Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 02-04-2011, 12:58 PM
  #14296
R/C Tech Elite Member
monkeyracing's Avatar
Originally Posted by Justind97
Hey guys,
I don't post on here much.
I just spent a week and half reading through all the posts, well from about post 350 to present.
A WEALTH of information in here! I want to thank all of you that post little hints and tricks.
A lot of the information I've jotted down and am keeping it aside for future reference.
Just wanted to say cheers and thank you very much!
There is a lot of great information available here and some very experienced mini drivers. Absorb everything you can!
monkeyracing is offline
Old 02-04-2011, 06:26 PM
  #14297
SoCalGuy's Avatar
Hi Guys,
So I got my mini built, did all the mandatory (bling) upgrades, And love the heck out of the way it drives. One thing I noticed is that is "skips" during hard cornering. Is that what is referred to as "bump steer"? I've upgraded to the Tamiya steering parts, using the s-grip tires, red springs rear and yellow front, asphalt track. Any suggestions would be appreciated.
SoCalGuy is offline
Old 02-04-2011, 09:41 PM
  #14298
Trader Rating: 24 (100%+)
Originally Posted by superspeed
What was the wheelbase on that VW bus body? 210mm?
I believe so. Not stated on the HPI label but it fits perfectly on a M02M chassis. Going up for sale soon .
Pic on right is what it looks like painted
Attached Thumbnails Tamiya mini cooper-hpi-vw-bus-body-set-001.jpg   Tamiya mini cooper-26802.jpg
Evoracer is offline
Old 02-05-2011, 02:35 AM
  #14299
2-Bad's Avatar
Guys... When bolting on the optional frt Shock tower on the M05, which position on the tower is the most preferred setup position? Or should I just bolt it in a similar position as the kit tower?
thx....
2-Bad is offline
Old 02-05-2011, 03:55 AM
  #14300
I)arkness's Avatar
i use the most outward spot, standing the shocks up like the m03, but if im wanting more steering id drop it down the the middle position
I)arkness is offline
Old 02-05-2011, 10:48 AM
  #14301
M03Racer's Avatar
Trader Rating: 33 (100%+)
Originally Posted by SoCalGuy
Hi Guys,
Are you running M03 or M05 chassis. I have no issues with "bump steer" on my M03R chassis I don't have a M05 so I'm not sure if the M05 has this issue.
M03Racer is offline
Old 02-05-2011, 11:42 AM
  #14302
roger999's Avatar
hi, have a question,
what grease or mayby diff silicone can I use for standard diff? We can't race on ball diff so i have no choice...
roger999 is offline
Old 02-05-2011, 12:03 PM
  #14303
SoCalGuy's Avatar
M-05 SWB.
Actually I don't believe it's bumpsteer (after googling it's definition); it just chatters (skips) when cornering. Maybe ackerman needs adjustment, or the suspension is too stiff.
SoCal
SoCalGuy is offline
Old 02-05-2011, 12:31 PM
  #14304
Bumpsteer is primarily created by suspension geometry. IE: You go over a bump, one of your front wheels rises, potentially 'steering' one or both of your wheels.
Chatter while cornering can be created by many things. First thing in a FWD mini: are you running universal joints or dogbones on your front axle? Dogbones will cause chatter while cornering.
After that, play with springs, look for excessive slop in the front end...maybe the tire are too spongy?
Old 02-05-2011, 01:29 PM
  #14305
academygaz's Avatar
M02M means 225mm.
academygaz is offline
Old 02-05-2011, 07:37 PM
  #14306
SoCalGuy's Avatar
Quick poll;
What's your favorite body?
SoCalGuy is offline
Old 02-05-2011, 10:03 PM
  #14307
I)arkness's Avatar
for swb:
monster mini or colt mini cooper.
main reason you can slam them super low and they look cool
Old 02-05-2011, 10:36 PM
  #14308
HPI Miata. It's a tough shell and protects the front wheels by deflecting collisions.
Old 02-06-2011, 12:18 AM
  #14309
rcmarek's Avatar
Default Fabia
Quick poll;
This one
rcmarek is offline
Old 02-06-2011, 02:38 AM
  #14310
2-Bad's Avatar
Hi, I've switched over from the plastic to alloy shocks. I've built them up the same as I would for TC Shocks, with the clear O-ring in the cartridge, except the instruction said to put a black O-ring under the piston. But the shock feel real tight! Put 500 oil in them with Blue & Yellow springs and they feel no better. Put them on the car and the cars suspension feels dead. Turned a few laps and sure enough the cars hopping like a bitch rabbit when cornering!
What have I done wrong?
2-Bad is offline
