Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 11-17-2005, 10:50 AM
  #826
Customworksking's Avatar
Trader Rating: 74 (100%+)
Arrow class
sweet i hope they split em up
Customworksking is offline
Old 11-17-2005, 10:57 AM
  #827
Steven Key's Avatar
Doc,
Any rumors of rule changes if they split the mini class? Like gear ratio.
The MO3 and MO3L are similar but there is a big difference between MO4L and a MO4m in wheel size.
Steven Key is offline
Old 11-17-2005, 05:44 PM
  #828
rccardr's Avatar
Don't have any more detail than that. No need to restrict the M04's to a 19 tooth pinion if they're only running against each other...
rccardr is offline
Old 11-17-2005, 08:08 PM
  #829
I am running a set of foams on my m03 . I don't know anythiing about on road so could someone tell me what a pink foam is a what a purple foam is ? what is the difference , and which ones should i be running in the front/rear ?
Mr.Pink is offline
Old 11-17-2005, 08:15 PM
  #830
Wicked-Wayz's Avatar
Trader Rating: 19 (100%+)
The colors are the different compounds. Which kind depends on the track you run on. Carpet, Asphalt, high bite, etc. Each company varies on the compound colors. A bsr purple can be different than a jaco purple. I honestly wish they were the same. Where did you get the foams for you mini.
Peace Aaron(W-W)
Wicked-Wayz is offline
Old 11-17-2005, 08:32 PM
  #831
the foams are actually from my TC3 , they are only 3mm taller than a standard mini tire , and 2mm narrower .
Mr.Pink is offline
Old 11-17-2005, 08:38 PM
  #832
cat007's Avatar
Default Foam Tires
Do you happen have the part number for the foam used on the TC3?? like to give it a try if its really just 3mm taller!!
cat007 is offline
Old 11-17-2005, 08:39 PM
  #833
Okie Dokie what brand are they. Here for the tamiya tires we run m-grip in front & s-grip in the rear. I know only a little about foam tires. Hopefully someone else can shed some better light on this.
Peace Aaron(W-W)
Old 11-17-2005, 11:13 PM
  #834
I don't have any part numbers , since i bought the tc3 used , the rims are standard touring car size and i don't know much about the foams either . Just go down to you local hobby store and ask them to "true" the foams down to the diameter you want . You could true them down to the same diameter as a standard "mini" tire if you want . I have another set of foams mounted on touring car rims , but they are wider than standard size rims/tires so they wont work on the mini . Tomorow i will get some pics up that shows just how similar the sizes are between the Sgrips and the foams i am running .
Mr.Pink is offline
Old 11-18-2005, 10:40 AM
  #835
Steven Key's Avatar
So for the TCS races if we can run our MO4L with a 21 tooth pinion it is going to be much faster than the MO4m with the same pinion.
I'm glad I decided to hang onto the two MO4L that I have.
Old 11-18-2005, 11:05 AM
  #836
Turbonium's Avatar
Trader Rating: 27 (100%+)
im sure if the different tire sizes are allowed, the gearinf will be adjusted to make it fair.
i do like the rwd, just couldnt hang with 'em on the straights in Memphis with that 19t pinion....
Turbonium is offline
Old 11-18-2005, 12:18 PM
  #837
Trader Rating: 114 (100%+)
Hello,
Does any one know when the TCS rules and dastes are going to come out?
Dave
dragracer72nova is offline
Old 11-18-2005, 03:11 PM
  #838
jw92656's Avatar
Anyone know where to get the Hollow Carbon Gear Shafts P/N 53390 ? I can't seem to find them anywhere ? Thanks.
jw92656 is offline
Old 11-18-2005, 03:14 PM
  #839
Trader Rating: 28 (100%+)
at some point the silver can will only pull so tall a gear ratio...or am I missing something...again, like the mini rookie that I am
madjack is offline
Old 11-18-2005, 03:41 PM
  #840
squarehead's Avatar
Trader Rating: 75 (100%+)
RCBoyz on eBay has most of the hop-up parts. I got mine from him for a few bucks. Drop them an e-mail, I'm sure they will have them for you.
squarehead is offline
