Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 01-12-2009, 10:18 AM
  #8116
chicagokenji's Avatar
Just a note to anyone running a Mini Cooper in and around Chicago.
We are now racing them at Strictly RC (NW side of Chicago) on our new carpet track. Here's a video from last month when we were racing Vendettas:
http://www.youtube.com/watch?v=6mcrM6XlzKM
People are also now showing up with them at our other Chicago track, Underground RC Racetrack. Here's a video from a Trans Am race from last month at Underground:
http://www.youtube.com/watch?v=BZbMl9uCKb8
If you'd like more info feel free to email me:
[email protected]
chicagokenji is offline
Old 01-12-2009, 07:34 PM
  #8117
CSF0623's Avatar
Does anybody know who makes this Toyota bB body?
CSF0623 is offline
Old 01-12-2009, 11:33 PM
  #8118
tony gray's Avatar
Easy, that's a Toyota bB from Active Hobby in Japan
Readily available from nearly all of the HK and Japan based shops, probably not so easy to find in the US though.
tony gray is offline
Old 01-13-2009, 09:53 AM
  #8119
Originally Posted by Team Ash
I am no where near an as knowledgeable as a lot of others here but try having another look at your suspension. Make sure that the shocks are not only the same length but that they feel the same when you compress them. If they are not even side to side you can get some really weird handling.
Terry
Problem solved, the upper arm was loose!
stocker is offline
Old 01-13-2009, 10:32 AM
  #8120
CSF0623's Avatar
Thanks Tony!
CSF0623 is offline
Old 01-13-2009, 06:28 PM
  #8121
edwintklee's Avatar
Trader Rating: 23 (96%+)
my ride. with new body shell..................
Attached Thumbnails Tamiya mini cooper-image471_2.jpg   Tamiya mini cooper-image472.jpg
edwintklee is offline
Old 01-13-2009, 06:51 PM
  #8122
Core Creations's Avatar
Trader Rating: 108 (100%+)
Who makes that shell?
Core Creations is offline
Old 01-13-2009, 07:39 PM
  #8123
edwintklee's Avatar
mugen fit spec D by www.abchobby.com
Old 01-13-2009, 09:37 PM
  #8124
MTX3-B's Avatar
edwintklee,
I see that u r using the HW13T 3000KV. hows the performance on a standard touring tires? Mine felt so so sluggish. Havent tried on the original mini tires tho. Whats ur setup on the esc?
thanks
MTX3-B is offline
Old 01-14-2009, 02:03 AM
  #8125
We don't know how the Rides will last, the old ones used to last forever, still too early to tell with the new ones.
Any current feedback on the Rides? Are the included sponge inserts any good? How do they compare with SPICE?
stocker is offline
Old 01-14-2009, 02:07 AM
  #8126
cannon's Avatar
Trader Rating: 35 (100%+)
We have been using the new Rides and the Spice tyre. Both last very well. I would use the Ride optional inserts with the Ride tyres. They make a firmer tyre which helps avoid traction rolls on grippy tracks
cannon is offline
Old 01-14-2009, 02:15 AM
  #8127
Thanks! I can only find SPICE inserts, any issue with using SPICE inserts on RIDEs?
stocker is offline
Old 01-14-2009, 02:29 AM
  #8128
cannon's Avatar
Stocker,
Do not use Spice inserts in Ride tyres
They are far too thick
Ride inserts are 4.1mm
Spice are either 5.0 or 5.5mm
They will make the Ride tyre bulge or far too hard
Plenty of Ride inserts in Australia
cannon is offline
Old 01-15-2009, 08:37 PM
  #8129
We're trying to resurrect some Mini racing at some local Chicago tracks.
Guys will be jamming softshell Lipo batteries into the Mini chassis and race with them.
Will they race just fine or are people adding weight to mimic NiMh cells to handle better?
Old 01-15-2009, 09:22 PM
  #8130
MD
MD's Avatar
Trader Rating: 136 (100%+)
The last few races at Hobbytown this past summer we had a good sized heat. I'd like to see that class grow. It really can be a budget racing class.
MD is offline
