Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 12-20-2009, 10:19 PM
  #11026
caltek1's Avatar
Trader Rating: 38 (100%+)
jcr,
You should be able to see in the above photo. I have used a 2mm red spacer on the front knuckle. The droop screw is approx 10-12mm long.
I will try and get a clearer photo. I thought you might ask, so re-edited my previous post.
Regards,
Calvin.
caltek1 is offline
Old 12-20-2009, 10:22 PM
  #11027
jcr
Got any part numbers to share so I don't have to do too much searching?
jcr is offline
Old 12-20-2009, 10:43 PM
  #11028
caltek1's Avatar
jcr,
50594 2 x 10mm droop screw
53539 aluminium spacer set
53599 fluorine coated 5mm aluminium ball connector or 53640 aluminium blue ball nut
Regards,
Calvin.
caltek1 is offline
Old 12-20-2009, 10:49 PM
  #11029
jcr
thanks!
jcr is offline
Old 12-21-2009, 07:01 AM
  #11030
portyansky's Avatar
Trader Rating: 54 (100%+)
Originally Posted by caltek1
portyansky,
After doing some secret mini testing in the heat of the day, I can honestly say that the motor mount with the DF-03 heat bars and the external heatsink do transfer heat away from the motor. Not sure what the temps were, but the parts were hot to touch after running for 10-12 minutes using the 13T Hobbywing BL systems.
Both cars were dialled and the new diff is up to the task.
Later,
Calvin.
Thanks for the responce. Do you have a part number for those bars?
Porty
portyansky is offline
Old 12-21-2009, 09:44 AM
  #11031
SERPENT7twenty's Avatar
Trader Rating: 20 (100%+)
Whats up guys. I'm looking to get into these Tamiya Mini Coopers for misc. reasons. If anyone out there is selling one please PM me. I'm looking for 2 rolling chassis (M03 or M05) with or without bodies and tires etc etc etc.
Just show me what you got in a PM. Again, M03s or M05s.
SERPENT7twenty is offline
Old 12-21-2009, 10:26 AM
  #11032
So I understand the difference from M03 & M05 is servo placement for stability.
Could someone please explain - What is so different with the M04?
studysession is offline
Old 12-21-2009, 10:27 AM
  #11033
jcr
M04 is rear wheel drive while M03 and M05 is front wheel drive
jcr is offline
Old 12-21-2009, 10:31 AM
  #11034
Thanks for the quick reply.
Then maybe I want a M04 & a M05. Decisions, decisions...
Old 12-21-2009, 02:02 PM
  #11035
caltek1's Avatar
porty,
Tamiya PNo 53924 DF-03 Heatsink Bars.
Later,
Calvin.
caltek1 is offline
Old 12-21-2009, 02:23 PM
  #11036
portyansky's Avatar
porty,
Later,
Calvin.
Thanks Calvin!
Porty
Old 12-21-2009, 03:17 PM
  #11037
Default M03 tie-rod measurement
Hi guys,
I really really need to reset my old M03s steering as over the last 6 years it's been fiddled with so often (due to different wheels, tyres, dampers etc) that it is now way out of wack. I seem to remember the dimensions in the manual are 16mm between rod ends but I really need the overall length of the whole rod end to end as I have now got turnbuckles and HD rod ends and have lost the old Tamiya ones to use as a reference point .
Please can anybody help and save me from a life of eternally weaving down the straightaways and fighting the thing through the bends. It used to be such a friendly car, I think it's still not forgiven me for having a brief fling with an M05 (it ended in tears).
Mini35 is offline
Old 12-21-2009, 05:46 PM
  #11038
Trader Rating: 22 (100%+)
Default Difference
[QUOTE=studysession;6747252]So I understand the difference from M03 & M05 is servo placement for stability.
The suspension of the M03/05 is pretty much the same but the chassis are very different. It's not just servo placement. The main chassis rails are nothing alike.
Terry
Team Ash is offline
Old 12-22-2009, 03:29 AM
  #11039
Julius's Avatar
Originally Posted by Mini35
Hi guys,
Can't give you a measurement but a suggestion:
Put the car race ready on it's wheels and compress and release the suspension. Now look at the front wheels (with servo centered of course) and check if the wheels are parallel. Just adjust your rod length until you achieve parallel front wheels at your set ride height.
As the Mini's have soo much bump steer, the ride height has a huge influence on toe in/out. So rod length can differ quite a bit from car to car.
Just my 2cents
Julius is offline
Old 12-22-2009, 10:23 PM
  #11040
niznai's Avatar
Does anyone know if Tamiya offers stainless steel suspension shafts for the M05? I hate the screw type shafts.
Got it, nevermind.
niznai is offline
