Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 02-23-2011, 12:20 PM
  #14491
Originally Posted by monkeyracing
Darn! They've used the bigger bearings. How am I supposed to fit that in my M-03?
These diffs need to have the outdrives assembled onto the case before filling with oil to avoid leaking. The m03 design has the outdrives put in after the diff is inside the chassis. Also the size of the m03's bearing inner race is too small for the size the drive cup needs to be.
Sydewynder is offline
Old 02-23-2011, 12:31 PM
  #14492
tony gray's Avatar
No need Jim. M03's are perfect as they are...
tony gray is offline
Old 02-23-2011, 12:50 PM
  #14493
R/C Tech Elite Member
monkeyracing's Avatar
Just like me.
I just chucked a new TA-03 diff in there anyway. No need to spend anymore.
monkeyracing is offline
Old 02-23-2011, 12:58 PM
  #14494
offtraxx's Avatar
Trader Rating: 59 (100%+)
any way to get rid of the front end noise on a mo-3? turning on power and it sounds like the dogbones want to fly out. been this way since I got it new x-mas time
offtraxx is offline
Old 02-23-2011, 01:14 PM
  #14495
Originally Posted by dongenserv
if anyone interested racing mini once a month see my thread california racing thank you
Hey Don,
I'm interested. I bought a couple of genetics a while back and then it died down. Whick track?
Danny
fx35rc is offline
Old 02-23-2011, 01:30 PM
  #14496
Put some universal/cv axles in there. That will take care of the chatter when turning. If you're talking about how it sounds like a squealing pig, that's just how they sound.
Old 02-23-2011, 06:24 PM
  #14497
ajt
ajt's Avatar
Default Looking to put together M05/CF-R
I haven't been into RC since 99 or so and I really want to get an M05 Pro or maybe even a CF-R M05 conversion built. When I found this site I freaked out. There is so much good information. Thanks to everyone for sharing! I have a couple of questions.
Does anyone know which parts I would need from the M05 to put together the CF-R M05? I am pretty sure that I wouldn't need the whole kit.
Also, does anyone know of good deals on radio equipment and motors? I am not sure where to buy online. Can you get good deals on kits or bundles? Sorry for the noob questions.
ajt is offline
Old 02-23-2011, 06:42 PM
  #14498
Go to rc-mini.net and look under reviews for xevo vs. tech
Old 02-23-2011, 08:21 PM
  #14499
Originally Posted by rccardr
Don, a little off topic, but if you're looking for old TC's you should e-mail me at [email protected].
I have a bunch of TA-04's including a TRF and Tuned Special...
i tryed to send you a reply but it would not go go thru can you email of what u got and price to [email protected] thanks
dongenserv is offline
Old 02-23-2011, 08:52 PM
  #14500
Default MINI COOPER 6 HOUR ENDURO
California Mini Cooper Racers, check this out.
entries will fill up fast, so enter early.
minicooper enduro flyer-pdf.pdf
thanks
Bill Secara
BILLSBOAT is offline
Old 02-24-2011, 12:17 AM
  #14501
BumFacedGoat's Avatar
mr wynder is correct. rc-mini lists all the bits you need to do the cf-r. doesnt look like many at all
BumFacedGoat is offline
Old 02-24-2011, 11:05 AM
  #14502
tony gray's Avatar
To quote Tims review in regard to what bits you actually DO need...
The parts you need for this kit are:
M05 F parts C hub, knuckle (front upright), rear upright.
M05 B parts just the steering wiper parts.
M05 C parts rear lower suspension arms, rear body posts.
M05 D parts the rear body post mount only.
You will need hinge pins for the lower rear arms.
You will also need universals, rear axles and parts of the M05 ball bearing set 4x 850 for steering wiper, and 8x 1150 for front and rear uprights.
Not a lot at all!
Old 02-25-2011, 12:35 AM
  #14503
Hi, after 2 qualies in TITC. Mix of M03/5/6.
rccartips is offline
Old 02-25-2011, 12:57 AM
  #14504
PizzaDude's Avatar
I see only 2 M-03's .
Any (close up) pics and setups of these cars at the TITC anywhere yet?
PizzaDude is offline
Old 02-25-2011, 05:04 AM
  #14505
Trader Rating: 8 (90%+)
Originally Posted by Firefox
On the subject of diffs, is the Tamiya 54194 the one to use and is anyone running the Tamiya 54238 reinforced ball differential cup ?
I am running it. It's very solid. Heavy though so I'm not sure about the performance hit.
To secure it. Use the TRF201 diff nut and bolt and the TRF201 thrust bearing assembly. They will fit perfectly. One thing to note, don't overtighten the diff or els ethe diff nut (although aluminum) will still strip. Don't ask how I know
P.S. Put lots of thread lock on the diff bolt/nut.
TenzoR is offline
