Tamiya mini cooper
Here are a couple of my past Mini Coopers. No problems at all with 60D tires.
You guys are just pulling everyones leg right???? You can't be serious about the Rover Mini body not fitting with 60D tires. Admittedly tight if using the 2 degree rears, but raising the front slightly takes care of that. Lots of SWB Minis at every TCS race I've been to and no one had to hack on their bodies.
Ahh crap, just what I was afraid of. I'll probs stick with the Swift, but as I type this, I'm having a brainwave....how about having TL01 wishbones, upper links, driveshafts, maybe longer shocks....and bingo, new FWD touring car? Only 237mm wheelbase, but HPI's Citroen Saxo and Peugeot 106 woudl fit!
Hmmmm, ideas formulating... nah, sod it, I'll leave it a Mini (Swift).
Cheers Tony.
Cheers Tony.
I hate thinking when I'm in the bathtub.
Here is something to think about....
If tamiya is making M05s with rear wheels drive bodys whos to say that one can't run a BMW Z-3 with big tires on a M05??
or a Miata.
this new car has me wondering about the rules for the TCS racing
cause I would like to get the S800 on a M05.
but don't want to buy it if I can't race the body on it
because in the rules proper body for chassis FWD and Rwd
sorry just think before there is a big stink at a event.
or a Miata.
Also, Tamiya is re-releasing the S800 for the M-05 ,so it will most likely be legal for the upcoming season.
You could be pulled back in !!!!!!!!!!!!! Seeya in Memphis !!!!
Up here in Canada we're still sticking to the FWD/RWD body rules, so we still can't use the new ones in TCS races..
Hi,
I want to cut 26mm tire inserts to fit 24.6mm Mini tyres, what should I use to glue it back together?????
On a side note:
Has anyone made any headway for setting up the M05?
We've been testing ours for a couple of weekends and they are starting to get fast.
hey guys, im new to the mini racing, all i can say is its great, im running a m03, one problem im having is when i turn corners the rear of the car it chatters, i raced one with out rear springs, and still chatters, so i put them back in, i have weight for im running a stick battery not lipo. any way or ideas to help out with it. also how can i get more speed out of this thing, im getting better at the cornering but on a straight i get killed, ive cleaned the motor, let it run in water for 15/20 min brake cleaned it air dried it ans oiled the bearings, what else can i do??
as for you speed issues if you want do the stuff rick has done or buck up and go buy a new motor for xmas.... give me a call and I will let you know how to go about the little tip and see if we can squeek out a little more HP.... as for your arm.... I trying there might be one guy in town that has one... just tryin to get a hold of him
silvermag, if rear is chattering, try harder springs in the rear. high speed is about good batteries/esc/motor, try a lipo. assuming you are already using a 20T pinion.
My set up from todays race
FRONT
Yellow short Spring
400 oil
3 hole piston
5mm under piston
1 bush in the top of the shock
full rebound
TRF dampers
M grip tyres
White Swift wheels
Kit inserts
top hole on inner upper arm mount
inner hole on upright (plastic)
3mm spacers on steering for toe out
4mm wheel hex's with 0.5mm spacer
6mm ride height
REAR
White short spring
400 oil
3 hole piston
5mm under piston
1 bush in top of the shock
full rebound
TRF dampers
S grip tyres
White swift wheels
Kit inserts
Adjustable upper arms with 2mm spacers between
5mm wheel hex's
6mm ride height
replaced
FRONT
Yellow short Spring
400 oil
3 hole piston
5mm under piston
full rebound
TRF dampers
M grip tyres
White Swift wheels
Kit inserts
6mm ride height
REAR
White short spring
400 oil
3 hole piston
5mm under piston
full rebound
TRF dampers
S grip tyres
White swift wheels
Kit inserts
5mm wheel hex's
6mm ride height
replaced
Hey Markus , Can I get that heatsink ,now that you gave the car away??
lol. you heard about that... turns out I never found the M04 heatsink (trust me I looked everywhere in my stuff). I can give you back the gold spring though
