Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 03-01-2009, 09:59 AM
  #8446
jonest's Avatar
Which brushless motor would most suit the M03?? Any recommendations?
jonest is offline
Old 03-01-2009, 12:16 PM
  #8447
tony gray's Avatar
Due to CONSTANT email questions and requests (AAARGHH! I cant stand it any more!!) we have released ONE of our chrome chassis sets onto the open market..
Info is on rc-mini.net, or go HERE to check it out. And Good Luck!
Remember, this is ONE of only 20 in the world....and there wont be any more.
tony gray is offline
Old 03-01-2009, 02:03 PM
  #8448
Swamp Rat's Avatar
I saw one Saturday Night in Brisbane Qld.
Very Very Nice indeed. Almost Blinding infact.
The Rat
Swamp Rat is offline
Old 03-01-2009, 02:22 PM
  #8449
tony gray's Avatar
That'd be Mr Harris showing off then wouldn't it Shane...
I think I could see the reflection off it down here in Melbourne even.
Old 03-01-2009, 09:30 PM
  #8450
edwintklee's Avatar
Trader Rating: 23 (96%+)
for me, i am using 13t hobbywing, speed almost = sporttuned, as recomended by the mini racers here.....
after running this bl systems for over few month, i notice virtually no $$ or extra effort spend on my mo3R...always charge battery and run...
edwintklee is offline
Old 03-01-2009, 09:32 PM
  #8451
edwintklee's Avatar
Originally Posted by tony gray
You're partly right...
The whole point of this is to keep the outdrive (the bit that sticks out of the chassis from the diff) firmly stuck IN place. And whether you use dogbones or unis the intent is till the same. Keep that outdrive in place.
Foam degrades and loses it springiness, rubber o rings perish.
So if you want to take it to the final degree, yes maybe if you're using dogbones you might want to put an or ring in the outdrive and one out in the hub as well. BUT...often this will be too tight and bind the whole system up.
I don't use dogbones anyway though...
generaly i got it, so i best get silicon fuel tube for this purpose?
i too don use Dog bones
Old 03-01-2009, 10:10 PM
  #8452
cannon's Avatar
Trader Rating: 35 (100%+)
Well Mini maniacs I am sitting here staring at a LARGE shipment of Shimizu mini tyres. Now life is really good. These will be put up on the website tonight. Shipment includes the 25 and 35 D98 tread plus some of the Shimizu slicks.
Great to see Shimizu around again
cannon is offline
Old 03-02-2009, 12:20 AM
  #8453
Drifting101's Avatar
Tony Ps Mini looked awesome at KROMA on Sunday with the chrome chassis, orange bling and rims to match, up until he tried the drifting tires aka X Patterns
Drifting101 is offline
Old 03-02-2009, 01:29 AM
  #8454
tony gray's Avatar
I did warn him....
Old 03-02-2009, 04:48 AM
  #8455
caltek1's Avatar
Trader Rating: 38 (100%+)
stocker,
I initially had my turnbuckle hinge pins on the inner hole on the MO3R uprights and found the car to be very sensitive to steering input. This was even with the steering speed at 50, so I changed them to the outer hole on the knuckle and have found the car so much easier to drive. I have not tried the most forward hole as I do not require any more steering.
You just need to make the turnbuckles longer so that you get the same toe out or run the front tyres straight when the front end is compressed.
BTW
I use spektrum and a digital servo, so the steering speed was way to quick. The car was on a knife edge all the time and this change slowed the steering reaction time down as well as making some minor changes on the radio.
Hope that helps.
Regards,
Calvin.
caltek1 is offline
Old 03-02-2009, 10:34 AM
  #8456
edwintklee's Avatar
hey calvin,
good input. i will try too....
Old 03-02-2009, 06:21 PM
  #8457
Mooshu Beef's Avatar
Hey guys, this is my first post in the Mini thread.
This summer I will be teaching kids how to put together a chassis that I have a sneaking suspicion will be the M-03 because the person I talked to said they are "mini-coopers" and I know they are Tamiya.
I am wondering if there are any complicated parts/suggestions you have for putting the chassis together. Also, I am hoping the place I am working at will have an extra chassis so I can throw in some electronics myself and option parts I can order ahead of time. What are valuable parts to have for these chassis' if I were to order some option parts ahead of time?
Thanks for any and all help!
Mooshu Beef is offline
Old 03-02-2009, 11:06 PM
  #8458
caltek1's Avatar
Mooshu Beef,
Go to this web site and read it. This will answer nearly all of your mini questions.
http://www.rc-mini.net/
Regards,
Calvin.
caltek1 is offline
Old 03-03-2009, 03:20 AM
  #8459
edwintklee's Avatar
does any1 find this new product usefull?? help full???
Old 03-03-2009, 05:01 AM
  #8460
Kail's Avatar
I was trying it during TITC. Well. If you are putting spacers into your shock already, then you will not need it. This tool makes it easy for you to adjust downstop with full length shocks. So it makes it easier rather than disassembling the whole shock.
Kail is offline
