Tamiya mini cooper
#9376
I have noticed that others like to turn there chassis into swiss cheese. Our rule is no modifications allowed on the chassis, so I expect this rule will stand for the MO5 as well.
"Build as per instructions". Just the way it should be.
G'day Scott,
You should try and get to Penrith Mon night, I will have my MO5 there for a run.
Later,
Calvin
G'day Scott,
Later,
Calvin
#9377
#9378
So i have built my mini and its going in a straight line. I was wondering what sort of spares i should get? We will be racing on carpet with the barriers being pipe. What is most likely to break?
#9379
I always try to have a set of the c parts and a spare chassis front and rear. A spare servo savo, a spare servo and an assortment of scews. Spare set of front and rear knuckles and bearings.
I am sure if you are running at the mini 50, others will have spares. I am taking a complete spare car, as backup. A spare body doesn't go astray either. A spare ball diff if that is what you are using.
Regards,
Calvin.
Regards,
Calvin.
#9380
Regards,
Calvin.
Regards,
Calvin.
#9381
1.) Anyone here know if the Tamiya 53597 Option Parts M03 Assembly Universals will work on the new M05?
2.) Are the M Chassis Alum Damper Set #54000 the same (length, parts etc.) as the shocks used on the TA05 Tamiya 42102 TRF Special Damper Set?
thanks
thanks
#9382
New chassis=freshly painted body shell???
This might help get the creative juices flowing. Crude, but useful.
#9383
#9384
That's exactly what I was thinking, so...
The bodyshell is done, I'm just waiting delivery of the M-05 Pro to put it on...
#9385
#9388
Just lousy material and build quality. There are a few things from 3Racing that should be avoided. This is one of them. Also to avoid are the steering knuckles and the lower control arms. They're made of very soft aluminum and bend with very little force.
The TA03 ball diff might be heavier, but it is better made.
Jim
Jim
