Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 11-17-2010, 10:24 PM
  #13591
That sadle pack setup is pretty cool. Have you accually run it like that? If you did, did the packs run under hard cornering?
Jay
pyro18t is offline
Old 11-17-2010, 10:32 PM
  #13592
goBezerk's Avatar
Jay
Sure have. If you mean did they rub on the ground, nope. They've actually got more ground clearance than the stick pack and pretty much spot on the right width as well. The overall width is around the same as the outer edges of the brackets that hold the stick pack in. The outer lower edge is around 4 - 5mm higher than a stickpack.
goBezerk is offline
Old 11-17-2010, 10:36 PM
  #13593
Wow seems like a great idea! My Mini should be showing up tomorrow, as long as I can catch the FedEx man that is!
Jay
pyro18t is offline
Old 11-17-2010, 11:54 PM
  #13594
Originally Posted by goBezerk
Think it's fairly safe myself, the plastic around it is pretty substantial and it's tucked behind the battery and the front wheel...anyhow, time will tell. It was either 10 mins of work with an offcut that was lying around or quite a bit more time to attach it to the motor screws...I opted for easy
And for the Mini Enduro nuts out there, here's my M05 with 6000Mah saddle packs Imagine how many laps you could cut with that! Don't know it would be approved for any events though...
Hey! Whatever works for you!
And yes, we all love to see some ingenuity! Love the saddle packs.
rcnutbag is offline
Old 11-18-2010, 03:40 AM
  #13595
Default Yeah Racing 1.5 degree rear uprights
Hey has anyone out there purchased these only to find that they're out of alignment? I checked my brand new ones last night, as they just didn't seem right, and true enough the left was toe-in, and the right almost 0 degrees.
I checked with brand new sets of lower arms as well, just so I could discount the possibility of the arms being out of whack.
Anyone?
rcnutbag is offline
Old 11-18-2010, 05:51 AM
  #13596
mangoman's Avatar
Hmm interesting idea with the saddle packs. In australia i believe battery fixings are open. But if i were running a race meet personally i would rule that that is not in the spirit of mini racing.
mangoman is offline
Old 11-18-2010, 11:19 AM
  #13597
cannon's Avatar
Trader Rating: 35 (100%+)
For racing I would have thought that it would handle worse as the weight is put further out. THere is no weight through the centre of the chassis
cannon is offline
Old 11-18-2010, 01:29 PM
  #13598
AUSSIE BOB's Avatar
Default not too far
I dont think it would go far at all. Definetly not more than 2 minutes with that pack as the wheels would fall off first.
Bob
AUSSIE BOB is offline
Old 11-18-2010, 01:35 PM
  #13599
goBezerk's Avatar
I was kind of the same, it was really just an experiment...but thought I'd post it for some feedback/ideas for other guys to play with. Good thing is no mods have to be done to the chassis, eg no cutting grinding etc
Yes and no. As the original was designed for a NiCad/NiMh, I thought I'd try and replicate in a way the weight of these stick packs and also have the opportunity to add even more between the cells if deemed necassary...re the weight distribution, from my experience it would mainly depend on the track conditions, grippy tracks needs the weight further inboard and slippery tracks further outboard. They can also be run with their bases against the chassis, just requires the battery leads to be more creatively added
Certainly at Boronia it sat on the track fine, haven't tried it at TFTR yet but probably won't bother as it's obviously not going to be "legal" anyhow. No sign of traction rolling, no matter how hard you pushed it...other bonus is you didn't need any extra weight to make minimum race weight
goBezerk is offline
Old 11-18-2010, 01:41 PM
  #13600
goBezerk's Avatar
Bob
Not sure what you're trying to say, at 30 grams over minimum race weight, it's certainly lighter than most local racers run at, typically around 1,400g...
goBezerk is offline
Old 11-18-2010, 02:06 PM
  #13601
RossoTorro's Avatar
Originally Posted by woodys3b
Setup sheet says he used a 21 tooth pinion. I don't have my car in front of me but I though 20 was the biggest you could use.
I run 21T pinion in mine, no problem there is a little give in the screws.
Just make sure you get a little gap...
RossoTorro is offline
Old 11-18-2010, 05:01 PM
  #13602
mangoman's Avatar
I have actually regularly placed weights out wide. My theory is that it can stop traction rolling to a limited degree up to the point at which it wants to tip over (dont know if it does, but it seemed to help but that would have also just been the weight itself). Obviously it should also theoretically effect the car as it has to transition left to right though.
Personally i think the car should still handle fine, as long as the batteries are not scraping on the ground as the car leans through corners.
mangoman is offline
Old 11-18-2010, 05:31 PM
  #13603
goBezerk's Avatar
I agree. From my off-road experience, outboard weight helps on bumpy slippery tracks as it helps the car roll a little easier and also stops the car pitching left/right. With centralized weight there's very little sprung weight out wide to keep the car flat through rough section of track. But on high grip tracks you want the weight to transition slower so that the car is more stable...
At the end of the day, the height of the center of gravity is more important than the actual location of it off the centerline...I decided it was great from a capacity point of view but didn't improve in other areas that I was hoping for, so I just went back to my brass bumper and happy days
goBezerk is offline
Old 11-18-2010, 06:10 PM
  #13604
AUSSIE BOB's Avatar
Default no nuts
Goberzerk, the wheel nuts are not there, that is why it would not go far.
Bob
Old 11-18-2010, 06:47 PM
  #13605
goBezerk's Avatar
Bob
good eyes there!
goBezerk is offline
