SMC 28C High Performance 4000mAh - 5000mAh Hardcase Lipos
#181
wouldn't posting to look for overcharging at your local track be good enough?
Well this is the same company that kept pimping the batch of IB's that were blowing up and kept their ground that there was a compromise to get the best performance instead of working to straighten out the manufacturer and letting them know that thier batts are not safe.
#182
I think your analogy is a little off. This is more like a drug dealer and the manufacturer. You make the drug, but give it to someone else to sell. To top that off, someone went a step further and told everyone how to abuse it....
While Danny and yourself did not post the knowledge on how to abuse/overcharge LiPo's, we've seen Danny post many times that LiPo's have to be cycled and discharged at high-amp loads to attain best performance.
I know in the day of the internet, there is no way to keep this information hidden, but to have someone post the info and poison this thread about when it is supposed to be for a new SMC product announcement, justs sucks.
If I were you (I have a habit of offering advice), I would ask RCTech to lock and/or remove this thread, and then pressure your web developers more and get your product information posted on your newly updated website, mucho pronto....
#183
Jack and Danny,
I think all of us appreciate knowing the information about overcharging, that is good to know (so we don't do it). The issue is the step by step instructions and then Danny saying Lipo's aren't that great so he didn't want the post deleted.
When all hell broke loose he kept saying how overcharging was bad, don't do it (but somebody will) but deep cycle is good. Damage was done by then.
I won't overcharge but I will cycle mine if Danny says it will make them faster, thanks Danny for the information.
See how easy that is.
#185
1) If I catch anyone abusing their LiPo packs by overcharging them, I will report him/her to the owner and he/she will be escorted off the premises.
2) A couple of factory drivers are using LiPo at the local track and they use the same routine that I do: 1) Fully charge the battery at home using cc/cv mode. 2) After running the battery, use the cc/cv mode at the track and pull the battery off the charger once it reaches 8.4 volts and cv mode kicks in. 3) Repeat step 2 after every race and after you're done racing. This will allow you to get hundreds of cycles out of your pack and it's how the "pros" maintain their packs.
3) Most of the LiPo information provided by SMC reps on this thread is either unsubstantiated or downright wrong. Consequently, I will not recommend SMC packs to LiPo noobs and I will tell everyone to disregard anything SMC has to say about LiPo. Maybe they should stick to making nickel grenades...
#186
2) If you disregard what is stated here you are only burying your head in the sand. You need to realize that people are doing this NOW and be part of the solution instead of blaming SMC.
3) We never "made" anything. See my previous post to get set straight.
#187
Jack, since Tony isnt associated with SMC in any way, you should ask him to remove your name from his signature to prevent tarnishing your good name. I guess the confusion came when people suspected he was sponsored by SMC based on his signature.
#188
Maybe requiring a good Lipo Sack is in order.
#189
Curious, I'm unfamiliar with the CE Lipo Update (not that I would want such a overpriced piece of fluff). Was this done in conjunction with a balancing mode? Did you compare a balance regular charge/discharge against it?
What I find confusing is Lipos have been in other parts of the hobbies for years now, yet now suddenly in the car section this overcharging method is discovered? Shouldn' this have cropped up by now in example racing aircraft? Or with Major Lipo Brands such as Kokam or Thunder Power?
The Cats out of the bag either way, and I don't believe censoring what was posted was/is the answer. Giving substantial scientific process proof (no comparisons to other charge methods/chargers given) would go along way one way or another.
#190
Curious, I'm unfamiliar with the CE Lipo Update (not that I would want such a overpriced piece of fluff). Was this done in conjunction with a balancing mode? No, I do not feel balancing helps in stock, 19, 17.5, or 13.5 racing. We're not hitting the pack very hard to off-balance the cells. In mod high drain/load conditions balancing should be done. Did you compare a balance regular charge/discharge against it? No, I do not own a balancer.
#191
First off, Jack/Danny... If you haven't noticed through the whole thread everyone reads right past your posts and continues attacking so don't worry about it and don't waiste your time. ROAR knows, EFRA knows, IFMAR knows and now be it this thread most other tracks, hobby shops and racers know.
I will admit that I didn't know anything about this until I read this thread this morning. We have a few guys that are die-hard r/c tech info guys and I will definatly check them out on the club races because there has been a majical .2-.3 per lap that comes out during racing (90% of our track is lipo users) compared to practice lap times.
From my personal use - A friend of mine has two cars that he uses and lets me use from time to time to club race with lipo and if anyone thinks that they always run the same reguardless of what you do you are extremely mistaken. If you want me to post the lap times from runs with a pack that sat for a week with 50-75% charge that was just topped off vs. the pack that he had ran 6-7 times that day then I can.... The difference for me was .2-.3 per lap and the overall run was over a lap difference (this was in 10.5 BL TC w/foam tires).... Two packs, same company, same ratings..... All packs were charged with the Orion Avionics charger (no crazy methods) with a balancer.....
#192
#193
Thanks for the reply. Curious, if you don't own a balancer, how can you make that decision about its effects one way or another?
