Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 11-05-2010, 07:23 PM
  #13426
Hi all, this is my first post in this thread. I've just bought an M05 Pro and am looking forward to going racing if my batteries ever arrive
I just have a complete newb question so I hope you don't mind. When it says to glue the inserts with rubber cement/glue what glue are you using? Is it even necessary if you are supergluing the tyres to the rims.
Thanks for the help
Simon
Modelholic is offline
Old 11-05-2010, 10:38 PM
  #13427
Thanks for the help
Simon
Contact cement works better for me.
Granpa is offline
Old 11-05-2010, 11:01 PM
  #13428
scribbler's Avatar
I switched from the tamiya inserts to the Spice/ Ride moulded foam inserts. All you have to is insert them in the tires. Less fuss and muss.
scribbler is offline
Old 11-06-2010, 04:37 AM
  #13429
Low_E's Avatar
hello chaps;i just pop in for a quick question: will the ball-diff for the M-05 (tam54194) also fit the older M-03?
thx
Low_E is offline
Old 11-06-2010, 04:41 AM
  #13430
cannon's Avatar
Trader Rating: 35 (100%+)
thx
No, the M05 ball diff uses 15 x 10 outdrive bearings. Cant fit in the M03 which uses outdrives which slip through 11 x 5 bearings
cannon is offline
Old 11-06-2010, 06:43 AM
  #13431
Low_E's Avatar
I also read somewhere that you can fit a TA05-diff into the M-03. Is that correct?
It does use the same bearings, AFAIK
Low_E is offline
Old 11-06-2010, 06:56 AM
  #13432
silvermag's Avatar
this is a little off topic but i had to post it...
‎1) Go to Google Maps 2) Click on Get Directions 3) Type in Japan as starting point 4) Type in China as ending point 5) Go to number 43 on the directions 6) Laugh
silvermag is offline
Old 11-06-2010, 07:07 AM
  #13433
TraxxasPeter's Avatar
Trader Rating: 21 (100%+)
lol thats so funny just did it
TraxxasPeter is offline
Old 11-06-2010, 07:12 AM
  #13434
k_bojar's Avatar
Trader Rating: 30 (100%+)
won't work - the TA05 is a belt-drive car, so its got a pulley instead of a bevel gear like the m05 needs
the M05 ball diff is similar to the ta05 diff in design and probaby some parts - but the main (important) gears are different
k_bojar is offline
Old 11-06-2010, 07:56 AM
  #13435
sportpak's Avatar
Trader Rating: 26 (100%+)
I've had good luck with the TA03 diff. Dap of locktite on the screw and bottom it out.
sportpak is offline
Old 11-06-2010, 03:22 PM
  #13436
cannon's Avatar
The diff that you are referring to is the TA03 ball diff NOT the TA05. It fits. Also the Manta ray ball diff will fit
cannon is offline
Old 11-06-2010, 03:45 PM
  #13437
caltek1's Avatar
Trader Rating: 38 (100%+)
The TAO3 ball diff is the best choice for either the MO3 or MO5 mini. The MO5 diff is not reliable unless you modify it, so it works properly. I have broken numerous diff bolts on the MO5 diff and replaced them with thicker bolts and thrust washers. Then you transfer the wear onto the aluminium diff halves which then scoreand spread open.
If you use the hardened outdrives on the MO5 diff, with a 3mm diff screw, with a 3mm thrustbearing and then retap the 416 diff nut and grind down to fit the slot in the hardened outdrives the diff will work. Not all will want to go to so much trouble....
To prevent all that work, just build the TAO3 ball diff and add nitro fuel line into the diff cups and good to go.
The diff comes down to how tight do you want it to be. I prefer with our HW BL systems to use a tight diff and accept the wear. If you do not use a tight diff then you get lunched off the line and when trying to get out of the corners.
BTW,
silvermag,
That is funny for a sunday morning read.
Anyway good luck with what you decide.
Calvin
caltek1 is offline
Old 11-06-2010, 03:57 PM
  #13438
Trader Rating: 71 (100%+)
Does the Tamiya 104 speedo have 2 plugs that plug into the receiver? If so, the 3 wire one would go into ch. 2 ,what is the second 2 wire one for?
G the Menace is offline
Old 11-06-2010, 05:03 PM
  #13439
Official's Avatar
The slot that marks Batt in your receiver.
Official is offline
Old 11-06-2010, 05:19 PM
  #13440
Thanks for the info! Out of curiosity, do you know what it's for? I haven't seen this before and am just wondering.
