Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 03-13-2011, 08:20 PM
  #14686
R/C Tech Elite Member
monkeyracing's Avatar
If you're thinking about using different body posts to lower the shell, try a set of M03/05 front posts on the rear of your car. The holes will be very slightly forward of where they'd normally be.
monkeyracing is offline
Old 03-13-2011, 08:25 PM
  #14687
Firefox's Avatar
That's the plan. It should lower the rear to where I want it. Way to high with the stock M05 rear body mounts.
Firefox is offline
Old 03-14-2011, 12:02 AM
  #14688
iti20090's Avatar
A change of rear posts also made for neat fit on this TT cladded M03, blooded this past weekend. Of interest was the too steep (my fault) rear wing which got the car all unstable on the long straights and was removed - would never have believed there would be any impact. The posts were in a pile of bits and meant new location holes - I do like the idea of the front posts on the back, though.
Cheers
Dave
iti20090 is offline
Old 03-14-2011, 12:43 AM
  #14689
Tim K's Avatar
Originally Posted by IndyRC_Racer
Well, my M-Chassis universals finally wore out. Before I replace them, I have a question...
Is there a good way to cushion the pins on the universals (where they contact the diff outdrives)? The pins seem a bit thin and have worn a grove into the out drives. I've been using the Tamiya RC M-Chassis Universal Shafts 53205 universals.
Luckily I got a good deal on a new M-03 kit, so I can use new outdrives and dog bones. I just prefer the universals so I don't have to worry about a dog bone popping out. (Yes, I know about using o-rings or foam to help keep the dog bones in).
I'm wondering if the Tamiya 53597 Universals (CVDs?) are a better option for about the same price.
Thanks for any responses.
The 53597 universals are a better option. The axle part of the uni has 4 holes in it so when 2 of them wear out you can disassemble the uni and use the 2nd set of holes. You can buy a rebuild kit for them as well in case your pins wear out first - part no. 53500
Tim K is offline
Old 03-14-2011, 06:46 AM
  #14690
Firefox's Avatar
Using the stock 225mm, M05M, parts, the front body mounts on the rear will be more forward.
Thinking about modifying the M05L shock/body mount support as pictured below, marked in yellow. It should keep the body mounts about the same location from front to rear but will still be wider, but I like wider if it will still fit....
Firefox is offline
Old 03-14-2011, 10:15 AM
  #14691
Cheers
Dave
Nice looking body. Did I notice the rear tires hanging outside the body? If so were there any issues? Is this body designed for the MO3 or the MO5? If for the MO5 what other mods did you have to do? Thanks Rodney
BONZAIIII is offline
Old 03-14-2011, 10:38 PM
  #14692
iti20090's Avatar
It will fit either M03 or M05, although it has a lower stance on the M05. The RC Mini lads used it on the M06. Ja, the rear of the body tends to "paint/cut curl" in after cutting/painting and the 2 degree tow in blocks exacerbate the appearance. Not had any dramas and I guess one could tweak it back with shoe goop or suchlike.
The standard rear posts will work with a bit of massaging as per my 2010 yellow raced version pic below - unfortunately not a good pic as the car was jacked up on the shocks but still on original posts and clear that body slightly raked nose down .
The new rear posts I found (perhaps TT01?) angled off much lower and did require a different hole position but that was easy - I also liked the lower rear ala the M06 RC Mini version. I would probably better go with the M05 front posts on the rear for the next shell, which would probably also provide better support.
Cheers
Dave
iti20090 is offline
Old 03-15-2011, 10:01 AM
  #14693
Thanks Dave
Old 03-15-2011, 10:03 AM
  #14694
CSeils's Avatar
Trader Rating: 54 (100%+)
Default Speed Controls
Just wondering what everyone is using for a speed control in their M03's. I had a LRP Quantum up until Saturday. Now I have to buy a new speedo but am having a hard time figuring out what is available these days. Something that is not brushless and one that will fit in the rear of the M03. Hopefully the same size of the LRP.
Anyone know where I can score a cheap Quantum?
Any suggestions?
CSeils is offline
Old 03-15-2011, 10:27 AM
  #14695
Firefox's Avatar
Just for reference, M05 with front body mounts on the rear with a MX5 body.
I like it
Firefox is offline
Old 03-16-2011, 01:20 AM
  #14696
iti20090's Avatar
First class - much better than through the angled rear window, will do same on next TT.
Cheers
Dave
I like it
iti20090 is offline
Old 03-16-2011, 08:01 AM
  #14697
k_bojar's Avatar
Trader Rating: 30 (100%+)
Any suggestions?
you also got the tekin Fx/FxPro speedo - which are brushed only and around the same size, if not smaller, then the LRP's
k_bojar is offline
Old 03-16-2011, 09:56 AM
  #14698
hi all,
I just got myself a M05 pro... i have never run a mini before.. I want to ask if 13.5t brushless motor is too fast? or 17.5t brushless is sufficient for a decent speed (not too fast)??
by the way, i'm using Tekin RS esc
thanks
hansenhon is offline
Old 03-16-2011, 10:01 AM
  #14699
rccardr's Avatar
+1 on the FX Pro, Carl. I use one in my GT silver can sedan, and you've seen that puppy run. I use an older Tekin G12CIII in my M05- same one I used for years in my M03- just take off the case and run it naked on a piece of dense foam. Works great, fits fine with a small receiver.
rccardr is offline
Old 03-16-2011, 01:10 PM
  #14700
Foxxrocket's Avatar
Has anyone tried widening the front wheelbase as a setup tool? I have some 1mm hex spacers I can put in the front end.
Foxxrocket is offline
