Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 06-09-2009, 08:45 PM
  #9196
edwintklee's Avatar
Trader Rating: 23 (96%+)
some details photo about HPI switch....after looking....hmm....still prefer my M03
http://translate.google.com.my/trans...&sl=auto&tl=en
edwintklee is offline
Old 06-09-2009, 09:39 PM
  #9197
niznai's Avatar
Originally Posted by fordmike65
Nice air!!! My Mini only gets that much air when it's tumbling end-over-end!
I think that's actually what's going on in those pictures too.
niznai is offline
Old 06-09-2009, 10:20 PM
  #9198
tony gray's Avatar
All they did was confirm what we told everybody 6 weeks ago...and also confirmed by Grahoo-san.
If you paid good money for a Switch, this what you'd be doing now..
tony gray is offline
Old 06-09-2009, 10:50 PM
  #9199
R/C Tech Elite Member
monkeyracing's Avatar
Mini battery question: I'm looking at two different lipo batteries for my mini. One is rated at 20C and the other is rated at 25C.
In a mini using a plain old silver can, will this have any effect at all? I suspect not, because a silver can won't draw nearly that much power anyway.
Or am I missing something?
Jim
monkeyracing is offline
Old 06-10-2009, 02:07 AM
  #9200
Skitee's Avatar
You should see no performance difference with the silver can.
Skitee is offline
Old 06-10-2009, 05:46 AM
  #9201
MTX3-B's Avatar
any difference with a bigger capacity?
MTX3-B is offline
Old 06-10-2009, 06:17 AM
  #9202
edwintklee's Avatar
i guess....its will stay "power" for longer period if using higher capacity battery.
Old 06-10-2009, 06:22 AM
  #9203
MTX3-B's Avatar
how much more capacity would it take? assuming 3200 20C vs. 4000 20C. for a 5 minute racing, would u feel any noticeable differences in "power" for high turn motors such as those of silver cans & sport tuned?
thanks
MTX3-B is offline
Old 06-10-2009, 06:26 AM
  #9204
edwintklee's Avatar
tony ...you probally mean should be doing this..
Old 06-10-2009, 06:40 AM
  #9205
edwintklee's Avatar
thanks
hey...hang lipo...
frankly i really dunno, i only know that IB4000 25c lipo very punch and have good top end as compare to yeah racing 3200....also max power 4400 lipo also quite good...all about was tested on a same car, same tyre, same motor(HB13t)
Old 06-10-2009, 09:15 PM
  #9206
MTX3-B's Avatar
hey...hang lipo...
so i can safely assume that for high turn motor applications (relatively low amp draw), higher capacity LiPo will be advantageous since a higher capacity battery would be able to withhold the voltage a lot longer period of time?
i couldnt gauge the actual performance vis-a-vis the 3200 vs. 4000 as the 4000 battery is relatively new and the other one is almost a year-old. but it would be nice should the difference is not that significant as one would save by opting for the lower capacity batt. Yeah Racing is one mighty pack if it is new.
MTX3-B is offline
Old 06-11-2009, 08:27 AM
  #9207
Old Tech's Avatar
Default Questions
I'm dusting off an old M03 chassis that had only been driven "slow in the driveway" (to quote a famous movie) and trying to bring it up to race spec. It has full bearings, and at one point I did buy the aluminum c-hubs and uprights for it. I never did get a ball diff or oil filled shocks. I started to read through this thread, but getting through over 600 pages! So, let me just ask.
1) What is the difference between the TA03 and Manta ball diffs, and which is the preferred to use in the M03 chassis?
2) What is the shock of choice for the M03 chassis? I see there is now availalbe an "M-Chassis" Damper set. Is this the way to go?
The car will be run on a carpet track with a failry defined groove.
OT
Old Tech is offline
Old 06-11-2009, 09:24 AM
  #9208
The Manta ball diff is heavier.
Your best bet for dampers are the Tamiya Mini CVA ones. They're very good, made of plastic and affordable. If you want to get something aluminum and don't want to spend money, 3Racing makes a good set for about $20 (usd). If you've got money to spend, then Tamiya does make alloy dampers for the M chassis.
Given a choice, I'd take one of the first two options. I have to admit though, the Tamiya aluminum dampers are nice.
Old 06-11-2009, 11:57 AM
  #9209
Is it worth my time/money to invest in a ball diff? Any performance advantages?
jmhub1979 is offline
Old 06-11-2009, 02:57 PM
  #9210
Old Tech's Avatar
Thanks MR. Don't mind saving a few bucks at all.
jmhub1979, not sure how much improvement there'll be with the ball diff. My gear diff is surprisingly smooth and free, actually.
Old Tech is offline
