Old 01-27-2008, 07:05 PM   #361
i hope they come out fast because u need ll the C u can get so that way u can get out of my way
Originally Posted by yyhayyim View Post
Not if I get my hands on these puppies, first!!!
iceman76 is offline   Reply With Quote
Old 01-27-2008, 07:11 PM   #362
Company Representative
Danny/SMC's Avatar
The casing molds are undergoing some slight changes and if there is no complications they will be available by the end of February.
Danny/SMC is offline   Reply With Quote
Old 01-27-2008, 07:17 PM   #363
OK where are they going to be sold at i see u have some batterys on tower also whats the street price going to be for the 5000
Old 01-27-2008, 07:31 PM   #364
Danny/SMC's Avatar
The major distributors carry our line so any local track or shop will be able to get them. If you want to buy online my guess would be Stormer Hobbies would be the first to get them as they always order our new products before they are available.
As far as street price we hope to offer them at the same price as our current 22C/5000 pack.
Old 01-27-2008, 09:44 PM   #365
oXYnary's Avatar
Send a message via AIM to oXYnary Send a message via Yahoo to oXYnary
Does this mean it wont be totally sealed versus taped to allow the cell to expand if something does go wrong?
oXYnary is offline   Reply With Quote
Old 01-27-2008, 10:02 PM   #366
Danny/SMC's Avatar
I'm not sure what your getting at. Our case will be like the picture posted in my first post on page one. It will glued together as we need to make sure it holds up to the ROAR drop test.
Old 01-28-2008, 01:02 AM   #367
We will look into this but I don't think we can offer a cheaper pack than Orion as the materials used in our packs are very expensive.
Hi Danny, If SMC have a better pack then orion I don't mind the slightly higher pricing though.
Ben.C is offline   Reply With Quote
Old 01-28-2008, 02:39 AM   #368
oXYnary's Avatar
Purposely overcharge and/or short circuit one while recording with a video camera (Camera behind some plexiglass of course). So we can see how when the lipo starts puffing up, and is blocked by the case, will it make the resulting fire more dangerous when it finally builds enough pressure to break the glue (small backdraft)?
It would be a interesting result in either case, and if it doesn't create much more damage than normal, then you should be A-ok, but otherwise it might show an area that needs to be resolved while the cases are being redesigned. Allowing us to see the results via youtube or the like will help with keeping good communication with your customer base.
The idea behind taped cases as the other companies will tell you is to allow a pack that is expanding to pop open relieving the pressure and giving a visual cue that something is seriously wrong. Its also partially why before this hard case ROAR debate/point, lipos were only heatshrunk.
Consider this also, tape will allow some flex (depending on type). Which means for the ROAR drop, and subsequent pit drop by users, it could help absorb some of the impact. Versus a glued hard case with no stress/relief points.
Old 01-28-2008, 09:11 AM   #369
Danny/SMC's Avatar
Our current 22C/5000 pack already outperforms the Orion 4800 pack and is priced slightly lower. The extra voltage and lower IR of our new packs while being at the same or similar price should be welcomed by most.
Old 01-28-2008, 09:20 AM   #370
Danny/SMC's Avatar
Most tracks and now ROAR rules mention that a pack needs to be in a hardcase so we have created a hardcase that will work for these rules. I'm not sure what can or will happen if a cell has a failure but with the ROAR rules packs should be charged in a Lipo Sack so this should take care of potential issues. Since the casing is made of plastic that is fairly thin I think you would see it get deformed if a cell would swell.
Old 01-28-2008, 09:48 AM   #371
Trader Rating: 38 (100%+)
Danny, I think most people are use to seeing the Orion packs which are not glued together (so they can swell). The two halves of the case are double-sided taped to the cells. It allows the case to protect it with a hard impact but at the same time allows the pack to swell without interference if there is a problem.
or8ital is offline   Reply With Quote
Old 01-28-2008, 10:08 AM   #372
oXYnary's Avatar
Forgive me if I'm wrong, but the hard case is in part is designed for in use abuse. Not charging. If something short circuits? The car stops and a marshall picks it up while this is happening?
Orbital states above to help you understand. I actually am a bit surprised you haven't done a test run of the safety feature of your hardcase. I'm sure you guys can swallow one blown up pack and the film to tape it on.
Old 01-28-2008, 10:26 AM   #373
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Oh comon man! You just want to see death and dismemberment. Or otherwise blaitent misuse of a battery for your personal entertainment.
Heres an idea.. take your old cells (ni-mh) and overcharge them to explosion ! Now record that and show what REAL damage can be done.
John St.Amant is offline   Reply With Quote
Old 01-28-2008, 11:00 AM   #374
Danny/SMC's Avatar
We use cells that will meet the ROAR tests and rules. If that isn't good enough for some of you then keep using/buying what you feel is best for you. It's impossible to please everyone on every detail. Our goal is to sell high performance Lipos for the racers and we are making them within the rules.
Old 01-28-2008, 11:05 AM   #375
oXYnary's Avatar
I was simply trying to help out with a detail. Something that could help to show innocence in case something ever did go wrong and someone was hurt (lawsuits).
SMC 4100 and 5200 Hardcase 7.4V 24C Lipos Danny/SMC Electric On-Road 90 04-05-2009 10:55 AM
SMC 4000 mah Hardcase Lipos 28C NIB rraden R/C Items: For Sale/Trade 11 09-12-2008 11:20 AM
SMC Lipos 7.4 5000mah wfdfiremedic Electric On-Road 624 08-27-2008 10:09 AM
New SMC Lipos 7.4v 2s 4000 and 5000mah HardCase IOwNMkeG R/C Items: For Sale/Trade 4 03-30-2008 01:54 PM
new maxamps 4000mah 7.4v Lipos $75 aussiebuddha Australia For Sale/Trade 2 02-01-2007 04:08 PM
