Old 01-16-2008, 08:18 PM   #1
jheimb4897's Avatar
Trader Rating: 1 (67%+)
Default Servo died. How to unglue it??????
I never glue servos, but in this case, the car was used. I was hooking upi my electrics and saw that the servo was glued. It's a Futaba low profile servo, don't know the model because the sticker came off. The thing is, I can't figure out how to unglue the servo from the chassis. It is carbon fiber, so I am not sure what is going to hurt it and what isn't. I don't want to break the servo because I would like to replace the innards. Someone please help!
I can walk backwards fast as you can, I can walk backwards fast as you can. I'm the backwards man, I'm the backwards man.
jheimb4897 is offline   Reply With Quote
Old 01-16-2008, 08:31 PM   #2
paul73rc's Avatar
Trader Rating: 5 (78%+)
Get a flat bladed screwdriver and put it inbetween the servo and carbon and turn it, it should pop off. Do it all around the servo, not just one side, it will make it easier. It shouldn't be too hard to get it off. Don't worry about damaging either, carbon is strong and the servo case is also fairly strong, you might just have a few scractches if you don't do it right.
paul73rc
paul73rc is offline   Reply With Quote
Old 01-16-2008, 09:03 PM   #3
AdrianM's Avatar
If it is glued with shoo goo just twist it hard and it will pop off. If some one CA'd it in place you are toast.
Adrian Martinez
Old 01-17-2008, 12:20 AM   #4
you could use a heat gun to gel up the glue used . while using a screw driver to pry the servo from the chassis .. make sure you dont use too much heat...
Mark Barden .
mb racer is offline   Reply With Quote
Old 01-17-2008, 03:01 AM   #5
Woz
get some de-bonder from your local hardware shoppy. works wonders at ungluing your hand from your mouse.
Woz is offline   Reply With Quote
Old 01-17-2008, 03:11 AM   #6
flameoutgarrett's Avatar
Send a message via MSN to flameoutgarrett
hobby shops that sell airplane stuff usually carry stuff to unglue ca, cant remember the actual name but it works great
Team fun-Www.rc-trim.com-Team Speedmerchant-Team Orca-Team Br00d
flameoutgarrett is offline   Reply With Quote
Old 01-17-2008, 03:16 AM   #7
Trader Rating: 16 (94%+)
BUT if that is CA Glue, the last thing you want is a heat source on it. CA fumes, especially when heated, could be deadly.
kn7671 is offline   Reply With Quote
Old 01-17-2008, 04:01 AM   #8
little man's Avatar
steam the chasis up side down to expose the servo to the heat ,when its ready it wi;; fall off this wont harm the carbon fibre or servo
let the servo dry out for a few days leave it open on a dry cloth
tamiya ta05,kyosho tf5,kyosho v1s,ansmann terrier,tamiya lunchbox,hpi cyber 10 b
I JUST WANT TO HAVE FUN ,NOW DAMM IT
little man is offline   Reply With Quote
Old 01-17-2008, 08:36 AM   #9
If it's CA, you can probably throw it into the freezer and cause the glue to crystallize. Then you can probably twist the servo and break it free.
Serzoni is offline   Reply With Quote
Old 01-17-2008, 10:04 AM   #10
SuperEk4's Avatar
Trader Rating: 32 (100%+)
the servo will spoil as it condenses.
Hobbywing-Acorn Racing-ManiaRC-UpgradeRC-Hong nor-Rc monster-Blackbeard-Rc-MoosDesign-SweepRacing-Boca bearings-Tresrey USA-Velociti raceware-Tekno Rc-Team J-JPL Models-SNR Graphite (RETIRED)
SuperEk4 is offline   Reply With Quote
Old 01-17-2008, 10:19 AM   #11
Just open the case and allow the servo to dry out before using it and there shouldn't be a problem. I thought the servo was dead, anyways?
Old 01-17-2008, 05:57 PM   #12
jheimb4897's Avatar
I want to send it back to Futaba. It is a 9550, so I don't want to spend another $70 when I can get it repaired for under $30. I got it unglued and it was shoe goo. I skateboard a lot, so I've got a bunch on hand. I seems to hold much better than tape.
Thanks a million guys!
My M8 died jspurgin Radio and Electronics 13 04-10-2008 10:39 PM
unglue tires?? lynell90 Nitro Off-Road 21 09-18-2007 08:02 AM
How to unglue..........glue? K_King Electric Off-Road 24 01-22-2007 01:36 PM
Unglue Tires? micros_rock Electric On-Road 9 08-07-2005 03:01 AM
how to Unglue, sloopy glued tires? tabarism Rookie Zone 12 05-03-2005 06:37 PM
