Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 12-10-2010, 10:54 PM
  #13846
caltek1's Avatar
Trader Rating: 38 (100%+)
Jay,
Was to answer this enquiry:
"Scuse me for asking instead of searching 6 million pages, but what's the ali rear upright of choice these days and what toe in ??"
Jacko
I thought the aluminium rear hub of choice was the Tamiya 1.5 degree upright. Lots of others buy as a hopup item for MO5 and MO3.
Perhaps I am misinformed.
Later,
Calvin.
caltek1 is offline
Old 12-11-2010, 01:34 AM
  #13847
Later,
Calvin.
The 1.5 Hub comes in the Pro kit.
Jay
pyro18t is offline
Old 12-11-2010, 02:20 AM
  #13848
Mr_Gleeman's Avatar
Trader Rating: 16 (100%+)
Can someone please tell me what the part number is for the Tamiya (blue version) servo posts used for the MO3
I had a set and remember it had 2 screw holes per post on the verticle side when installed and one on top to anchor it to the chassis.
Mr_Gleeman is offline
Old 12-11-2010, 06:34 AM
  #13849
subaru73's Avatar
Trader Rating: 42 (100%+)
Default m03
here you go http://www.tamiyausa.com/product/ite...oduct-id=49443
subaru73 is offline
Old 12-11-2010, 07:06 AM
  #13850
Mr_Gleeman's Avatar
Thanks subaru73, that's the one!!
Cheers
John
Old 12-11-2010, 08:08 AM
  #13851
subaru73's Avatar
Cheers
John
you are welcome
Jon
subaru73 is offline
Old 12-13-2010, 03:22 AM
  #13852
scribbler's Avatar
I just replaced the plastic steering link with a piece of graphite/carbon fiber. I won't get a chance to see if it will work till Tuesday. I found the plastic piece flexed too much. Any speculation as to what will happen?? I think it'll will give more steering consistancy, but I'm wondering if there is anything I've overlooked, or not taken into consideration??
scribbler is offline
Old 12-13-2010, 03:31 AM
  #13853
sosidge's Avatar
I take it you mean part B10 in the standard build? In which case I don't think you will notice much difference.
By my reckoning the biggest problem with the steering linkage is the bad fit of the posts it mounts on (part B3), with lesser issues caused by the free play in the step screws and the steering uprights. I don't think the actual moulded parts are excessively flexible.
I intend to try the hop-up steering parts on my car at some point. At the moment it is good in corners, but awful on the straights.
sosidge is offline
Old 12-13-2010, 12:56 PM
  #13854
tony gray's Avatar
Another first for rc-mini. In a world exclusive, the first battle of the hyper-minis.
Two top-line, no holds barred FWD Mini kits take on each other. Only on rc-mini.net
The Tech Racing CF-R and the all new Xevo Triumph.
Click HERE to see it all
tony gray is offline
Old 12-13-2010, 03:45 PM
  #13855
RossoTorro's Avatar
So......... The Hyper Minis are slower than the orginal ones?
So much for upgrades then, or should i say downgrade...
RossoTorro is offline
Old 12-13-2010, 04:42 PM
  #13856
NT
NT's Avatar
Trader Rating: 21 (100%+)
Read the article again dude
NT is offline
Old 12-13-2010, 05:38 PM
  #13857
Hi, did I read correctly? M03 = 20.7, Xevo = 21.3, Tech = 21.6? So M03 is fastest? What wheelbase were they running? thanks.
rccartips is offline
Old 12-13-2010, 06:59 PM
  #13858
tony gray's Avatar
M03 - SWB
Tech CF-R - SWB
Xevo -MWB
Old 12-13-2010, 07:06 PM
  #13859
over gear's Avatar
Trader Rating: 18 (100%+)
tony gray: great report! if you suspect the CF-R has lots of wheel spin coming out of corners... do u notice excessive tire wear?
over gear is offline
Old 12-13-2010, 07:29 PM
  #13860
tony gray's Avatar
Hard to tell on the basis on a single race meeting.
That's only our guess at the moment, and to be honest I dont think that's the answer. If it was excessive wheelspin I think we'd hear it as the car is whisper quiet.
