Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 01-24-2011, 08:37 PM
  #14266
R/C Tech Elite Member
monkeyracing's Avatar
Originally Posted by rough512
were you using the aluminum motor plate?
Nope. The car is box stock except for dampers. I was using a TT-01 heat sink that covers a good portion of the motor. This helped a little compared to my first run with no heat sink at all. I've got another, more open heat sinkon the way with a fan attached that I hope will alleviate this a bit.
monkeyracing is offline
Old 01-24-2011, 10:53 PM
  #14267
mangoman's Avatar
Is that a 540 motor, and if so are you covering the cooling vents on the motor with the heat sink?
mangoman is offline
Old 01-24-2011, 11:03 PM
  #14268
Yeah, 540 silver can. The vents are covered more by the gearbox than by the heat sink. It is something I thought of. Never gave it much weight though. I guess we'll see what happens when the more open and cooled unit arrives.
The one I've ordered is a Yeah Racing piece. Costs around $5 US. hopefully the fan will last more than one race day.
Jim
Old 01-25-2011, 05:51 AM
  #14269
mangoman's Avatar
Yeah the motor will heat up so much more if the vents are covered
mangoman is offline
Old 01-25-2011, 06:30 AM
  #14270
digitrc's Avatar
I've always found the same. Clip-on heatsinks seem to cause more heat problems than they solve.
digitrc is offline
  #14271
sohlman's Avatar
Trader Rating: 92 (100%+)
Nice thing about the M06 is that the rear sway bar mounting brackets above the motor are perfectly spaced for attaching a 30x30 fan.
sohlman is offline
Old 01-26-2011, 11:32 AM
  #14272
Morbo's Avatar
Anyone know if the Alpine body fits on the M03?
Morbo is offline
Old 01-26-2011, 11:56 AM
  #14273
superspeed's Avatar
Alpine body is short wheelbase = 210mm.
If you have stock M03, wheelbase is a match. However, the front end of M03 such as steering servo mount is pretty tall so it might hit the body.
If your LHS is not too far, try test fit the body on your M03 chassis if they have the body in stock.
superspeed is offline
Old 01-26-2011, 11:59 AM
  #14274
superspeed's Avatar
Default Fan vs. motor heatsink
Jim
The weight difference between dc fan unit and motor heatsink won't be too much, fan cools the motor better.
Old 01-26-2011, 03:34 PM
  #14275
Does anyone happen to know where I could find a copy of the Japanese TCS rules? Just curious about the differences.
Old 01-28-2011, 02:28 PM
  #14276
Trader Rating: 88 (100%+)
Does anyone have a good starting setup for a M-03 and m-05 on carpet?
MUDVAYNE is offline
Old 01-28-2011, 02:30 PM
  #14277
caltek1's Avatar
Trader Rating: 38 (100%+)
I don't change my settings on my car when I go from asphelt to carpet, only the tyres and ride height. I use the Tamiya M grips with the black Tamiya hard insert.
Calvin.
caltek1 is offline
Old 01-28-2011, 03:15 PM
  #14278
digitrc's Avatar
My starting setup on carpet with M-05 (briefly)...
- GET THE CAR TO RUN IN A STRAIGHT LINE! For me that meant high torque servo saver, aluminium steering posts and shims. I also took out the bumpsteer with a spacer on the upright.
- Tyres - Sweep 25 all round, glue sidewalls of fronts.
- Shocks - CVA super mini, blue short spring front, yellow short spring rear, #600 oil front, #500 oil rear (makes no difference on these dampers)
- Ride height - arms just below level front, arms level rear, allow a tiny bit of droop.
- Drivetrain - M-05 ball diff set tight (but not locked), UJs.
- Weight - 1300gm (rules)
- Body - Abarth 500 (225mm).
Car is good... got it running well just in time to strip it apart to build an Xevo!
digitrc is offline
Old 01-29-2011, 11:41 PM
  #14279
tony gray's Avatar
And at the latest big event down under, the KROMA Cup in Melbourne.
It was an rc-mini 1,2,3 with Tim, Brad and Aaron taking the places.
Cars? M03 SWB, M05 LWB, M03 SWB. There's very much life in the old girl yet.
Oh, and all 3 cars ran TA03 ball diffs..
tony gray is offline
Old 01-30-2011, 12:09 AM
  #14280
For install TA03 diff in M05 should we change or add anything?
higbo is offline
