Old 01-20-2008, 12:47 AM   #16
fathead's Avatar
Originally Posted by JevUK View Post
All I've got is a robotrinic and novak gtb. Do you know what esc they used?
I used a Robitronic with my GTB & 6.5 and it worked fine.
Slavich Design
fathead is offline   Reply With Quote
Old 01-20-2008, 06:22 AM   #17
JevUK's Avatar
Ok I got it working! Turns out it didn't like running from a mains 12v power supply.
Then receiver pack went flat, doh
Next problem is the software does not let me save graph so I have to do a screen print . The link to robitronics order page does not work.
People spend all that money on the hardware and they want even more for the software sheeesh
This is going to be great for comparing esc. I hear people saying one speed is faster than another and with this setup you can find out for sure.
Bring it on!
JevUK is offline   Reply With Quote
Old 01-20-2008, 07:20 AM   #18
In a sense most of the timing is controlled by the ESC and its profiles, so it is just as important to use the same ESC on the dyno as on the car.
"we need to do at least 11.2 km/s to break earths orbit or almost the speed as Cam's car"
Neil Armstrong 1968
Cammer is offline   Reply With Quote
Old 01-20-2008, 07:53 AM   #19
JevUK's Avatar
99.8% effeciency
That can't be right.
Old 01-20-2008, 08:40 AM   #20
JevUK's Avatar
That was a Novak 8.5 with 12.3mm sintered rotor. There was a 70 amp limit.
Here is my 10.5 with 12.3mm sintered. Now with 100 amp limit.
Old 01-20-2008, 08:46 AM   #21
gacjr0's Avatar
Trader Rating: 15 (100%+)
Nice job,
Why the current limiting?
Thanks for posting these.
gacjr0 is offline   Reply With Quote
Old 01-20-2008, 09:04 AM   #22
sosidge's Avatar
Looks like Robitronic need to rewrite their software to graph efficiencies over 90%!
I'm also quite surprised at the near 100% efficieny of the first motor, perhaps there really is a sweet spot in the power band that is that efficient? Or perhaps is related to your setup with an external ESC driving the motor.
Old 01-20-2008, 09:38 AM   #23
JevUK's Avatar
Originally Posted by gacjr0 View Post
Nice job,
You're welcome, I wish I had other 10.5's to test and other esc's.
I had the amp limit low at first because I was wary of blowing something up. I forgot to try the 8.5 with a higher amp limit.
The 10.5 graph started below 100 amps so that was fine.
I do have an old supersport esc I could test.
The fact the effeciency went off graph the scale did make me chuckle . I don't think there is anyway I can have it go to 100%.
Not too important because the peak efficiency is way higher than the peak power.
For 17.5,13.5 and 10.5 I don't suppose efficiency is going to be much of a worry, especially with lipo's.
Old 01-20-2008, 10:23 AM   #24
JevUK's Avatar
Here is the same motor but using an old Novak Supersport Esc. Please bare in mind this esc had been repaired by a friend as the fets had become unsoldered. I do not know if it has impacted the performance or not.
Old 01-20-2008, 10:52 AM   #25
RussB's Avatar
Send a message via MSN to RussB
could you post a 13.5 with the standard rotor and that same 13.5 with the big rotor? if you have the stuff.
RussB is offline   Reply With Quote
Old 01-20-2008, 12:09 PM   #26
JevUK's Avatar
Sorry Russ I don't have a 13.5 motor or 13mm rotor.
If anyone wants to lend me one I would be happy to test it
Or alternatively someone could do the same test with a gtb and 13.5 if they have the gear.
I tell you what, how about a dyno thread as a sticky?
MRT, Novak, Spektrum, Sanwa, Tamiya, Alleven RC, Maxamps, CheapBatteryPacks, Duratrax Ice, Pro Peak PSU, Nuova Faor, McLarney Racing, Futaba, KO Propo, Team Associated, Enerland.
Old 01-22-2008, 06:17 PM   #27
Bring it on!
Jev we await the test results..
Expect you'll come up with some interesting findings.. like showing up the ESC's lacking in the FET department, our top brushed MX has almost as many FETs as some top 'racing' BL speedo's (from what I've heard).. you can't beat a decent number of high-end MOSFETs, plus a well designed pcb with the lowest resistance tracks etc. Having said that it's what works best on the track, speed is good but it needs to be speed with good control, especially when it comes to racing.
Terry_S is offline   Reply With Quote
Old 01-23-2008, 02:46 AM   #28
JevUK's Avatar
Hi Terry.
Well I'm suprised people have not used this method to compare brushed esc's in the past. .
You can already see how much better the GTB is than the Supersport with a 10.5. 178w versus 154w, that's a 14% drop in peak power!
As I've got a spektrum receiver in the loop, I could even compare a 2.4ghz version of the gtb to a regular one
I know there is more to a motor and esc than just what these dyno plots show. But it takes away the randomness of track testing.
Once the spec brushless classes are in full swing we can get more feed back on how these dyno plots translate to on track performance.
Old 01-23-2008, 03:09 AM   #29
Back in the old days there used to be 'intensive' speedo testing, pushing them to their limits to see how they performed, don't seem to see it these days though.
It's good to see someone with technical knowledge and experience carrying out independent unbiased testing, it's worth a lot more to serious racers than the 'bigging up' from marketing.
Old 01-25-2008, 04:33 PM   #30
JevUK's Avatar
Thanks terry, I started up a thread in the electronics section.
http://www.rctech.net/forum/showthre...22#post4117222
Just put the results of Tims Orion 10.5 and Andys Novak 10.5
I need a 1/18 Brushed/Brushless Motor w/ESC Combo..Need ASAP smarking1212 Micro and Mini Scales 4 07-19-2008 07:55 PM
FS: Novak GTX esc, brushed motors, comm lathe, motor dyno mike williams R/C Items: For Sale/Trade 12 03-17-2008 04:26 PM
LRP 80500 sphere brushed/brushless with motor Tmachine R/C Items: For Sale/Trade 3 02-18-2008 11:59 PM
Motor: Brushed ..T = Brushless ....KV ? skyblueblue Singapore R/C Racers 20 06-12-2007 09:54 AM
WTB; Brushless or Brushed motor setup. NitroMaxx3.3 R/C Items: Wanted to Buy 1 09-09-2006 11:42 PM
