Old 01-23-2008, 07:55 AM   #316
Trader Rating: 38 (100%+)
Originally Posted by raffaelli View Post
Someone at my track plugged the connectors in reversed and boom. I would suggest updating the connectors so they can't be reversed.
Lipos dont go boom. I witnessed recently (and heard about recently) of 2 different people hooking their Orion packs up backwards. Both just caused the pack to be unusable (from the fuse). One of them the ESC started smoking. I have my leads cut to make hooking them up backwards impossible. For this reason the Orion design seems a bit flawed. On the other hand when you have the wires coming out then when someone goes to change the plugs if they arent careful they could possibly short the pack.
or8ital is offline   Reply With Quote
Old 01-23-2008, 07:57 AM   #317
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Post
Originally Posted by Jack Rimer View Post
The resistence is in the circuit board inside the pack, not the plugs.
Concider the # of connections... and the circuit board is sufficient conductor on its surface to allow proper current flow. And from the pac i had appart the board was only there to hold the barrel in position. Also concider the surface area in which each connector has. Something tells me I'm going to have to post a picture of my car to make a point. But lets just say that less wire (no matter what guage) and the fewer connections, the better!!
John St.Amant is offline   Reply With Quote
Old 01-23-2008, 08:00 AM   #318
Post
Concider the # of connections... and the circuit board is sufficient conductor on its surface to allow proper current flow. And from the pac I had apart the board was only there to hold the barrel in position. Also concider the surface area in which each connector has. Something tells me I'm going to have to post a picture of my car to make a point. But lets just say that less wire (no matter what guage) and the fewer connections, the better!!
Old 01-23-2008, 08:06 AM   #319
Old 01-23-2008, 08:28 AM   #320
raffaelli's Avatar
Originally Posted by STLNLST View Post
that would be great or the buyers could just pay attention to the (+) and (-) markings on the battery.
HA! Thats what we all told him. But, he said that the pattern of the carbon fiber dashes on his 3600 make him think it was correct.
24ITA
raffaelli is offline   Reply With Quote
Old 01-23-2008, 08:33 AM   #321
raffaelli's Avatar
The boom I was refering to is sound of the fuse.
At the track I race at, most people are in a transition phase from MH to Lipo, including myself. So, to be able to run both, they have leads from the speedo to deans, then to the barrel connectors to the battery, redundant, but necessary.
24ITA
Old 01-23-2008, 09:20 AM   #322
Say what you want .. i love my lipos.. no more bs!!
waiting for saddle packs for my 501x and 12th cars...
and I have seen round cells explode.. in person... not mine , but none the less... violent! I was hit by a casing>>> not fun!
Old 01-23-2008, 09:42 AM   #323
raffaelli's Avatar
Agreed!
24ITA
Old 01-23-2008, 09:47 AM   #324
Send a message via AIM to Dawn Sanchez
Agreed!
Raffaelli?????? Posting???????? Is he still around???????? What?????? Are my eyes deceiving me??
Hi Chris...
Dawn Sanchez is offline   Reply With Quote
Old 01-23-2008, 09:54 AM   #325
m3ndo5a's Avatar
Skip.
m3ndo5a is offline   Reply With Quote
Old 01-23-2008, 10:16 AM   #326
Company Representative
Danny/SMC's Avatar
Originally Posted by Joel Lagace View Post
Maybe you should make some post in french!
Back to the topic of this thread...
-what are the weight and dimentions of these packs, what will fit in the new bread of TC's?
-Is there room to push that balancing port wire stuff back into the case?
-Can the case be opened and closed?
-Whats the estimated street price?
-if fitment is not an issue does one pack put out more performance then the other in a typical 5-6minute run?
Thanks for the info..
Dimensions of the prototypes posted on the previous page.
I will have the weight once we get the samples in whichn should hopefully by the end of this week. The 4000 should fit in all sedans easily. The 5000 will require some fitting or possibly aftermarket chassis/top deck.
Not sure about the balancing port being able to be pushed back inside.
The case will be glued so I would say it can't be opened. Which I don't see a need to open it anyway.
Street price should be about very close to our current 22C pack.
The 5000 will have a bit better performance as cell size makes for more performance. I will have the data as soon as I get our first samples.
We hope to have them available by the end of February.
Danny/SMC is offline   Reply With Quote
Old 01-23-2008, 10:32 AM   #327
jag88's Avatar
So will all soft pack Lipos be discontinued ?
jag88 is offline   Reply With Quote
Old 01-23-2008, 10:53 AM   #328
soft packs are for helis and planes! so that wont happen..
but as far as cars go?
yes!!!
Old 01-23-2008, 10:53 AM   #329
If the pack is glued together, will there be room for the cells to expand if there is a problem? I know Orion doesnt glue their's together for that reason.
Old 01-23-2008, 10:59 AM   #330
raffaelli's Avatar
I have seen the hard cases pop open during touring on carpet racing after impact. We took at look at how it was hald together. Seemed like there were small non-locking tabs with CA on them. Can they be molded to actually lock together? Maybe a couple of small screws?
24ITA
SMC 4100 and 5200 Hardcase 7.4V 24C Lipos Danny/SMC Electric On-Road 90 04-05-2009 10:55 AM
SMC 4000 mah Hardcase Lipos 28C NIB rraden R/C Items: For Sale/Trade 11 09-12-2008 11:20 AM
SMC Lipos 7.4 5000mah wfdfiremedic Electric On-Road 624 08-27-2008 10:09 AM
New SMC Lipos 7.4v 2s 4000 and 5000mah HardCase IOwNMkeG R/C Items: For Sale/Trade 4 03-30-2008 01:54 PM
new maxamps 4000mah 7.4v Lipos $75 aussiebuddha Australia For Sale/Trade 2 02-01-2007 04:08 PM
