Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 03-18-2009, 12:39 PM
  #8596
Moole's Avatar
Default my mini
hi all
here are some pics of my first mini...
Moole is offline
Old 03-18-2009, 01:18 PM
  #8597
RC MARKET's Avatar
Originally Posted by Moole
hi all
RC MARKET is offline
Old 03-18-2009, 01:59 PM
  #8598
Hyde's Avatar
Originally Posted by edwintklee
hi guys,
for m03R, the rear upright, got 2 holes, any different in handling? if using the lower hole? currently using top hole
the was a post mentioning about front upright, where using the inner hole will make the car easy to drive...
the rear uprights have two holes. one for 0 camber, and the bottom hole for camper[not sure about much dagree of camber sorry] i set the car up with added rear camber from the firs time i built it. I DO think it makes a HUGE difference. then proper tires tires makes the car dialed.
the m03r is all around a very good car. all tamiya hopups so the car is ready for an all tamiya track
Hyde is offline
Old 03-18-2009, 03:41 PM
  #8599
Core Creations's Avatar
Trader Rating: 108 (100%+)
For carpet I put 5mm front internal spacer in the shock and 3mm in the rear. Thats with the standard TRF shocks. If you use the new M-Chassis version TRF shocks you will use much less spacer wise.
In mine and several other local mini racers opinions the sways are a must on carpet. If the car is setup right it makes a HUGE difference. As do other small things...but I am only allowed to tell so much.
Originally Posted by Low_E
and should I alter my shocks when using swaybars?
My mini drives rather ok for the moment, but haven't tried the combination with swaybars.
In other words, do the swaybars make the shocks function differently?
I guess I'll find out but any info is mucho apreciated.
Core Creations is offline
Old 03-18-2009, 03:55 PM
  #8600
Low_E's Avatar
are the black swaybars the stiffest?
(That's what they seem to me)
Low_E is offline
Old 03-18-2009, 05:58 PM
  #8601
Default ABC Mini Pickup bodyshell mounting?
Hi , i've just got a mini pickup bodyshell and was wondering how you mount the shell at the rear as the standard tamiya mounts are shaped and too long.
BILKO1 is offline
Old 03-18-2009, 06:05 PM
  #8602
ChattyMatty's Avatar
Default any chance you got a pic of that?
I'm gunna pick up one of those bodies, and Patrick has mentioned the issue but I have never heard how to solve it. I was assuming these would do:
http://www.tamiyausa.com/product/ite...oduct-id=50855
ChattyMatty is offline
Old 03-18-2009, 06:08 PM
  #8603
No the black swaybars are the softer of the two. I use the blacks most of the time. You can use them to tune a little from there. If the rear is too planted you can run the silver rear. And if the front seems to dump over too much you can use the silver front.
A couple carpet tips:
Glue the sidewall on the front tires. This will reduce the rollovers.
Start with 70wt oil 2 hole pistons in the front with a 5mm internal spacer. I'd start with a Blue short front spring and tune from there.
Dump the car low...like 2-3 mm max ride height.
In the rear I'd start with 50wt 2 hole pistons and yellow short springs(TRF Shocks) and a 3mm internal spacer. Ride height about 0.5mm higher than the front. A safe tire combo is S-grips up front and A slicks in the rear.
Old 03-18-2009, 06:32 PM
  #8604
Hyde's Avatar
yep those would work perfect. or you could mod some tc3 rear ones or even maybe straight ta03 posts
Hyde is offline
Old 03-18-2009, 06:37 PM
  #8605
[QUOTE=ChattyMatty;5568201]I'm gunna pick up one of those bodies, and Patrick has mentioned the issue but I have never heard how to solve it. I was assuming these would do:
Looks like they would work i'll try and get some.
BILKO1 is offline
Old 03-18-2009, 07:06 PM
  #8606
R/C Tech Elite Member
monkeyracing's Avatar
Try a set of M-03 front body mounts on the rear. I did with a body that was too low and it worked. Don't know for sure if it would work for you, but it's worth a shot.
Jim
[QUOTE=BILKO1;5568311]
monkeyracing is offline
Old 03-19-2009, 12:28 AM
  #8607
i used TL-01 rear posts
fits loverly
sidecarphil1 is offline
Old 03-19-2009, 08:54 AM
  #8608
axle182's Avatar
Trader Rating: 18 (100%+)
OK ill post up my setup that worked pretty darn well at the local big race last weekend. M03R kit.
Front -
Tires - S grip Radials
Insert - Hard tamiya foam - no double stuffing
Tire Sauce - Niftech - Inside first line of radial blocks, no more
Ride - level lower arms or go higher, try the feel
Springs - Blue short springs
Shocks - TRF Mini shocks, setup as instructed for the M03
Toe - dead ahead at ride level
Ball diff - TA03 tight as i could get it (still a little diff action)
Camber - Fixed Links
Rear -
Tires - Type A slicks
Tire Sauce - Niftech - Full
Ride - as low as you can go before dragging.
Springs - Red short springs
Shocks - TRF Mini shocks, setup as instructed for the M03 (double check you have MINIMAL droop)
Toe - M03r rear uprights - 1.5 deg
Camber - roughly 1.5 deg at ride level
Other mods, i placed a TONNE of lead in the bottom of the rear compartment, not all the way to the back tho, and a big strip across the underside of the lipo, full width. electronics were placed ontop. My car was one of the heaviest. I could still traction roll if pushing way too hard, but it was FAST. I ran no sway bars, didnt touch the car at all during the entire weekend, i just tried a little more sauce on the front, and it started to traction roll more, so kept it to the first inside line of radial blocks. It was a little rocket, and it held TQ most of the weekend, even with my rusty driving. If i wasnt super rusty and shaking in the final, i think it would of done very very well. Started 2nd, and was 7th by the first corner, but caught back up to have an epic battle with 2nd place, ended up 3rd overall.
This was on medium grip carpet. I would have glued the sidewalls if the grip had of come up alot (if you have alot of foam cars at your race), but the current setup about was perfect. With a little more practice, i think we would have won it.
axle182 is offline
Old 03-19-2009, 02:44 PM
  #8609
mach51's Avatar
Trader Rating: 31 (100%+)
I was thinking of getting an M03. I was looking at the M03R but from what I can tell it does not come with a body. So, it might be cheaper to get the base version that comes with a body and upgrade it? Id also rather have threaded shocks than clear shocks. Is there a list somewhere of what shocks do and do not fit these cars?
mach51 is offline
Old 03-19-2009, 02:51 PM
  #8610
Hyde's Avatar
get the m03r. it comes with a huge amount of tamiya hopups. you could get a body and some nice tamiya alloy shocks for about 60.
if you get the m03 base model. you'll have to pay about 150 for everything the m03r has and you'll still have to buy alloy shocks.
another thing to think about.... if you want a stock car for cheap get the m03.
if you like easter egg hunts and you wanna hunt for tamiya hopups then get a stock m03 and start hunting!
its way more cheaper to buy a m03r if you want a hopped up mini.
NOTE: the blue alloy bling the m03r comes with makes this car stronger and it has more adjusting points on the uprights and other cool little stuff. also its "cool looking" lol
m03=big bang for you're buck
m03r=HUGE bang for the buck
Hyde is offline
