Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 06-25-2009, 04:58 PM
  #9301
caltek1's Avatar
Trader Rating: 38 (100%+)
RC Champ is where mine is coming from. Pricing is good, postage hurts.
Regards,
Calvin.
caltek1 is offline
Old 06-25-2009, 07:13 PM
  #9302
R/C Tech Elite Member
monkeyracing's Avatar
So, what's with the 10 different versions they're selling? I can't get a decent translation on their page. Are they selling totally hopped up versions from day one?
Jim
monkeyracing is offline
Old 06-25-2009, 07:52 PM
  #9303
tony gray's Avatar
Ignore all the other crap. It's just combo deals with stuff you dont want/need. Batteries and screw kits and such.
tony gray is offline
Old 06-25-2009, 08:04 PM
  #9304
I recommend the Ti screw set unless you already have lots of them. hex screws are much easier to torque and won't strip as easy as a phillips. I got the Ti and Al kit for the extra "blueness"... need some conformity with my other tamiya chassis
the EMS shipping seems expensive at first. But it is still way cheaper than anyone else. And you get in 3-4 days
redbones is offline
Old 06-25-2009, 09:29 PM
  #9305
Regional Moderator
Darkseid's Avatar
Totally agree.
I'm also getting the kit and the screw set.
For those trying to order the kit and screw set, its the 13,500 option. If you use the Google Language tools it will translate it well enough for you to see what each offers.
And its a DAMN good screw set. First, the blue screws are as close to Tamiya blue as you'll ever get, and the screws on the bottom are usually all Ti screws. The hexes are perfect fits for any quality 2mm(5/64) driver.
As for the shipping, all people have to do is compare prices.
Kit+screw kit+EMS shipping(RC Champ)=kit+standard ground shipping(any US seller) So your paying the same thing you would pay for the kit here in the states, plus your getting a great screw kit.
On top of that, EMS usually takes no more than 3 days to get to you. Compare that to the standard shipping from US shops....what 5-7 days???
Darkseid is offline
Old 06-25-2009, 09:31 PM
  #9306
Trader Rating: 21 (100%+)
I've got a question. I have just finished off my m03, when i put the servo saver (horn?) on (b11, b10, b6) and drive around the horn doesn't re-center as it can move around and i meant to glue it together?
l337 is offline
Old 06-25-2009, 10:36 PM
  #9307
So, are RC Champ's prices amazingly low, or are Tamiya's North American prices totally out to lunch? I expect that when the M-05 hits the shelves here, it will be well over $200 (CAD).
Converting the prices on RC Champ to Canadian dollars, I'm getting a price of around $123.
Just how much do they charge for shipping?
Jim
Old 06-25-2009, 10:41 PM
  #9308
cannon's Avatar
Trader Rating: 35 (100%+)
Jim
For us in Australia , Chanp charge around 30% of the item value for shipping which is ridiculous
cannon is offline
Old 06-25-2009, 11:32 PM
  #9309
waOscar's Avatar
I think you may have missed the little washer (B2) which goes on the front under the screw.
waOscar is offline
Old 06-25-2009, 11:51 PM
  #9310
i do have a washer under the head of the screw. Its as if I'm not clamping the horn down tight enough to hold it all together to make it work as 1 piece.
edit: I fixed it, problem was the middle piece (b6) wasn't tight enough around the other 2 pieces which allowed it to move around. I got a new horn set for 8.50 (not for a mini) and put that b6 in and it works like a dream. Thanks for everyone's responses.
l337 is offline
Old 06-26-2009, 03:11 AM
  #9311
wrap the silver spring from the high torque servo saver around the stock one. you can also use a tie strap,but I dont recommend that.
redbones is offline
Old 06-27-2009, 11:09 AM
  #9312
Kail's Avatar
Just got my M05 courtesy of my good friend coming back from Japan. Hehe its nice. They include alu servo horns but not the other alu parts. Guess they are hop ups
Kail is offline
Old 06-27-2009, 02:44 PM
  #9313
Skitee's Avatar
I hope for Tamiya's sake that your kit is just missing the Alu rear uprights, otherwise they'll have some very upset customers on there hands.
Afterall it's on there own site that the Pro kit comes with the Alu rear uprights included.
http://www.tamiya.com/english/news/n...ews1.htm#58443
Skitee is offline
Old 06-27-2009, 04:26 PM
  #9314
Kail's Avatar
My bad. Alu rear uprights too. No alu fronts tho
Kail is offline
Old 06-28-2009, 03:21 AM
  #9315
found some things out.
1. The alum rear upright uses 1050 bearings. It has 1.5 toe in. So I cannot see a diff between this and my M03R one. I say they are the same deal.
2. The lower suspension mount on the rear bulkhead is a completely separate piece. This gives alternatives for toe in or anti-squat blocks. good idea there.
3. Car is a tad heavy this time. came in at about 1386g. (my cup racer is 1340g with same batt.) There are stuff that you don't need such as the batt holders (just use tape) and the electronic trays. but I don't think I can get it under 1300 using 3600mah packs.
4. Get the hex screws. oh, what a life saver. enough said.
redbones is offline
