Old 01-20-2008, 05:23 PM   #196
ASM
ASM's Avatar
Trader Rating: 21 (100%+)
Adding 5 ounces is difficult enough and there's almost no place to put the weight but on the battery . It also helps keep the car balanced side to side as it was with the nimh's as well.
Scott Meeks
2016 & 2017 ROAR Region 4 VTA Champion
USVTA Member #116
ASM is offline   Reply With Quote
Old 01-21-2008, 12:15 AM   #197
JayBee's Avatar
Trader Rating: 31 (100%+)
Thanks for the support Syndrome; I think everyone posting on the subject is seeing the flaw with this ruling
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 01-21-2008, 12:24 AM   #198
syndr0me's Avatar
Trader Rating: 32 (100%+)
Hopefully ROAR will address the rule, or clarify it at least. I'd pretty much have to skip a ROAR event if I couldn't put weights on the battery, 'cause I'm not gonna buy a new car just to fit them on the chassis.
After some of the stuff I've seen in the SMC LiPo thread tonight, I'm feeling pretty exasperated over this whole LiPo thing. Maybe it's just shock. I hope we don't rue the day the unwashed masses joined us, 'cause it's starting to look ugly.
syndr0me is offline   Reply With Quote
Old 01-21-2008, 12:32 AM   #199
glassdoctor's Avatar
LOL... hope that doesn't happen, though it crossed my mind too, I admit.
glassdoctor is offline   Reply With Quote
Old 01-21-2008, 01:39 AM   #200
JimmyMac's Avatar
Can't please everyone. I know I'll be running brushless and lipo at the Roar Nats in June with my 416. Got it all figured out too for weight. At least on my car.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 01-21-2008, 02:48 AM   #201
JayBee's Avatar
This is an easy one to get right and please the MAJORITY brah
Old 01-21-2008, 03:19 AM   #202
you can always create a carbon fiber battery bar that's the same length and width of the battery itself and modify that to clear anything that makes up the centerline of the chassis.
Right there you'd have plenty of space to add weight.
Sabin is offline   Reply With Quote
Old 01-21-2008, 10:08 AM   #203
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
The Electric On Road Committee is evaluating solutions for this issue. Please be paitient, this rule is more problematic in TC, then it is in Off Road.
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 01-21-2008, 10:18 AM   #204
JayBee's Avatar
Nice to hear that Tim
Old 01-21-2008, 10:25 AM   #205
Send a message via AIM to Dawn Sanchez
This is sad to read.
Basically, the rule is there preventing people from adding weight for pre tech, removing it to race and then replacing for post tech. Adding to the battery is the easiest way to remove weight and re add it at the end of the run. The rule states mounted to the chassis as its not so easy to remove and replace with slight of hand.
If ROAR didn't do everything possible to insure fairness, can you just imagine the bashing at that point? C'mon... this is no easy task... as it wasn't easy getting to you BL rules and Lipo rules as the entire membership asked for....
Its a problem, yes.. and it is being addressed.
Dawn Sanchez is offline   Reply With Quote
Old 01-21-2008, 10:32 AM   #206
JayBee's Avatar
This is my method Dawn.... no amount of 'slight of hand' would accomplish what you're describing.
Old 01-21-2008, 10:45 AM   #207
asw7576's Avatar
Why don't check the car weight after each heat and each final ?
Pick 3 cars who finished 1, 2, 3, and 1 car at random. Those cars will be announced by race director and the drivers must present their car for weight inspection before going back to their desk.
Old 01-21-2008, 10:56 AM   #208
syndr0me's Avatar
Dawn,
I didn't mean that to sound threatening, like change it or else. It's just that I don't think I can get all that weight secured to the chassis of my car, and if I could, what would it do to the handling? The rule makes a lot more sense when you explain it that way, though. Hopefully there can be some middle ground.
In reality, rather than skip a race or buy a new car, I'd probably just get some NiMH (eeek!) and race with those. I'm a fan of ROAR these days, and will be joining in a few weeks when I move to a ROAR club. I think you've done a fine job here, and have restored people's confidence in the organization with your leadership. Thank you for everything you've done, and for surrounding yourself with the best people in the business.
Old 01-21-2008, 11:03 AM   #209
Every car in every class should be checked for minimum weight before and after every heat and main! Any car that comes in under the minimum weight after a race should be DQ for that race. This is the only way to insure fairness.
I also think that in carpet racing minimum ride height should also be checked before and after, but there's some debate to this. The way I feel, if you come in after a race lower than legal, then you were too low during the race, and therefore breaking the rules.
jiml is offline   Reply With Quote
Old 01-21-2008, 11:38 AM   #210
Mason's Avatar
I don't know if this is totally possible but the design sounds good. Make a plate, attaching (screw) rectangular weights to it that fit into the generic battery slots and screw the plate down from the top of the tray into/onto the chassis (or wait, drill a hole through the plate and the battery post can hold it down). the weights wont hang down below the chassis and your battery cg is still lower than a nimhs. any dremel wizard can spend a few minutes hacking this out. any aftermarket supplier could make a couple bucks off this. you guys make me almost want to go into business. You could alter plate density/thickness or weight material/size to get the weight balance you need.
and the guys using the cell emulating packs, flip it over like offroaders.
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
ROAR approves LIPO and Brushless al dente Colorado Racing 12 01-23-2008 11:42 PM
Roar Approves Lipo *Chrominator* Electric Off-Road 28 01-23-2008 10:35 PM
ROAR Approves Brushless Motors chicagokenji Wisconsin & Illinois Racing 5 07-17-2007 11:40 AM
ROAR approves Batteries.. Mason Electric On-Road 33 12-18-2005 08:29 PM
ROAR Approves batteries Mason Florida Racing 0 12-16-2005 01:49 PM
