Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 03-31-2008, 12:59 PM
  #6496
mep
mep's Avatar
Trader Rating: 40 (100%+)
Originally Posted by shadow102
i recently picked up a set of tech racing m03 springs and am trying to figure out which are the hard, medium, and soft springs. They are all white but two have a silver dot on top, two have blue dots, and two are just straight white
The Tech Racing mini dampers come with a chart. The springs are Blue, white & Black however, no silver.
blue = hard
white = med
black = soft
mep is offline
Old 03-31-2008, 01:36 PM
  #6497
TryHard's Avatar
Originally Posted by tony gray
Latest update - It's here....
The definitive guide to Mini setup, online NOW. Go here to find out just what to do to get in the winners circle!
question is, how many are true....
Like it's mentioned at the bottom... April 1st??
Hehe
TryHard is offline
Old 03-31-2008, 01:39 PM
  #6498
caltek1's Avatar
Trader Rating: 38 (100%+)
G'day Tony,
I got five mentos in my motor, what's the record????
CYA
Calvin
caltek1 is offline
Old 03-31-2008, 02:12 PM
  #6499
tony gray's Avatar
A Joke Cal?
I assure you this is no joke. It's cutting edge setup advice.
You wont find anyone else telling you stuff like this!
tony gray is offline
Old 03-31-2008, 02:58 PM
  #6500
Jaybo's Avatar
i've just spent the last 45 minutes matching my bearings, some were really crap!
Jaybo is offline
Old 03-31-2008, 03:41 PM
  #6501
TryHard's Avatar
Wonder why...
TryHard is offline
Old 03-31-2008, 03:52 PM
  #6502
Scottrik's Avatar
Trader Rating: 261 (100%+)
A little-known improvement to the quench-hardening springs hint is to cool the spring in the saliva on your tongue. "Thry it...it workth"
Scottrik is offline
Old 03-31-2008, 05:06 PM
  #6503
I'm a little confused by which ones were jokes and which were legit, but the one about cutting every other diff gear tooth, that kinda looked like a recipe for little pieces fouling your gears up? You can see the little fragments it leaves behind.
eric7 is offline
Old 03-31-2008, 05:38 PM
  #6504
Jaybo's Avatar
yeah - you need to make sure you dont chip any of the 'good' teeth, and make sure you completely remove the other teeth, give it a good clean with a toothbrush or similar to get all the shavings out so they dont clog up the gearbox.
Jaybo is offline
Old 03-31-2008, 05:48 PM
  #6505
killingtime's Avatar
LOL!
So Tony, do you recommend the mint or strawberry Mentos? OR!, could you use diet soda vs. regular? I'll have to do extesive testing to find out what has the most carbonation too, as this seems to assist in the molecular bonding of the soda to the brushes.
killingtime is offline
Old 03-31-2008, 11:26 PM
  #6506
Herkimer Jitney's Avatar
Damn, thats one of the funniest articles I've read on the web for ages.
You guys are just nuts. Brilliant stuff.
I love the toe-out, toe-in thing so they both point the same way...
You know I almost believed some of them....
Herkimer Jitney is offline
Old 04-01-2008, 12:12 AM
  #6507
One of our local racers actually pulled off the "clip off every other tooth on the spur to make it faster" on one of our other more gullible racers. To see that guy scratch his head and wonder why the car wasn't working was priceless! (btw- he was given a replacement spur for the one he hacked up)
Old 04-01-2008, 10:28 PM
  #6508
over gear's Avatar
Trader Rating: 18 (100%+)
anybody know where can i buy Spice inserts? i've tried ChampRC and RCMart... no luck
over gear is offline
Old 04-01-2008, 11:17 PM
  #6509
caltek1's Avatar
overgear,
did you try here,
http://www.rainbowten.co.jp/english/
Later
calvin
caltek1 is offline
Old 04-01-2008, 11:58 PM
  #6510
over gear's Avatar
thanks calvin!
