use a non-digital servo with the HRS RX.....you can take the risk of frying both your reciever and servo.....
dtm is offline   Reply With Quote
Old 06-21-2003, 12:34 PM   #3
Registered User
Never use standard servo with HRS. You can tried it. Let us know how things happen.
Aku-Man is offline   Reply With Quote
Old 06-21-2003, 08:04 PM   #4
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I tried it, figured it was worth a shot. Basically it was like a glitch machine, imagine the worst glitching you've ever had, x 10.
Old 06-22-2003, 12:55 PM   #5
Accord's Avatar
Send a message via AIM to Accord
I tried it with a crappy old 3003 servo a few weeks ago just to see what would happen. The servo wasn't responsive at all and it's movements were very erratic, you could also hear it making a ton of noise like the internals were all going in different directions. It also glitched like all hell broke loose, when I shut it off and turned it on again, the servo didn't work anymore. By Futaba saying not to use analog servos in HRS mode, they're not joking around, IF YOU USE AN ANALOG SERVO IN HRS MODE YOU WILL FRY IT, plain and simple, there is no way around it.
Accord is offline   Reply With Quote
Old 06-22-2003, 06:39 PM   #6
The sampling rate of analog servos is too slow for the HRS. Analog servos sample at a rate of 30 pulses per second whereas digital servos sampling rate is close to 300 pulses per second.
AreCee is offline   Reply With Quote
Old 06-22-2003, 10:25 PM   #7
I didn't fry the servos, they just didn't work with HRS mode, they work fine with a regular radio still though.
Old 06-23-2003, 02:37 AM   #8
GTO2's Avatar
R/C Tech Charter Subscriber
Would other rx (ppm/fm123 for eg.) work fine with 3PK besides the HRS and the PCM?
GTO2 is offline   Reply With Quote
Old 06-23-2003, 06:40 AM   #9
Yes. Be sure to use the correct crystal for the Rx and that it matches the Tx crystal.
Old 06-23-2003, 06:44 AM   #10
dtm
dtm's Avatar
I have used KO and Sanwa (Airtronics) FM RX with my 3PK with no problems. @40mhz I even use KO crystals (matched sets)...again no problems.
Old 06-23-2003, 07:09 AM   #11
Trader Rating: 69 (100%+)
im using the hrs receiver that came with the 3PK as well as the ff. receivers with no problems (40mhz):
1024PCM, R123F (FM), R114F (FM) Note: the R114F is a 4-channel microservo (about 1/2 the size of the R123F) that was intended for airplane use, i think, bec. of the very long antenna wire
marvi is offline   Reply With Quote
Old 06-25-2003, 12:49 PM   #12
GTO2's Avatar
Thanks for the reps.
One more question: Would Tx have a same power over any freq on its band? Say I got it of factory at Ch63 (40MHz) would it have certain loss/damaging effect if I operate it at Ch80 (abt 500kHz difference)? TIA.
Old 06-25-2003, 08:53 PM   #13
dtm
dtm's Avatar
No loss what so ever. The KO RX do not come with any crystals when new. I think Futaba simply stick a crystal in their RX to fill in the hole .....I've never managed to find a band that I am using.....
FS: Futaba 9450 Digital Servos and PCM Receiver STi R/C Items: For Sale/Trade 11 08-19-2008 06:25 AM
futaba digital servos aussies1129 Australia For Sale/Trade 5 07-21-2008 02:11 PM
FS -Digital Servos and Spektrum SR3001 PRO receiver Omarko Australia For Sale/Trade 3 04-28-2008 02:47 AM
FUTABA Servos Digital Brushless BLS451 and Digital S9351 SCUBA STEVE R/C Items: For Sale/Trade 8 11-11-2007 06:18 PM
Brand New Futaba Digital Servos and HRS High Speed FM Receiver For Sale racer rich R/C Items: For Sale/Trade 10 02-22-2005 10:48 AM
