Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 04-08-2011, 04:39 PM
  #14821
NT
NT's Avatar
Trader Rating: 21 (100%+)
Originally Posted by mangoman
I dont think TG seems like the kind of guy who likes having electrodes poked into him, let alone talk of a tread mill....
You're right Marty-anal probes are much more his thing!
NT is offline
Old 04-08-2011, 05:54 PM
  #14822
mangoman's Avatar
OH MY!
Say hello to pauly
mangoman is offline
Old 04-08-2011, 07:21 PM
  #14823
just got my m03 in
Robs Pics is offline
Old 04-09-2011, 12:47 AM
  #14824
caltek1's Avatar
Trader Rating: 38 (100%+)
Martin,
Don't you know "All of the rc mini net stuff is done with smoke and mirrors."
Haven't you been told.
BTW,
Thanks for the driving tips last night. I will make sure I don't take them to Illawara tomorrow for the practice meet.
Later,
Calvin.
caltek1 is offline
Old 04-09-2011, 12:58 AM
  #14825
caltek1's Avatar
Default OIL GEAR DIFF
I am happy to report the oil gear diff I have been testing in my MO5M is working a treat and standing up to the abuse running on carpet and asphalt. The diff has not leaked and still pulls the car in a straight line. I have been very happy with this car and will continue to test for a while yet.
The best part is it is a very simple conversion and only requires minimal effort to get a great working lower maintenance diff.
The 500 000 wt oil could be replaced with 300 000 wt oil, as a friend who is running this in his car has pretty much the same grunt on acceleration out of the corners.
I still also run the TAO3 ball diff in my other car that I use at big events as I prefer the drive that this gives and I like the reliability.
I think however that in the future the gear oil diff will be the way forward for the MO5/MO6. Unfortunately they will not fit inside a MO3 unless one is purpose made.
When I have conducted some more testing I will report back.
BTW,
I don't want to hear anymore about anal probes and TFG in the one sentence. You guy's are fully sick.
Later,
Calvin.
caltek1 is offline
Old 04-09-2011, 02:48 AM
  #14826
mangoman's Avatar
Originally Posted by Robs Pics
just got my m03 in
www.rcbabes.com
mangoman is offline
Old 04-10-2011, 07:29 AM
  #14827
Misiek's Avatar
Are Tamiya CVA Mini shocks any better than the clear ones that the kit comes with?
http://www3.towerhobbies.com/cgi-bin...?&I=LXGL65&P=7
Thanks.
Misiek is offline
Old 04-10-2011, 07:33 AM
  #14828
PadrinoNY's Avatar
Trader Rating: 58 (100%+)
Thanks.
They are both the same withthe exception to weight the clear ones are lighter. If your considering changing the shocks you might wanna consider the aluminum ones they just plain out work better....
PadrinoNY is offline
Old 04-10-2011, 07:35 AM
  #14829
Firefox's Avatar
Anyone make a BMW Z3 or Z4 mini body ?
Firefox is offline
Old 04-10-2011, 07:54 AM
  #14830
Misiek's Avatar
Thank you. Sounds like I will be getting Tamiya part 54000 soon then.
Misiek is offline
Old 04-10-2011, 04:42 PM
  #14831
mangoman's Avatar
The clear ones which come in the pro kit crack really easy. For me, its rare to see a seasoned mini driver with them on the car.
Those plastic ones you listed are fine for a cheap shock. They use plastic ride height adjusters as opposed to a threaded collar.
If you are allowed after market hop ups you may also want to consider using some of the other alloy brands such as 3racing if you are on a budget.
mangoman is offline
Old 04-12-2011, 01:48 PM
  #14832
Misiek's Avatar
What is the advantage (if any) of the aluminum motor plate?
Misiek is offline
Old 04-12-2011, 02:01 PM
  #14833
Default Alum Motor Plate
It acts as a heat sink so you motor will run cooler...and looks good so your car will LOOK cooler.
oldrcer is offline
Old 04-12-2011, 02:40 PM
  #14834
*Croatia*'s Avatar
What size pinion and spur are you guys running with the silver can motor for your mini coopers? Getting ready for TCS. Thanks!
*Croatia* is offline
Old 04-12-2011, 03:44 PM
  #14835
You can't change the spur as it's part of the gear set. Most if not all of us are using 20T for the pinion.
Sydewynder is offline
