Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 03-24-2008, 10:14 PM
  #6421
asw7576's Avatar
Originally Posted by Ashley Cobb
I used to have some stuff called kyosho diff locking clay... would that be a solution to what you are looking for...?
by the way, what is the advantage of tightening the diffs? wouldn't it just make the understeering worse?
yes, will be more understeering at corner entry and possibly including mid cornering too.
The reason behind using lock diff is to achieve maximum forward traction on both wheels while exiting corner.
asw7576 is offline
Old 03-24-2008, 10:34 PM
  #6422
Trader Rating: 28 (100%+)
I get ya, so when the little buggers whine coming out of the corners thats wheel slip?
cheers
ash
Ashley Cobb is offline
Old 03-24-2008, 11:05 PM
  #6423
Suspended
Originally Posted by kwkride
I'm really new at this (only competed twice so far) but last week we did have 13 cars listed for the "main".
Jim
On 11 Aug 2008, well over 50 peepz from all over New England, other nearby states, and forgeign countries overseas will want to participate in the TCS with their M03s.
The local shop's track, R/C madness, in CT, can't handle the TCS, but yet they insist they can (and did it very poorly) hold up thru the past years. The TCS director will be pressured to cut corners to accomodate the rest of R/C Madness's schedule, due to time constraints, and kill time by making it all happen in the same time it takes for the average race. He will make the call for over 12 cars like he did last year.
It's all a fender bender and crash magnet, waiting to happen there, if they plan to run it on their current schedule. That's just another reason why I'm out!!!!
I certainly hope they do less than 8 at a time. I've seen the track. It's small and super tight. No room for full speed - even for a Maubauchi Motor (barely obtainable unless it's fresh out of the box for a kit.).More than 6-8 car heat would not be good for the TCS races there. But, as I have found out, there are way over 50 entants already. That will eat up a day or two heh.
dragnse7en is offline
Old 03-24-2008, 11:47 PM
  #6424
westerdude42's Avatar
Originally Posted by rccardr
The '20 people on the track at one time" thing was not Mini class-it was the much smaller, much slower Porsche/Ferrari TamTech class. And on the Aliso track even 30 cars would not be a crowd in that class!
Mini's at TCS run like what you would expect- 6 to 8 in each qualifier, 10 in each Main.
The Seattle TCS is running 6 car heats for quals and 8 car mains. 7 with a bump. We got 30 mini entries so far this year, it's gonna be fun.
westerdude42 is offline
Old 03-25-2008, 06:34 AM
  #6425
mkdut's Avatar
Trader Rating: 19 (100%+)
Fun is an understatement. Somewhere in getting ready for TCS I forgot to get the sedan ready because I was having such a good time running the mini. Especially when running with the GT3 guys and giving them a run for their money. Oh well, I still have a few days to prep the sedan.
mkdut is offline
Old 03-25-2008, 07:08 AM
  #6426
Originally Posted by tony gray
You mean like this?
Yes, thanks! Looks like a good fit.
eric7 is offline
Old 03-25-2008, 09:31 AM
  #6427
Mike YGPM
Old 03-25-2008, 10:41 AM
  #6428
mkdut's Avatar
Originally Posted by westerdude42
Mike YGPM
Got it! Insert question answered. By the way the official answer was red inserts from Sorex 28 premounts and firm mini foam.
mkdut is offline
Old 03-25-2008, 11:02 AM
  #6429
TryHard's Avatar
Evening all,
Quick Q, how much weight, if any, are you guys adding to the Orion 3200 LiPo when being run in a mini?
I have a fear that it might be too light with none... but then again, haven't currently got a motor in the car
The LiPo is about 160g lighter than my Sanyo 2400's I had previously been using.
Cheers
Ed
TryHard is offline
Old 03-25-2008, 12:06 PM
  #6430
Core Creations's Avatar
Trader Rating: 108 (100%+)
I personally run 1 oz under each "wing" of the battery and it makes a big difference. Other than that if I were to add more I would mount it inside the rear chassis as close to the battery as possible and maybe some on the front bumper.
Core Creations is offline
Old 03-25-2008, 12:13 PM
  #6431
tony gray's Avatar
Originally Posted by TryHard
Evening all,
Cheers
Ed
Ed, we run an extra 120 gms distributed inside the front and rear bumper and a little inside the rear chassis.
With no weight at all the car has a huge tendency to traction roll..
Plus, most ruling bodies will stick a minimum weight limit on Minis once they start running lipos, so inevitably you'll need to add weight anyway.
tony gray is offline
Old 03-25-2008, 12:16 PM
  #6432
Steven Key's Avatar
Hey TryHard,
I run my Mini to the TCS required 1,300 grams minimum weight.
With a 3200 Orion LiPo I had to add 140g to get my car to weight 1303 grams.
Steven Key is offline
Old 03-25-2008, 12:28 PM
  #6433
TryHard's Avatar
Cheers guys, just what I'm after.
I'm only really using the car for a bit of a laugh at local club meets (although you wouldn't think of it too look at it... ), but still don't want to spend the whole time rolling over
I'll add a load of weight to the bumpers. I can get some underneath the battery too, but I'll have too glue that on, and grind off some of the lettering to be able to slot the battery in properly.
Cheers
Ed
TryHard is offline
Old 03-25-2008, 12:39 PM
  #6434
rcarmchl's Avatar
Trader Rating: 15 (100%+)
You can also add weight above that battery as there is a cavity in the top part of the chassis, no body will know they are there!!!
rcarmchl is offline
Old 03-25-2008, 12:46 PM
  #6435
and I thought dealing with people was a complex issue!---
bowl806 is offline
