Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 11-11-2005, 09:49 PM
  #811
Hi guys, does anyone have any set up tips for a fast bitumen track ? tyres are type A 60d slix all round.What is the common toe in / toe out measurement on the front ?
jim beam is offline
Old 11-12-2005, 05:29 AM
  #812
tamiyarcracer's Avatar
Originally Posted by SeattleRCer
I'm not too familiar with Tamiya parts yet... Will the blue TRF shocks (part #49355) fit my M03? Will any TRF shock fit my M03? Or are there different types of TRF shocks, other than color? Thanks!
All the the Tamiya aluminum shocks are the same in size and length. they are different by color and some of the aluminum goodies for them. And even the non threaded bodies are the same size and length.
And yes they will fit on the M03
tamiyarcracer is offline
Old 11-12-2005, 07:16 AM
  #813
RaceBucks's Avatar
At SoCal we have a high traction asphault track; most of the guys run a slight toe out 1 to 2 degrees. Cooper seems to go to neutral when the front dives, if you were neutral or toe in than it would be pretty severe toe in the turns. SoCal tracks are fairly technical so toe out seems perfered here.
RaceBucks is offline
Old 11-12-2005, 08:31 PM
  #814
MrPhoney's Avatar
Default SoCal Racing
So you guys are running on Tuesday nights? I might have to come down and run mine if I can get away from Tuesday night commitments. I usually race PanCar on Saturday nights but that class has not run for quite awhile.
MrPhoney is offline
Old 11-12-2005, 10:08 PM
  #815
SeattleRCer's Avatar
Thanks for the shock info, tamiyarcracer! By the way, I made it down to SIR a few weekends ago. That place is great! Didn't have a chance to drive, but watching the races and meeting a few people was a good time. I hope to make it down there again in the next couple weeks for some practice. It'll be my first time driving on an onroad track, so should be fun.
SeattleRCer is offline
Old 11-13-2005, 05:16 PM
  #816
Hi -
Would appreciate if anyone can let me know how to measure the front toe angel of the M03L, the standard touring car setup station (for 190mm touring car) does not seem to work. Thanks alot!!
Dennis
dennis01 is offline
Old 11-16-2005, 05:31 PM
  #817
Trader Rating: 28 (100%+)
so here is the question:
front drive or rear drive chassis...to race?
madjack is offline
Old 11-16-2005, 05:55 PM
  #818
mo3 or m03l r the most popular classes for mini. i.e front wheel drive
Doomah is offline
Old 11-16-2005, 07:12 PM
  #819
What springs should I run ? I have a couple sets from a TC3 and they are shorter than the stock cooper ones , I have blue , yellow , silver . Any suggestions ? this is on a otherwise stock mini , except i am running foam tires . should it be stiffer in the front and soft in the rear , I just need a good starting point , then i will fine tune to my driving style . Also , is there a way to make the ride hieght lower when using the stock friction type shocks ? thanks .
Mr.Pink is offline
Old 11-16-2005, 08:20 PM
  #820
people generally run stiffer in the front and lighter in the rear, coz about 80% of the weight is on the front end.
you can lower the car by putting orings below the shock pistons.
Doomah is offline
Old 11-16-2005, 08:49 PM
  #821
Hebiki's Avatar
Trader Rating: 26 (100%+)
madjack.. LOVE THE avatar.. looks like a BUMPY but fun ride.
Hebiki is offline
Old 11-16-2005, 09:54 PM
  #822
I don't understand where to put the orings ?
Mr.Pink is offline
Old 11-16-2005, 10:46 PM
  #823
directly underneath the shock pistons
Doomah is offline
Old 11-17-2005, 04:33 AM
  #824
rccardr's Avatar
Madjack- Early word is that for 2006 the Mini class will be split into FWD (M03, M03L) and RWD (M04, M04L) so that they can compete against each other equally.
rccardr is offline
Old 11-17-2005, 08:56 AM
  #825
Turbonium's Avatar
Trader Rating: 27 (100%+)
dang Doc... if that happens, ill hafta choose! i love the rwd's, tho... i need to run 3 classes now!
Wes
Turbonium is offline
