Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 03-30-2009, 03:48 PM
  #8701
Herkimer Jitney's Avatar
dude it tells you all this stuff on the rcmini site. i think its in the m03 build-up section. i do all my cars exactly like they say and never have any trouble. even tells you which way to position the diff
Herkimer Jitney is offline
Old 03-30-2009, 06:26 PM
  #8702
Originally Posted by axle182
yes if you dont use loctite. Use it once, wait for it to set, and it wont have a problem. with the 3 cars, we each run a different amount of diff action (mine has hardly any, dads is very free, and brothers is about in the middle). None of them have changed.
Under what kinda conditions do you use the different diff action on the ball diff?
thanks for sharing!
stocker is offline
Old 03-31-2009, 08:44 AM
  #8703
axle182's Avatar
Trader Rating: 18 (100%+)
thanks for sharing!
its half personal preference, and half road conditions. We run on carpet, and its a fine line before grip flipping. So i run mine as tight as possible, two reasons, i get max drive from both front tires on corner exit, and it also (i feel) reduces front grip a little. I throw it hard into corners, it takes changing your driving style. My brother and father run a little looser diffs, as i do want them to spin tires coming off corners. With the tight diff, the car usually pushes like crazy on corner exit too. so you have to 'point and shoot'. Looser diff will still steer where ever your steering, and will drop power to the front tire that has the least weight on it. So if your racing asphalt, id try it at different stages, hell id even try a few gear diffs with different oils in them (10,000, 5,000 etc). Again this is just personal preference.
axle182 is offline
Old 03-31-2009, 03:46 PM
  #8704
Core Creations's Avatar
Trader Rating: 108 (100%+)
Anyone looking for a mini or Coop body?...
http://www.rctech.net/forum/r-c-item...ready-trf.html
http://www.rctech.net/forum/r-c-item...ody-cheap.html
Core Creations is offline
Old 03-31-2009, 07:05 PM
  #8705
subaru73's Avatar
Trader Rating: 42 (100%+)
Default mini
question for people running liop and tsc spec mini.where and how much weight are you adding to your car to bring it up to legal weight.
subaru73 is offline
Old 03-31-2009, 07:23 PM
  #8706
tony gray's Avatar
How much is up to you. But where? Well this is what we recommend...
HERE....
tony gray is offline
Old 03-31-2009, 08:10 PM
  #8707
MTX3-B's Avatar
Originally Posted by Low_E
hey guys,
I'm looking for the best performing Lipo (hardcased) that fits the M-03M.
ATM I have an Orion 3400 and just wondering if there exists stronger.
I just read about a new Muchmore Stikpack-alike Lipo that will fit the M-chassis, but it delivers about the same punch ...
Orion: 3400 at 25C ==> 3.4 x 25 = 85 Amps
Muchmore: 4200 at 20C ==> 4.2 x 20 = 84 Amps
Anybody knows stronger Lipo's that will fit?
(We can't modify the chassis in our local Tam-cup and may only use hardcased Lipo's)
at the recently concluded KLGP Race held in Kuala Lumpur, Malaysia last weekend, the winner, Mr. David Jun of Tamiya TRF was using IP 4000mAh 25C+.
His car was blistering fast and the power of the LiPo battery was very consistent throughout the heat and final. The second spot was 2 laps behind. We had a 30-minute final in A-main. He used 2 packs of the IP.
MTX3-B is offline
Old 03-31-2009, 08:14 PM
  #8708
cannon's Avatar
Trader Rating: 35 (100%+)
Agree .. the IP4000 25C is a good lipo for Mini.
Also available is the Ace Power 4000 25C or the Ace Power 3200 30C
All will fit the Mini
cannon is offline
Old 03-31-2009, 08:31 PM
  #8709
MTX3-B's Avatar
Since we are talking about LiPo in a mini, can you really feel the difference using a LiPo with higher capacity and discharge rate?
For the low amp consumption of a sport tuned motor and the actual load on the car, does C rating really matter?
Thanks.
MTX3-B is offline
Old 03-31-2009, 08:40 PM
  #8710
cannon's Avatar
More a combination with the capacity of the lipo. Higher capacity lipos "stretch" the discharge curve so that at the end of the race the higher capacty lipos are stil holding higher voltage than a lower capacity one
cannon is offline
Old 03-31-2009, 09:39 PM
  #8711
Drifting101's Avatar
My mini is forever traction rolling what are the methods to stop it?
Drifting101 is offline
Old 03-31-2009, 10:04 PM
  #8712
cannon's Avatar
Mmmmmm ... such an open question. OK here goes:
1. Learn to drive Just joking
2. Steering Exponential . Turn it down
3. Tyres. Make sure you dont have too much grip up front
4. Which Mini to use? I know the Mini Net guys say it doesn't matter and they can win easily with a SWB but have you tried the LWB car. I find it easier
Try different set ups and see which works best for you. Someone elses setup will not always suit another driver
cannon is offline
Old 03-31-2009, 10:41 PM
  #8713
1. I do need to learn a bit with the mini as it is quite different to my touring car but on that rare occasion that my set up is right I do ok
2. I have played with it and I have that set
3. I have to use soft ride tires to get it not to flip if I use 36s like every one else it rolls big time
4. I will try the LWB
I have tried the all published setups for our track
I will try what you suggested
Old 03-31-2009, 10:58 PM
  #8714
cannon's Avatar
what tyrte combination are you using? What is on the front and rear?
cannon is offline
Old 03-31-2009, 11:07 PM
  #8715
Soft ride on the front and rp36 rears is what I have to use to keep it from rolling but I have to "Bully" it to get it to go decent lap times and I have no idea were to start as I have only had decent tires for 3-4 months
