Old 01-19-2008, 12:10 PM   #16
RussB's Avatar
Send a message via MSN to RussB
3.9fdr for a sedan isn't that unreasonable... that's what we gear a 13.5 with a 13mm rotor around. heck, i've run a 13.5 with the standard rotor at 4.4 before with 0 problems. it was actually even cooler than usual at the end of the run.
RussB is offline   Reply With Quote
Old 01-19-2008, 12:16 PM   #17
odpurple's Avatar
Originally Posted by pokie View Post
OMG, is that adapter actually available?
Everything is available; the question is how much do you want it?
TOP Racing USA--OD Racing--Novak--Power Push--J Spec
odpurple is offline   Reply With Quote
Old 01-19-2008, 12:23 PM   #18
My TC is a direct drive w/IRS. It has a 17.5. Current gearing is 3.1 w/6cell nimh,wt. is 46oz. Am I in the ballpark? ( I've yet to run it, it's kinda cool outside-10 degrees) Thanks, Don
DLS II is offline   Reply With Quote
Old 01-19-2008, 12:39 PM   #19
Trader Rating: 45 (100%+)
So without using a fan on the motor when running the car on the track, what temperature is too hot for a B\L motor? Do you think a B\L motor can take more gear as long as it stays cool? I'm assuming running a fan on the motor will help alot?
Apex is offline   Reply With Quote
Old 01-19-2008, 12:53 PM   #20
HD-F1's Avatar
Trader Rating: 18 (100%+)
In my oval touring car I ran the novak 17.5 at the same final as a stock brushed motor. Motor was at 65 degrees at the end of 4 min. 9 teeth later I got the temp up to 140 degrees and it was gettin pretty quick then. From what I understand 170 degrees is about as hot as you wanna get these motors before it starts to eat the goodie out of the rotor. I'm no expert in it at all, this is just what I have been told and read. Gear them by temp? Xtremes article on BL motors said they had infinate torque just dont get them hot. Thats what I'm going with.
Heath
WWW.MAXAMPS.COM
WWW.HYPERDRIVERACING.COM
WWW.NITROKILLERS.COM
myspace.com/ballisticwhiplash01
COOPER MOTORSPORTS
HD-F1 is offline   Reply With Quote
Old 01-19-2008, 04:25 PM   #21
tpczx6's Avatar
OD I want one so I can gear my 1/12 76/76 I can make it fit I know I can if not please start working on a way to switch the gears in our cars
RcAmerica--Xray---Hudy----KO PROPO USA---ORCA---GRAVITY RC
Motiv------Apexrc----- AVID
SWEEP Racing USA
Mike's Hobbyshop in Dallas (RIP)
Nor-Cal Hobbies [The Race Place]
tpczx6 is offline   Reply With Quote
Old 01-19-2008, 04:36 PM   #22
odpurple's Avatar
I'll put the design team right on that!
Old 01-23-2008, 01:52 PM   #23
nashrcracer's Avatar
R/C Tech Charter Subscriber
got my 17.5 in from stormer now I just need to put it in a car and do some testing.
RC50 As you come into this world, something else is also born. You begin your life, and it begins a journey towards you. It moves slowly, but it never stops. Wherever you go, whatever path you take, it will follow never faster, never slower, always coming. You will run, it will walk. You will rest, it will not. One day, you will linger in the same place too long you will sit too still, or sleep too deep. And when, too late, you rise to go, you will notice a second shadow next to yours. Your life will then be over.
nashrcracer is offline   Reply With Quote
Old 01-23-2008, 03:34 PM   #24
Regional Moderator
Darkseid's Avatar
This past weekend, I ran my 17.5 in rubber tire at a fdr of 4.02. This left me with a rollout in the 49.25 range. The motor felt really good at this gearing, but the motor was very cool. It only tempt at like 120-130 degrees after a 5min race, including 3 or so practice laps. So I went up a tooth to put myself at 3.92 fdr and a rollout of about 50. This moved the motor temp up to about 134-135, but the motor felt very soft. No real punch to speak of.
Now, I went through a similar thing with the 13.5 when I ran that. When geared to a certain point, it lost its punch, but when geared past that, it hit a sweet spot in the rollout where it had both punch and top end.
So I'm wondering will the same hold true for the 17.5. I've reached the soft point, but still haven't made it to Novak's recommended heat for proper gearing. So I'm wondering if its time to try a fdr in the 3.8 range and a rollout in the 51 range, to get to that magic sweet spot like the 13.5 achieved.
I guess I'll try it this weekend.
TLR 22...Tamiya F104...
Old 01-23-2008, 03:51 PM   #25
ShaunMac's Avatar
Darkseid - What ESC are you using? NIMH or LIPO?
Were you running with any 27T racers? How did the 17.5 compare to the 27T?
Thanks for the info.
ShaunMac is offline   Reply With Quote
Old 01-23-2008, 04:19 PM   #26
Trader Rating: 139 (97%+)
Send a message via AIM to twistedone
I have been running a 17.5 novak motor at cefx in my tc for about a week im at 93 spur and 49 pinion with fdr of 3.80 in my tc5 good top speed and corners very well the faster drivers will do better with this and a avg is going to do great because it is controlable speed
nothing like a 13.5
I am also racing with 13.5 motors and in some cases beating them not on speed just on less crashes and more consistent lap times
twistedone is offline   Reply With Quote
Old 01-23-2008, 06:45 PM   #27
it would be hard pressed to get up to operating temp at our track right now it was 45 degrees in the track room and 60 in the pit room and this is only tennessee. that's the only thing bad about finding a temp to run at when you go otside in the sun it will get hotter and you 'll have to change the gear and slow down to keep the motor strong but not be as fast as you could be in the middle of a cold track in winter
Old 01-23-2008, 10:53 PM   #28
Trader Rating: 17 (100%+)
Send a message via AIM to Kave
Originally Posted by nashrcracer View Post
just trying to get a place started as the onslaught of questions arise.
I just ordered a novak 17.5
going to start out about a 3.0 or 76mm on my 12th scale
and probably 2.0 or 51mm on my touring
anybody been running them yet? or had access to the other companies.
On my 12th scale with a 13.5 this last weekend we ran 75mm rollout on a 95x48 track doing about 12.5 second lap times. If I had to guess I would assume 17.5 would be up into the high 80's
And Sedans forsure into the 50's
Kevin Van Ert | MFR | CRC Racing | Team Scream Racing | Hobbywing | Xenon USA | Dumpers Speed Shop | Genesis RC | Race Rewards | Lake Superior RC Car Club | www.lsrcc.com
Kave is offline   Reply With Quote
Old 01-23-2008, 11:27 PM   #29
odpurple's Avatar
yup, 85 to 90mm for 1/12th
Old 01-24-2008, 08:59 AM   #30
Regional Moderator
Darkseid's Avatar
I'm running LRP Sphere w/ Orion 3200 Lipo.
No, we weren't running with any 27t racers, our track has pretty much gone all BL for all classes. Except for TCS mini.
Official Tekin FX series thread(tekin support) Randy_Pike Radio and Electronics 50 09-01-2016 05:13 PM
tekin gearing? tino Micro and Mini Scales 0 06-24-2008 08:11 PM
12th scale gearing need help ASAP! cm367700 Electric On-Road 4 02-27-2008 08:33 PM
1/12th Scale Novak brushless gearing 17.5 noline Electric On-Road 2 02-12-2008 04:59 PM
F/S , Super Cheap Blowout: Orion V2 Touring 10x1 , GP3300 1.17V , Novak CYCLONE tunerjetta29 R/C Items: For Sale/Trade 17 11-23-2004 08:57 PM
