Tamiya mini cooper
#7321
yes that yokamo is nice i also had one years ago was one down from yours without the shocks . if your having problems with the front end bye a one way kit for it we use it and it works great have front a little under level and after you get use to it you can dive into the corners just like you had brakes .another way you can go to is to put one or two more washers in the balll dive and tighten it down it seems to work good to . if you want to go for speed get the baja motor that comes in the kit is 540 can fancooled internaly and on trinity monster machine 8.99 volts 54.000 rpm is just ballistic to drive
#7323
Yeah I've been thinking the same thing ever since I got my M03...now with my M03 all beat up I'm thinking about scratch building something.
#7324
Hey Tony! I've been perusing the rc-mini site for some time now, and noticed that you guys don't seem to like Tamiya tires. Does anyone in your crew run them, or are you all fortunate enough to have easy access to the south Asian market and all of it's goodies?
If so, what do you run if you're racing on carpet? We don't see much of anything besides Tamiya tires here, and people seem to have success with them. Are any of the tires you guys have reviewed on the site suitable for indoor carpet use?
Anyone else want to pipe in on this one? I'm looking for a new tire combination, and besides maintaining the great traction I've got now, I'd like to reduce the amount of rolling my car does. It's not much, but even once per race is a little annoying. I'm running 60d slicks on the front, and S Grips on the rear. Hard inserts all around.
Jim
Jim
#7325
Because Tamiya tires are very mediocre Jim.... Nowhere near as good as most of the aftermarket ones. And given that 99% of our racing over here is done on Asphalt it's a no-contest situation for us.
But...we do run Tamiya tires if we run carpet. S grips mainly, and they work fine there.
#7326
I've actually been pondering the idea of popping for some Team Powers tires from Harris RC. When you guys mentioned the wear characteristics, I thought my dreams had come true. That and they don't allow for much in the way of speed rolling. Seems to me I've spent more money on far more foolish things in the past.
We need a Canadian distributor to end the virtual monopoly that Tamiya's got here for m chassis tires.
Jim
Jim
#7327
One thing to remember Jim is that the rules we run under for CARCAR and WCICS (or at least my interpretation of them) would not allow non-Tamiya tires. I realize that the situation at KARZ is different (probably for the better too
) but it's something to keep in mind for those of us running multiple series.
Having said that I've been thinking of trying out the non-Tamiya alternatives too!
Cheers,
Mike
Cheers,
Mike
Jim
Jim
#7328
Yeah, our rules at KARZ are fairly relaxed. We've even got some of the kids running on touring car foams, since it likely doesn't make much of a difference for them. Stu had some interesting rims he ordered in from somewhere, with a different offset. A few weeks back, Aaron was running some HPI X patterns on his M04.
As race coordinator, I'm completely cool with it, unless someone gains a massive, dominant advantage over everyone else because of the gear they're running. You, Stu, Josh, etc all did well not because of tires, but because you are all very good drivers.
So, until something momentous happens, KARZ is going to be relaxed about the tire rules. Everyone just has to remember to use the correct rubber if/when they run at CARCAR.
Hey, while I've got you here, Mike, it was M Grips you were running at all 4 corners, right? They seems to allow just enough slip on the carpet. Very nice.
Jim
Jim
#7329
Jim
Jim
Anyone run enduros with Minis? We've run a few over the last year and they have been a blast! 1.2 hours, three man teams and a manditory motor change. The last race was decided by .2 seconds! Here's the results:
http://www.hobbyplexraceway.com/resu...nduro+Results/
Tim Ski
#7331
I'm thinking I'll have to try out a swaybar up front just try to deal with the traction rolling and make the car just a little bit more forgiving. Anybody have any experience with the swaybars and their effectiveness (or not!).
Cheers,
Mike
#7332
I'm don't know about the sway bars. I ran a set a while back, found the the car didn't handle as well, and rolled over just as much as ever. But, like like it says on rc-mini "Some people swear by them, others at them."
I'm going to try running S grips on the front and M grips on the rear this weekend, with hard inserts all around. I may even try to double stuff the fronts.
Jim
Jim
#7333
#7334
#7335
This summer I ran "S" grips all the way around with HPI medium/hard molded inserts, double stuffed in front and HPI medium molded inserts in the back with sway bars and it ran well in our parking lot series with almost no traction rolling. I ran an M03L. My friend ran the same set up on his M03M and has similar results.
